Old November 4th, 2013, 17:03   #16
storx
i have nothing against hybrids, but most of the early builds of any kind of hybrid seem to fail.. i really hope this setup works for you as the upgrades for tdi's is still very limited to date. I wish more companies took interest in developing turbo's with better technology. I have a friend who had an procomp turbo on his car that started to smoke so he sent it in to have it rebuilt by procomp and they upgraded it to the new triple ceramic oil-less setup and when he put it on the car his spoolup increase 400rpms with zero change to the tune.
Da Diesel Build
storx is offline   Reply With Quote
Old November 5th, 2013, 12:04   #17
ibexlatham
ibexlatham's Avatar
Originally Posted by Kevinski4 View Post
I'd love to check this car out as the build progresses! I'm not too far away.
I'm sure we can arrange something, the turbo wont be in until spring as I dont have a garage so I'm about on "winter shutdown" and the car is my DD so working on it required taking vacation days for any larger project but I plan on having it in as early as possible in spring.... I usually take a few trips up to The Dells or Eagle River each summer so I can swing by on my way to one of those.
ibexlatham is offline   Reply With Quote
Old March 20th, 2014, 19:00   #18
ibexlatham
ibexlatham's Avatar
Just trying to stay relevant now that spring is near...
Also updating to a "build thread" to clean up my sig.
Old November 24th, 2015, 05:05   #19
DubOn937
Any updates?
Reflex Silver 2009 Jetta TDI - - Malone Stage 3 - -
DubOn937 is offline   Reply With Quote
Old February 16th, 2018, 15:06   #20
travis45
travis45's Avatar
This turbo is on its way to my house.... Looking forward to giving it a try. Any suggestions for setup are appreciated. How much boost you think she's safely good for?
14 Sportwagen TDI CR170 Frankenstien hybrid 2056 Turbo, Rawtek turbo back exhaust, Malone Stage 3, CP3 Fuel Pump, Malone DSG Tune, Panzer, 19" Konig Oversteer Wheels, Fluidamper Crank Pulley, H&R 22mm rear sway bar, PolarFIS. Soon to install Darkside intercooler and piping, Wavetrac LSD.
travis45 is offline   Reply With Quote
Old February 16th, 2018, 22:35   #21
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 300hp
You should of gone for a serious one
With all the mods you've done you went cheap on turbo
CP3 Upgrade
100-200 Acceleration
Macradiators.com is offline   Reply With Quote
Old February 17th, 2018, 05:50   #22
travis45
travis45's Avatar
I will at some point, it was a deal I couldn't pass up. Thinking I should be able to pull another 20-30 hp out of it for now with this turbo. Also, it's an easy bolt on. We'll see what happens...
Old February 17th, 2018, 10:59   #23
KERMA
KERMA's Avatar
IMO the turbo isn't the bottleneck but sounds like a fun project nonetheless
HP is for show, TQ is for go.
celebrating 15 years of: http://www.kermatdi.com
kermatdi on facebook
No, no, you're not thinking; you're just being logical. - Neils Bohr
KERMA is offline   Reply With Quote
Old February 17th, 2018, 13:48   #24
travis45
travis45's Avatar
What do you think the bottleneck is? Exhaust manifold? I wonder if EGT will be an issue...
Old February 17th, 2018, 14:38   #25
KERMA
KERMA's Avatar
the bottleneck is fuel. plain and simple
throwing ever bigger "stage" turbos at the same fueling will do very little to contribute actual results, other than maybe bragging rights for more turbo pressure. "I gots moar boosts than you"
Funny thing, but when we were dyno tuning the Double Eagle for the world record at Bonneville, it made more power with LESS boost. Not exactly what you might expect, but there it was. More power at 22 psi than at 25 psi, and the higher the boost, the power kept dropping off lower. More fuel, less fuel, etc, didn't matter. You could load up the dyno to keep the rpm in control then adjust the on the fly, adjust the boost up, power goes down, adjust the boost lower, power goes up. The answer then is to go bigger on the exhaust of course but then you start moving the map width higher in the rpm band. then play with gearing but I digress. There's always a tradeoff, regardless of what the part sellers may claim in this wonderfully efficient echo chamber we call the forums. Bigger is NOT always better.
but like I said, it would be fun to fool with it and see what you can get out of it. Might be something really special- you won't know till you try.
Old February 17th, 2018, 15:59   #26
travis45
travis45's Avatar
Oh, definitely will up fueling. Yes, more boost doesn't equal more power. If it can give me 20 some + hp I'll be happy.
Old February 17th, 2018, 16:03   #27
turbobrick240
turbobrick240's Avatar
Another significant bottleneck is the OE valve springs. They're pretty soft.
Old February 17th, 2018, 16:18   #28
travis45
travis45's Avatar
Head work with cams, valves and springs will be the next phase down the road.
Little by little... Thinking head studs Would be a good idea about now...
Old February 26th, 2018, 18:12   #29
travis45
travis45's Avatar
Well, she's in! Unfortunately, I had to swap the actuator, but I'm glad she's boosting! Here's the first log, going to drive it a bit on the Malone stage 3 and see how it does before fueling up!
http://log.malonetuning.com/chart/22...fCjwAAAA%3D%3D
Old February 27th, 2018, 15:47   #30
travis45
travis45's Avatar
Does this sound right? Surge?
https://youtu.be/ZcGXIy0Y0K0
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Audi A4R4 450HP CBEA (CR) Build TDIsyncro TDI Power Enhancements 934 October 13th, 2017 20:10
Project MK6 Golf TDI CR Build David@OttoStadt VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 16 August 27th, 2014 19:14
CR Build for power and mileage in kit car Whitbread TDI Power Enhancements 37 June 12th, 2014 16:40
400wtq 2.0 CR build? What will it take? Tortus TDI Power Enhancements 22 August 16th, 2012 09:44
lowering CR on franken-motor-build Grede TDI Power Enhancements 4 November 16th, 2011 22:17
Page generated in 0.15126 seconds with 10 queries
[Output: 129.61 Kb. compressed to 107.77 Kb. by saving 21.83 Kb. (16.85%)]
