Old July 27th, 2013, 20:18   #1
2hellWITHhybrids
Default A/C Blows Warm
2004 Jetta Wagon, 150K. A/C just stopped blowing cold air. Both fans spin, even when just the ignition is on, I changed one recently due to a bad bearing, but the A/C still worked for at least a month after doing so, therefore I don't think the fans are an issue. The clutch is engaging when I turn the A/C on and pressure reads fine. All fuses in the block and on top of the battery are fine. Before getting into measuring duty cycle on a bunch of random wires, I was just curious if there is a component known to go out around 150k on this year? Unfortunately I'm troubleshooting this on a broken leg, so I'd like to figure this out the easiest way possible. Thanks in advance for any input you guys may have!
2hellWITHhybrids is offline   Reply With Quote
Old July 27th, 2013, 20:33   #2
CopaMundial
Do both fans spin with JUST the ignition on... or do you need ignition on and AC on as well?
Welcome to the TDIClub forum. If this community forum helped you save money on a purchase or repairs, please consider donating just a small percentage of what you saved using the 'donate' link HERE. Donations keep the forum going. (note: I'm not affiliated with TDIClub or Fred... I just can't imagine the world without either of them)
CopaMundial is offline   Reply With Quote
Old July 27th, 2013, 21:01   #3
2hellWITHhybrids
Fans only spin when the AC button is pushed. When I turn the fan on 1-4 there is no fan movement (although air is blowing from the vents) until the AC button is engaged.
Old July 27th, 2013, 21:23   #4
gquenstedt
What do you mean the clutch engages and the pressure reads fine? If that were the case then it would be cooling.
Are you measuring high and low side pressures w/ the engine running and compressor engaged?
Check out my website: www.gqlaw.us
gquenstedt is offline   Reply With Quote
Old July 27th, 2013, 22:35   #5
DanG144
If your fans are on and your AC clutch is engaging, check your refrigerant pressures.
You may have an RCV (Refrigerant Control Valve) failure. This is very common.
Old July 28th, 2013, 12:01   #6
2hellWITHhybrids
Hooked some gauges up this morning and here's what my pressures read. The first is with the engine off, the second is with the engine running.
[IMG] http://www.flickr.com/photos/78174100@N06/9386941150 [/IMG]
[IMG] http://www.flickr.com/photos/78174100@N06/9384163803 [/IMG]
Any ideas?
Old July 28th, 2013, 12:30   #7
2many diesels
Your pressures' are way to low. You have 0 # on low side under vaccum. Should be in the 30-40 range. Take two cans of freon and call me in the morning.
2many diesels is offline   Reply With Quote
ac blows warm at stops... cold at highway speed laack VW MKIV-A4 TDIs (VE and PD) 1 July 22nd, 2013 17:56
Flashing Coolant Lamp/Chime, AC blows warm Moonlight VW MKIV-A4 TDIs (VE and PD) 34 June 13th, 2013 19:52
Diesel Blows Up All the Way... Joester General Automotive 13 July 17th, 2011 20:30
My 20005.5 Jetta blows warm air when cold is called for dae06 VW MKV-A5 Golf/Jettas 5 May 26th, 2011 05:11
warm weather warm TDI engine hard starting wpeets TDI 101 23 February 2nd, 2002 21:54
Page generated in 0.16228 seconds with 10 queries
[Output: 76.66 Kb. compressed to 66.50 Kb. by saving 10.16 Kb. (13.26%)]
