Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old July 21st, 2013, 19:43   #1
Dozenspeed
Dozenspeed's Avatar
Fuel Economy: $10,457 per TB change
Default MK6 Jetta Mileage/Boasting Thread
This is a simple data collection thread similar to others you may have seen scattered around the forums. Some are more formal than others, but among the many "mileage" ones within the various forums, the concept and intent often gets digressed and scattered.
Anyway I thought it would be cool to have our own MK6 Jetta "scorecard" in this specific forum. I lovingly refer to my poster child rendition as the "red-headed stepchild model" due to some sentiments from some of the long-timers, so here is a place to cheer on YOUR MK6 and show off their mettle!
ALL you have to do is: 1. Quote the very previous post that has the latest list, 2. Add your line in the format illustrated,* and 3. Delete the "[quote]" tags.
*Do not be intimidated by the formatting, make it easy on yourself. When posting the first time, I recommend simply copying the line closest to yours, pasting it where you need to put it, and edit that to reflect your data. Don't worry if you have too much trouble, someone here will likely ultimately fix it.
PLEASE try to put your data in mileage order, highest to lowest and under the correct year. It's just bit of careful copy/pasting.
The idea is to show how often the "worry items" are actually being needed. So if YOU just bought the car new, all the values are "1" -meaning "original, first one from factory" -for owner, TB, DPF, etc..... Warranty repair/defective replacement items DO count.
-Anyone from anywhere with an MK6 Jetta Sedan (in alignment with this forum's classification) can contribute, but please convert your kilometers to miles as necessary. Simply multiply your kilometers by 0.62137 OR use this handy converter: http://www.metric-conversions.org/le...s-to-miles.htm
Below is a legend for the color coding:
(Your Mileage) MI (Date of your posting/update) (Your TDIClub forum handle) V.: (Stands for Verson" -your vehicle's transmission type and package/designation, see acronym key below) Owner: 1 TB: 2 DPF: 1 HPFP: 1 EF: 3 FB: 1RB: 2 Note: (optional note section, within the single line is preferred)
MODEL PACKAGE/TRANSMISSION TYPE DESIGNATION AND COMPONENT ACRONYM KEYS:
6MT= Six-speed manual transmission
DSG= "Automatic" Transmission
USA MODELS:
BSE= "base" model package
PRM= "premium" model package
CANADIAN MODELS:
CL= Comfortline model package
HL= Highline model package
COMPONENTS:
TB= Timing Belt Replacement: Recommended every 120 thousand miles (should include H20 pump, rollers, hardware, etc)
DPF= Diesel Particulate Filter: Subject to habits of usage, this is in the exhaust stream, and collects oil ash volume until its capacity and then replaced
HPFP= High Pressure Fuel Pump: No specification on replacement interval, but a watchful eye is kept on this hot topic
EF= Exhaust Flap: No specification on replacement interval, but a not-uncommon issue that still isn't cheap
FB= Front Brakes: Yes, even if you do just pads, but sensibly should be a pad and rotor job
RB= Rear Brakes: See above. Basically these categories are just another a subtextual competition
ADDITIONAL NOTES: Many entires in the note section contain "IC TSB" -This stands for Intercooler Technical Service Bulletin and means it was replaced under "recall." Also, sometimes replacement items not in the basic 7 counting fields may be reported and mimic the tabulation style, but are extracurricular
For more information on any of the above items, please use the search function on the forums for thorough, quality answers rather than ask in this thread where they may not be seen.
****Always make sure to grab the LATEST post with Mileage******
Dozenspeed is offline   Reply With Quote
Old July 21st, 2013, 19:45   #2
Dozenspeed
Dozenspeed's Avatar
133280 MILES - Dozenspeed - Version: 6MT Premium -Owner: 1 -Timing Belt: 2 -DPF: 1 -HPFP: 1 -Note: original clutch and brakes
2012:
2013:
2014:
Do you have a MK6 Jetta SEDAN? (2011-2015) Contribute to our mileage thread here! Over 70 cars and 3.5 million miles of data!
Old July 22nd, 2013, 05:26   #3
Locnar
Locnar's Avatar
Fuel Economy: 41-ish
I hope this works. I might be one of the lowest in mileage after all is said and done...but it is my second MKVI - so there are 23000 miles unaccounted for.
2011:
2012:
2013:
6545 MILES - Locnar - Version: 6MT Premium w/ Nav -Owner Note: 2013.5 w/ soft dash
2014:
Locnar is offline   Reply With Quote
Old July 22nd, 2013, 05:43   #4
tjdeerslayer37
2012:
2013:
18,100 MILES- tjdeerslayer37- 6MT- premium no nav
2014:
6mt, Malone stage 2, diesel dubs 2.5" dp and resonator ceramic coated. Best tank 876 miles, 58.6 mpg
tjdeerslayer37 is offline   Reply With Quote
Old July 22nd, 2013, 07:55   #5
torrimac
36000 MILES - Torrimac - Verison: DSG LE - No nav
2012:
2013:
2014:
torrimac is offline   Reply With Quote
Old July 22nd, 2013, 16:41   #6
Dozenspeed
Dozenspeed's Avatar
Originally Posted by Locnar View Post
I hope this works...
Me too! Thanks for your contributions. Hoping to see some of the durability fields filled out too, it seems a little silly now being early on, but it will get more interesting as the cars get older.
Let's see some '12s....and who's gonna be first with a '14?
Old July 22nd, 2013, 16:44   #7
Dozenspeed
Dozenspeed's Avatar
133,500 MILES - Dozenspeed - Version: 6MT Premium w/o nav -Owner: 1 -Timing Belt: 2 -DPF: 1 -HPFP: 1 -Note: original clutch and brakes
36,000 MILES - Torrimac - Verison: DSG LE - No nav -Owner: - -Timing Belt: - -DPF: - -HPFP: - -Note:
2012:
2013:
18,100 MILES - tjdeerslayer37- 6MT- premium no nav -Owner: - -Timing Belt: 1 -DPF: - -HPFP: - -Note:
6,545 MILES - Locnar - Version: 6MT Premium w/ Nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Owner Note: 2013.5 w/ soft dash
2014:
Old July 23rd, 2013, 05:53   #8
SkeeterMark
SkeeterMark's Avatar
Fuel Economy: See Sig
36,000 MILES - Torrimac - Verison: DSG LE - w/o nav -Owner: 1 -Timing Belt: 0 -DPF: 0 -HPFP: 0 -Note:
2012:
2013:
18,400 MILES - SkeeterMark -Version: 6MT Premium w/o nav -Owner: 1 -Timing Belt: 0 -DPF: 0 -HPFP: 0 -Note: 2013.0
18,100 MILES - tjdeerslayer37 -Version: 6MT- Premium w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 0 -HPFP: 0 -Note:
6,545 MILES - Locnar -Version: 6MT Premium w/ nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: 2013.5 w/ soft dash
2014:
[URL="http://www.fuelly.com/driver/TDISkeeter/jetta"][IMG]http://badges.fuelly.com/images/sig-us/172184.png
Last edited by SkeeterMark; July 23rd, 2013 at 06:02. Reason: Edited for consistent entry format
SkeeterMark is offline   Reply With Quote
Old July 23rd, 2013, 06:26   #9
Dozenspeed
Dozenspeed's Avatar
^^^ Nice contribution, Skeeter. Just one thing: I intended to account the number of component you are on, so originals should be "1"- to match owner....note mine are all ones except the timing belt, I'm on my second, the only one I've replaced. (In my previous post I made a couple safe assumptions )
PS, I'll think you'll enjoy some of the stat porn I have on my cab I'll post elsewhere in the not-near future...I have a running count on all official passengers in the car's history, as well as all my car washing and service expenses from day one, for starters....
Anyone else besides me wonder if I have the bold parts wrong, or think this is too complicated?
Old July 23rd, 2013, 08:16   #10
pdt165
41,650 MILES - PDT165 - Version: 6MT Premium w/o nav -Owner: 1 -Timing Belt: 1 -DPF: 1 -HPFP: 1 -Note: Malone stage 1.5 Tune
2012:
2013:
2014:
LED bulbs in almost all possible locations. Aftermarket OEM Fogs. ESP Off Button. Malone Stage 1.5 Tune.
Micro-Can, Jupiter FL, PM me.
pdt165 is offline   Reply With Quote
Old July 23rd, 2013, 08:16   #11
pdt165
One stat that could be fun, assuming most have a fuelly account. adding avg mpg
Old July 23rd, 2013, 08:41   #12
DUDGY
DUDGY's Avatar
Question: Timing belt, DPF, HPFP are items that are replaced? I'm confused, Locnar you replaced all of those in 6000 miles? And tjdeerslayer37 you replaced timing belt withing 18k miles? Or am I missing something?
Good list I like your idea of this setup
DUDGY is offline   Reply With Quote
Old July 23rd, 2013, 09:05   #13
jetta12tdi
2012:
29,000 MILES - jetta12tdi - Verison: DSG Premium - w/o nav -Owner: 1 -Timing Belt: 0 -DPF: 0 -HPFP: 0 -Note:
2013:
2014:[/QUOTE]
jetta12tdi is offline   Reply With Quote
Old July 23rd, 2013, 09:36   #14
Cooperdb
Cooperdb's Avatar
Color me confused also??? some are denoting " 1 " next to componets and some have " 0 " so does 1 mean still original part or its been replaced once?? I think if you havent replaced it yet that zero makes more sense !?
Cooperdb is offline   Reply With Quote
Old July 23rd, 2013, 10:04   #15
pdt165
Based on what OP said, the number is what "item" you are on. Thus most of us are on '1' unless you have had them replaced meaning you would be on '2'
ALL:
I just made a new post and switched all the 0s to 1s assuming that is what was meantby the poster. I didnt mess with the existing 1's as it appeared those posters where thinking what the OP meant
AZNWHIP's 2011 CW Mk6 TDI Build Thread aznwhip VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 166 September 16th, 2014 19:35
May 2013 Mileage Thread Juergs TDI Fuel Economy 118 June 8th, 2013 15:59
The "What did you pay for your Mk6 Jetta TDI" thread ~Jb VW MKVI-A6 Jetta Sedan (~ 2011+) 126 November 8th, 2012 14:23
WTT: Portos (MK6 Golf) for Mambos (MK6 Jetta) dean_park Private TDI Items for Sale/Wanted 7 July 29th, 2012 18:59
May 2010 Mileage Thread Juergs TDI Fuel Economy 129 June 7th, 2010 05:02
Page generated in 0.22697 seconds with 10 queries
[Output: 144.15 Kb. compressed to 121.44 Kb. by saving 22.71 Kb. (15.76%)]
