miketoth1979
Just wanted to quickly document a cool fix for handbrakes a fellow member tipped me off to!
I recently started a thread in the TDI-101 forum asking about an issue with my handbrake on my '01 Golf. The handbrakes were losing power but not due to the brake cable tightness.
Here is the thread:
http://forums.tdiclub.com/showthread.php?t=390254&highlight=rear+brake+question
Seatman suggested using these handy VW springs, used to release "sticky" handbrakes.
The part #'s for the springs are:
Left side 7H0615295A
Right side 7H0615296
So I ordered those springs ($5.10 each) from my nearest VW dealership in Ohio, and they had them for me the next day.
Installation of the springs took literally 10 seconds per side, once I figured out how they were supposed to be oriented.
RESULTS:
Wow.....amazing difference for such a simple fix. The lever on the rear passenger brake still doesn't return 100% to the top stop where it is supposed to be when the handbrakes are not activated, but it goes quite a bit further now with the help of these powerful little springs.
I have gained back a lot of power to my handbrakes. Was testing them out on some steep inclines yesterday and was able to hold in place with just the handbrake alone. Thanks for the suggestion, Seatman!
This may not be a permanent fix, as I suspect I will eventually have to address whatever is going wrong inside the rear brakes themselves, but it sure was a quick and effective fix for the time being!
Here is the thread:
RESULTS:
