Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2013
TDIFest 2013 Discussion about TDIFest 2013 on the Labour Day weekend (August 30th to September 1st, 2013) in Sunday River, near Bethel, Maine. Latest information in the TDIFest wiki.
Old August 28th, 2013, 05:27   #16
Metal Man
Metal Man's Avatar
I wasn't sure if we would bring the tandem this year, but it looks like there will be quite a few with bikes so we're in. Lug_Nut, you'll have to fight my wife for her stoker seat, but we could give it a try if you wanted to go for a ride. She recently had surgery on here arm so she was riding one handed for a bit.
For parts and timing belt tool rentals www.metalmanparts.com FREE shipping on most orders over $75.
Metalmanparts Facebook page
https://www.facebook.com/metalmanparts
Metal Man is offline   Reply With Quote
Old August 28th, 2013, 06:06   #17
Abacus
That helpful B4 guy
Abacus's Avatar
Lug_Nut, so this isn't you?
'97 B4: 453,000 miles Malone 3, K03/04 Hybrid Turbo, PP520's, Stage 2 cam, SBC3, ARP studs, Westach EGT/Boost, Koni Reds/Yellows, 2 1/4" exhaust, 2.5" Cat, no mufflers or EGR, Evo plate,
BUG*PWR 2013 Award Winner
Old August 28th, 2013, 16:39   #18
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Originally Posted by Metal Man View Post
I wasn't sure if we would bring the tandem this year, but it looks like there will be quite a few with bikes so we're in. Lug_Nut, you'll have to fight my wife for her stoker seat, but we could give it a try if you wanted to go for a ride. She recently had surgery on her arm so she was riding one handed for a bit.
I'll pack the helmet, clothes, shoes and pedals on the off chance that can occur. I ususally ride a 56 cm road frame (32 inch inseam, size 11+ shoe). Would the tandem's 'engine bay' accommodate that swap?
Might be, his right hand is empty.
No, a unicycle is one thing I haven't ridden, nor even tried. Monocycle, yes, unicycle, no.
Svante Arrhenius 1896
Old August 28th, 2013, 16:44   #19
Metal Man
Metal Man's Avatar
It's pretty versatile size wise, so it should be good.
Old August 28th, 2013, 18:00   #20
MonsterTDI09
MonsterTDI09's Avatar
Tommorw I will check out some local roads.On a early moring ride.
2010 Jetta sedan TDI DSG Platinum gray metallic.Build date (5/10) Mods ----EV skid plate, E code head lamps, Polar FIS
A cleaning service for DPF. http://www.dpfregeneration.com/ I have no affiliation
MonsterTDI09 is offline   Reply With Quote
Old August 28th, 2013, 23:38   #21
Nuje
Fuel Economy: 1250km/tank
LugNut: Have you ever tried aerobars (a la tri-geeks)? Takes the weight of your upper body off the soft tissue of your hands and onto the skeletal structure (elbows).
I used to get numb hands after even 10-15 minutes, but since switching to aerobars, I can go 100km+ no problem (well, apart from some saddle-soreness and dead legs. )
Nuje is offline   Reply With Quote
Old August 29th, 2013, 05:33   #22
Lug_Nut
Lug_Nut's Avatar
This is an injury that had come up in the past month. I had been hoping that it would be temporary and resolved by now.
I've had clip-on aero extenders but don't think I'm in the condition that allows climbing from the seated position that they require.
Old August 29th, 2013, 06:07   #23
20IndigoBlue02
20IndigoBlue02's Avatar
Climbing in a seated position, even without aerobars is good.... as you're actually more efficient.
Also helps to have appropiate gearing.... so I went with a 32T cassette in the back, with a compact crank up front.
...interesting... though I have a 32" inseam (though I'm 5'10") and I ride a 54cm road bike (endurance geometry)...
2016 Tiguan SE 4Motion
20IndigoBlue02 is offline   Reply With Quote
Old August 29th, 2013, 06:23   #24
Abacus
That helpful B4 guy
Abacus's Avatar
Climbing from aero bars isn't the best since your stability is reduced due to the aero position. I equate climbing to actually having to get out of the saddle, but I also have race gruppo on the bikes and not compact (53/12 to 39/25), so I'm out more than others.
I am 5'11" with a 31" inseam and I ride a 56 or 58, depending on componentry, a 54 is just too short and my knees hit often.
Old August 29th, 2013, 06:40   #25
MonsterTDI09
Aero bars are good for going straight,on the open road.
Old August 29th, 2013, 07:05   #26
Lug_Nut
Lug_Nut's Avatar
...but I also have race gruppo on the bikes and not compact (53/12 to 39/25), so I'm out more than others.
My straight cog days are long behind me now. 13-18 cluster with 42-53 rings? Yeah, back in my 20s and 30s. Now it's 13-23.
The mountain bike's granny is a 24 chain ring and a 28 cog in back.
Wait, it's worse than that! The rear is a 24 incher so that's even lower gear inches than a 26 or 29.
Old August 29th, 2013, 07:20   #27
20IndigoBlue02
My road bike:
Compact crank (50-34, Shimano 105) with 11-32T cassette (Shimano XT RD)
Cross bike:
Cross crank (46-36, FSA Omega) with 11-32T cassette (SHimano SLX RD)
My MTB 29er
Triple with 42T removed (iirc, left with 32-24T) with 11-36T cassette
Old August 30th, 2013, 16:29   #28
Nuje
I'm pretty comfortable with my 53/39 and 12-21 cassette, hardly ever use the 19 or 21 on the back. Most of the roads have at most a 6% grade around here, and I can power up that sitting without too much strain; once it goes to 8% and beyond (there are a couple roads around that have 8-12% pitches), I'm out of the saddle more than I'm sitting. And yeah - and 12%, I'm wishing for a 23 or even a 25 on the back.
I know that climbing while in the saddle is more efficient (going back to when I had the SRM PowerMeter cranks), but it feels good to get up out of the saddle occasionally, if only to prevent other body parts (more delicate than hands) from going numb.
Giant TCR Advanced SL with Dura Ace (compact frame design, size "medium" so it's a measured 50cm while my "normal" size is a 56cm).
Liked it so much (unbelievably smooth ride for a super-stiff frame), that after a couple years, I put the heavier wheels on that one and named it my rain bike, and bought a new TCR Advanced SL in the Medium-Large frame size (52cm measured, I think), which lets me stretch out and is just slightly more comfortable to ride. With Dura Ace drivetrain and some nice Bontrager XXX-lite bars/stem, as well as the Dura Ace C24 wheels, it rides 2-3km/h faster for me.
Old September 1st, 2013, 05:38   #29
NHgranite
NHgranite's Avatar
Steel is real. Espeshally when paired with Campy.
'12 Passat SE. 6MT.
H&R springs, FrostHeater.
NHgranite is offline   Reply With Quote
Old September 1st, 2013, 05:46   #30
Abacus
That helpful B4 guy
Abacus's Avatar
But titanium rides like steel without the weight and is more durable.
Biking at the Fest Metal Man TDIFest 2011 5 August 31st, 2011 00:29
PD130 Hybrid or PD150 Hybrid turbo? Which is better? CraigLovelock TDI 101 0 December 4th, 2010 08:19
Oregon considers taxing miles instead of gasoline; hybrid cars could threaten road up AZ06Jetta Fuels & Lubricants 48 January 6th, 2009 09:47
VW Tests Hybrid vs Diesel; Defers Hybrid RED TDI News/Tech 41 September 19th, 2004 19:51
All the talk of hybrid gassers, why not a hybrid diesel? Xanrel Non VW Group Diesels 4 May 13th, 2002 21:19
Page generated in 0.16796 seconds with 10 queries
[Output: 134.02 Kb. compressed to 112.17 Kb. by saving 21.85 Kb. (16.31%)]
