Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Past TDIFests > TDIFest 2013
TDIFest 2013 Discussion about TDIFest 2013 on the Labour Day weekend (August 30th to September 1st, 2013) in Sunday River, near Bethel, Maine. Latest information in the TDIFest wiki.
Old July 22nd, 2013, 19:23   #16
AARodriguez Corp.
AARodriguez Corp.'s Avatar
Originally Posted by Savageman69 View Post
cant hate a guy for trying lol.
Not at all
AARodriguez Corp. is offline   Reply With Quote
Old July 31st, 2013, 09:33   #17
bassman5066
Hello, I have a 1Z engine swapped into a 91 Golf that already has a Malone Stg 3 and PP764 nozzles. Shortly after TDI fest, I will be pulling the head for replacement, and installing a Schweitzer S2A turbo with an air/water IC setup, and an upgraded cam (open to recomendations). Currently the ECU is set for 18 lbs of boost and was probably going to start somewhere around there on the new turbo since it will be flowing much better. I was looking to have my chip reflashed to work better with the new turbo setup, and was wondering what the price would be for a custom tune since I already have a Malone chip, and also would it be OK to drive the car 500 or so miles home with the stock turbo and cam on the custom tune?
Sent from my Bosch Motronic ECM via VCDS Version 1.9LVE
The MK2 Golf 1Z build thread
bassman5066 is offline   Reply With Quote
Old August 1st, 2013, 20:45   #18
AndyBees
AndyBees's Avatar
Just signed up may '84 Vanagon for a Stage 3! ....
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old August 9th, 2013, 23:08   #19
jay_fyp
jay_fyp's Avatar
haha NICE! I had an '80 Vanagon that unfortunately caught fire and burnt to it's demise in Florida on a road trip from N.J. to FL in 2000 when I was 21. I miss that van so much. It took me on many road trips throughout the country in my teenage years and early twenties.
jay_fyp is offline   Reply With Quote
Old August 10th, 2013, 05:43   #20
AndyBees
AndyBees's Avatar
Wow!
Well, back in '97, my '83 Air-cooled non-Westy burnt an exhaust valve. We were fortune to find a guy with a large garage that let me pull the engine tl do the repairs. (EDIT: in Alaska)
So, with the engine back in the vehicle, but still up on stands, I fired it up. In a matter of seconds gasoline was pouring out the bottom below the engine.
The problem: the pressure fuel line just above the transmission was almost "rubbed" through. So, apparently when I connected everything back in place, the line had a little more stress and ruptured right there.............. could have been on the road and ended up like your Van.
You need to find another one! ..........!
I really like my ALH powered Vanagon!
Old August 10th, 2013, 22:17   #21
jay_fyp
jay_fyp's Avatar
Wow!
You know, I kind of feel like that's what happened to mine. Mine didn't gush all the gas out, but I can remember after the last fill up on my tank of that vanagon before the fire, that I saw some gas on the ground and just chalked it up to overfilling, spilling, whatever the case may be. Next day, boom, catches fire after starting and driving not two minutes down the road, likely due to a spark igniting the fuel. After it happened and I researched it turns out it was a very common issue with them. Luckily I got that van on the cheap, and it well exceeded what I payed for it in the distance it took me. And yes I want another one badly, a nice diesel westfalia, wouldn't mind a vw bus westfalia either.
How many mpgs you getting with the ALH in yours and does it pull it? I can tell you SLOW was an understatement with my gasser Vanagon. Your'e gonna have the fastest Vanagon know to man after a Malone 3 tune! Awesome.
And sorry for blowing up your thread with Vanagon talk Newzboys! I will be a customer at TDIfest!
Edit (Just saw your mpgs in your sig) very nice!
Old August 11th, 2013, 08:22   #22
AndyBees
AndyBees's Avatar
Well, it hangs above 30 mpg. Seems I've hit 34 mpg on a few tanks. With the ALH engine (or any modern TDI engine), it is a must that the gearing of the tranny be addressed as well as wheel size (got to bring down those RPMs).
It runs really nice as is ........ have had a starting issue that seems to allude all logic.
Become a Malone Tuning Dealer - Custom Chip Tuning Mark@MaloneTuning Vendor & GroupBuy items for sale 2 June 8th, 2016 21:15
Malone Tuning by AARodriguez at TDIFest 2012 AARodriguez Corp. TDIFest 2012 4 August 31st, 2012 23:30
TD Tuning 10% Tune/Loader Pre-Order Discount! vwmikel Vendor & GroupBuy items for sale 6 February 9th, 2011 18:22
Only 72 hours left to pre-register for DATR, don't get left out! ssnapier Mountain/Southwest States 0 August 16th, 2010 13:50
How do I register for TDIFEST ? SyNtAxx TDIFest 2006 2 September 1st, 2006 08:30
Page generated in 0.13890 seconds with 10 queries
[Output: 88.42 Kb. compressed to 77.04 Kb. by saving 11.37 Kb. (12.86%)]
