Old August 28th, 2013, 12:44   #1
GravyTrain
Default Torque Converter Locked-Up?
I have a 2000 Jetta, when I put it in Drive or reverse it act like the TC is locked up. There are no codes showing. I can hear a ticking sound when I have it in Drive, and then in reverse it will kill the motor occasionally with my foot on the Brake. Is there a sensor that may be out or a stuck solenoid valve that is keeping the TC locked? What do I need to check?
Thanks in advance.
GravyTrain is offline   Reply With Quote
Old August 28th, 2013, 18:47   #2
Lensdude_com
Lensdude_com's Avatar
Fuel Economy: 50 mpg average (Imperial)
Originally Posted by GravyTrain View Post
I have a 2000 Jetta, when I put it in Drive or reverse it act like the TC is locked up. There are no codes showing. I can hear a ticking sound when I have it in Drive, and then in reverse it will kill the motor occasionally with my foot on the Brake. Is there a sensor that may be out or a stuck solenoid valve that is keeping the TC locked? What do I need to check? Thanks in advance.
The best first step is reading the codes from VCDS.
Lensdude_com is offline   Reply With Quote
Old August 28th, 2013, 22:53   #3
GravyTrain
okay, so I gotta find someone with a "VAG-Com". I saw a thread with a map of people who have one I will try that.
Old September 7th, 2013, 07:54   #4
GravyTrain
Just a follow-up.
The car has been to a couple mechanics and still no certain answer. The first mechanic hooked it up to the Vag Com and everthing checked out okay. He speculated that a valve may be leaking or stuck. He said it would need a deeper look. He didn't charge me and sent me to a vw transmission specialist. One of their mechanics looked at it and said it was fine but my motor mounts were worn. I wanted to explain cause and effect to him at that time. Anyway before i could pick it up some one started the car and saw what it was doing. They said "we're not sure what is causing it but we can rebuild it for 2500".
The trans shifts fine, so i wouldn't think it needs a rebuild, but if I drop the pan and the fluid is silver I would think I would need to rebuild it. They also wanted to let me know my brakes squel, wow so that's what that sound coming from the wheels when I apply the brake is? I shouldn't be a smart a**, I'm just frustrated that nobody knows what is causing the problem but willing to let me spend my money on the big stuff.
Old September 9th, 2013, 17:40   #5
Timeshifte
One of the solenoid valves in the tranny controls the torque converter lockup, its an electrical part, I had a similar problem with my Jetta, but it would kill when put into drive or reverse. The part was inexpensive just be careful of the connector when you replace it. Sounds like your "experts" maybe misleading you. There are several threads on the auto trans. http://www.kansascitytdi.com is a great resource as well as http://forums.vwvortex.com/forumdisp...smission-Forum .
Timeshifte is offline   Reply With Quote
Old September 17th, 2013, 18:16   #6
GravyTrain
Thank you for the help. I have been talking with kasascitytdi through e-mail and they have been a great help as well. After doing some driving around I realized it is locking up in drive as well as reverse, just not to the extent of killing the motor. I have to back out of my driveway so i notice reverse of course. The mechanic that hooked the car up to the Vag Com has been very helpful and said he would check my fluid levels after I do the job (assuming it all goes well for me).. Anyway I will post my results....
Old September 19th, 2013, 10:40   #7
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Me and GravyTrain have talked and I suggested changing the TCC solenoid. I'll bet that fixes it.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions. ASE Certified for Passenger Car Light Diesel Engine.
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old September 19th, 2013, 11:02   #8
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I had an 01M once that had the TC clutch stuck in a sort of halfway engaged position. TCM couldn't detect this, and there were no DTCs anywhere in the TCM, but the ECU had a DTC for throttle body limit (this was a gasser). Almost acted as if the TC clutch apply pressure never fully bled off. But even after I had the transmission OUT, I could barely spin the converter in the bellhouse. And then I realized that this, too, explained the weak crank at startup.
The ECU had the throttle body cranked out beyond what it knew it should have been to stay at idle speed, and that was why it was setting the DTC, and why it kept spazzing out the RPMs in and out of gear. I'd imagine an ALH makes enough torque at idle that in the same condition it wouldn't have cared as much, not sure.
But I agree, I'd try the TC solenoid first. Cheaper and easier.
oilhammer
www.cardocautomotive.com
Old October 6th, 2013, 23:00   #9
GravyTrain
I finally got the new solenoid in. Work is always slowing me down Anyway that foxed the problem thanks for all the help and input. Now to wait for the next something to happen.....
Old October 7th, 2013, 11:42   #10
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
I'm glad it fixed it for you.
nailed
Torque Specs: Torque Converter Nuts blarg VW MKIV-A4 TDIs (VE and PD) 3 July 13th, 2015 13:39
Locked torque converter bobannavw VW MKIV-A4 TDIs (VE and PD) 4 November 12th, 2008 16:17
Torque Converter #? Kayakkermit VW MKIV-A4 TDIs (VE and PD) 2 March 29th, 2007 09:09
Torque converter???? OmegaRenegade Ontario 9 March 5th, 2006 07:30
torque converter Giuseppe1 TDI Power Enhancements 0 February 15th, 2005 22:47
Page generated in 0.15844 seconds with 10 queries
[Output: 96.58 Kb. compressed to 82.34 Kb. by saving 14.23 Kb. (14.74%)]
