Old August 28th, 2013, 19:11   #1
The_Stealth
Question Limp Mode :(
Just had my TB done and now I have a limp mode problem. Prior to the TB change my timing was seriously retarded and just below spec. My car has .205 injectors and a Unitronic Stag 2 tune. I took the following logs to help diagnose the problem. From what i can see the MAF is working ok. What do I check next?
Error Code:
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 35-10 - - - Intermittent
Log 1
LOG 2
The_Stealth is offline   Reply With Quote
Old August 30th, 2013, 05:54   #2
Monster1926
Fuel Economy: 45 mpg
Check your vac lines to start.
Monster1926 is offline   Reply With Quote
Old August 30th, 2013, 06:15   #3
LNXGUY
LNXGUY's Avatar
vac lines, vnt actuator, the vnt vanes themselves, etc.
Bill
LNXGUY is offline   Reply With Quote
Old August 30th, 2013, 07:05   #4
The_Stealth
After some Googling, I found the MKIV limp mode thread here: http://forums.tdiclub.com/showthread.php?t=179589
My vac lines are original on my car, so 10 years old. So they are in dire need of changing. I would like to get some silicone lines, but I am having a hard time finding a vendor that ships to Canada at a good price. Any suggestions?
Old August 30th, 2013, 14:47   #5
The_Stealth
I found this on EBAY. I was wondering of anybody has used this supplier's product? Is there anything else I will need when swapping out the vacuum hoses?
As a side not, I'll be testing by vacuum pump, N75 and actuator this weekend. Hopefully I can narrow it down.
Old August 30th, 2013, 15:18   #6
BobnOH
Fuel Economy: 50/45/35
As a rule, I avoid ebay, but if you know what it is you're buying you can get some stuff.
McMaster-Carr carries a full line of sizes, color, etc., here in the states.
Look for a place like that.
Here is one in Canada, I'm sure there are others
Old August 30th, 2013, 15:48   #7
The_Stealth
Originally Posted by BobnOH View Post
McMaster-Car
I contacted them already and they will not ship to Canada
Old September 1st, 2013, 18:08   #8
The_Stealth
Update!
Vacuum from vacuum pump = good
N75 works fine
Tried to apply a vaccum to the turbo actuator, no vaccuum possible at all! Noticed some rust particles in my Mity-Vac's lines. Took my phone and got this shot:
Looks like my actuator is rusted through. Is this thing easy enough to change out?
Old September 1st, 2013, 18:19   #9
tonystdi
tonystdi's Avatar
Fuel Economy: 50+ mpg, 800 mile club
I had my vnt actuator replaced and the Vacuum lines, years of limp mode gone. Bengone1 did mine, look real easy for a guy who knows what he is doing.
TonysTDI 2003 VW Jetta TDI, 705k+ miles,
miles, 2000 VW Jetta TDI 314,000 miles, 800 mile club, 1990 VW Vanagon
705,000 miles......looking for one million! AARODRIGUEZ CORP.
tonystdi is offline   Reply With Quote
Old September 1st, 2013, 19:01   #10
thordehr
TDI(s): 2003 Jetta
Originally Posted by The_Stealth View Post
Update!
N75 works fine
In the voice of the MythBusters guy, "Well THERE'S your problem!"
May as well get this kit....
http://www.idparts.com/catalog/produ...FS_ZQgodgUcAMg
thordehr is offline   Reply With Quote
Old September 1st, 2013, 19:53   #11
H2O2H
Recently confirmed mine was shot as well. (No over or underboost, just some lose of power and mpg's)
Ordered one from www.leftlanecars.com (they are on ebay as well) and they sell the Garrett ones.
They are other venders on here that sell them as well.
Only one vender responded to me on a Sunday. How they got my sale, and the free priority ship helped as well.
http://www.leftlanecars.com/parts-store/engine-parts/038198716-vnt-actuator/#cc-m-product-6116469782
H2O2H is offline   Reply With Quote
Old September 4th, 2013, 11:17   #12
The_Stealth
Well I had my actuator replaced today. The sucker did not want to come off without a bunch of heat. Got it installed and adjusted (4" it starts moving, finishes at 18"). Put the skid plate back on and went for a drive. Now instead of uncontrolled boost, I had absolutely zero boost. Found that the check valve was finished. Got a replacement and now all is good so far.
I grabbed a few pictures of my old actuator, I'll post them when I get home this evening. It looks way worse than my first photo.
Old September 4th, 2013, 16:11   #13
The_Stealth
As promised:
Old September 4th, 2013, 19:48   #14
H2O2H
Nothing duct tape can't fix. Tomorrow I replace one, will see how it compares.
Shouldn't look bad, since it leaks vacuum, not like yours, which never even saw vacuum, lol..
Limp mode ... new everything, and still limp! big_worm81 VW MKIII-A3/B4 TDIs 7 November 18th, 2016 08:36
Transmission in limp mode - how to reset / remove limp mode? nvr-enuf VW B5 Passat TDIs 7 August 26th, 2013 04:18
Limp Mode dogder VW MKIV-A4 TDIs (VE and PD) 5 September 26th, 2011 12:16
Limp Mode r0nd3L VW MKIV-A4 TDIs (VE and PD) 3 May 28th, 2011 16:50
Limp Mode?? bagdwag TDI Power Enhancements 11 January 15th, 2011 10:40
Page generated in 0.16679 seconds with 10 queries
[Output: 115.46 Kb. compressed to 96.11 Kb. by saving 19.35 Kb. (16.76%)]
