Old August 21st, 2013, 21:51   #1
starrd
TDI(s): 1996 Passat
Default Transmission/Shifter question
Hi all,
I have begun to experience weird behaviour with my transmission that I would like some opinions on. My issue is with 5th gear. As long as I downshift early, I have no issues going from 5th to 4th. If however, I press in the clutch and wait too long (low RPM's and low speed) the shifter doesn't want to come out of 5th. If I coast to a stop - no go. If I stop the engine, still no go. Seems to be locked there. The last time it did this I slowly let the clutch back out until the car started to move slightly, then re-pushed in the clutch and I was able to get it to shift out of 5th. None of the other gears do this. I don't want to pull too hard on the shifter for fear of breaking a cable.
CTN diesel trans with 520,000 km's and clutch has about 100,000 km's - it is a Sachs VR6 setup. Any ideas where to start? Don't really want to replace things I don't need to.
Black 1996 Passat TDI Malone Tune, 2.9 bar Map, keyless, k03/04, Vr6 Clutch & PP & PP357's
White 1993 Passat TD - Giles Super Pump, 18psi K14, CTN Trans, Vr6 Clutch & PP, Keyless
Red 1990 Corrado - Stg IV, VR6 Clutch & PP, Diagnostics Chip by me
starrd is offline   Reply With Quote
Old August 22nd, 2013, 06:07   #2
SkyRyder55
Fuel Economy: 5 L/100kms
maybe check oil level in tranny first. I know that 5th gear is prone to failure if tranny level gets low.
PP764 nozzles, RC3+ tune, EGR delete with custom race pipe. MK4 Wolfsberg seats installed,
Bilstein HD, H&R Sport springs,16" Borbet rims,Rockford fosgate components front and rear, Alpine 12" Type R sub. Alpine 1000W Mono Amp, PPI 640 Watt 4 channel amp
SkyRyder55 is offline   Reply With Quote
Old August 22nd, 2013, 12:31   #3
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Or take the end cover off and inspect the shifter fork and linkages.
Before you do that, take a look under the hood, and see if there is anything getting in the way of the shifter linkages. Very common for something to be left in there or to move out of place and get in the way of the pivots/cables.
Also take a look at the black plastic linkage pivot, they tend to break and cause gear engagement issues.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old August 23rd, 2013, 20:55   #4
starrd
TDI(s): 1996 Passat
Thank you for your replies. Will change the oil tomorrow and see if it helps. I have checked the shifter linkage and plastic pivot and they are fine.
Old August 25th, 2013, 19:34   #5
yakko
yakko's Avatar
TDI(s): PASSAT 96,97
Fuel Economy: 43 - 44
That plastic pivot can look good and not work right. I had trouble with reverse and that piece looked good. I replaced it any way and it worked perfect. I think it stretches.
JMHO.
yakko is offline   Reply With Quote
Old August 25th, 2013, 20:25   #6
d.david
TDI(s): 02 Jetta
Fuel Economy: To the Fest 52.7
My trans was acting a little funny and not ha ha. Third would be notchey and not ingage fully but not all the time. 1st to 2nd grind when not shifting fast again not all the time, reverse when backing out of garage would hang up. Changed trans oil used the G070 oil and all have disappeared. Thought I was going to have buy a six speed.
d.david is offline   Reply With Quote
Old August 29th, 2013, 20:52   #7
starrd
TDI(s): 1996 Passat
Thanks for all your replies. I ended up changing the trans oil with Redline MTL and the problem has gone away thankfully. 520,000 kms on original oil must be a little too much I guess.
No Mechanical Link Between Shifter and Transmission? BDison General Automotive 17 June 26th, 2010 15:16
A3 shifter selector on transmission edjet Other VW Group TD(I)s 7 August 7th, 2009 22:48
Manual Transmission Shifter Movement or Vibration cpearson45 VW MKIV-A4 TDIs (VE and PD) 1 May 26th, 2008 08:23
Transmission Shifter hpsauce VW MKIV-A4 TDIs (VE and PD) 0 April 22nd, 2007 18:10
Sticking auto transmission shifter sierrarider VW MKIV-A4 TDIs (VE and PD) 2 August 6th, 2003 17:38
Page generated in 0.15028 seconds with 10 queries
[Output: 80.96 Kb. compressed to 70.26 Kb. by saving 10.70 Kb. (13.22%)]
