Old December 3rd, 2017, 09:49   #106
gassprint1
TDI(s): 2006 jetta
i'm using an old dell studio 1737 with vista on it. from using the vcds, it seems like a simple dos base program that requires very little power to run it.
gassprint1 is offline   Reply With Quote
Old December 3rd, 2017, 16:35   #107
jef@rosstech
Associate Ross-Tech Vendor
From our FAQ 1.4
VCDS requires a computer running Microsoft Windows (the HEX-NET can be used with VCDS-Mobile on other platforms but that use is still in beta testing). A Laptop is most convenient but a desktop PC can also be used.
We recommend a PC running Windows 7, 8.1, or 10 with at least 2GB of RAM (single-core Atom�-class processors are no longer recommended).
http://www.ross-tech.com/vag-com/faq_1.php#1.4
XP was released in 2001. The last time XP was sold with a computer was about +7 years ago. In short, old computers are old computers. We do still have customers running VCDS on XP, but we do not support XP.
To that end, we do not do anything to prevent a Windows XP computer from running our software, so anyone can give it a go if they wish.
Jef blah blah blah
www.Ross-Tech.com
What should you do first with VCDS? AUTOSCAN!
jef@rosstech is offline   Reply With Quote
Old December 3rd, 2017, 17:16   #108
JSWTDI09
JSWTDI09's Avatar
In that case you should update your download page at Ross-Tech.com. The current download page for version 17.8.1 clearly states:
Release 17.8 works with Windows XP, Vista, 7, 8, and 10 (both 32-bit and 64-bit)
Have Fun!
Don
JSWTDI09 is online now   Reply With Quote
Old December 4th, 2017, 09:26   #109
Pat Dolan
Fuel Economy: 800km/1100km/tank
Thanks for all of the very informative answers. It turns out, my yank software was autoenginuity, and they have long ago updated it to run on 64 bit bus systems up to Windows 10.
I will probably buy another toughbook, but either running 7 or later. Wish I was skilled enough to do this in a Linux environment, but I guess I will have to struggle along in the Windows world where they never seem to get things right or stable.
A4=2003 TDI Variant, A3=Golf CL, A2=2x1.6 Jetta TDs, Golf Syncro Country, A1=Scirocco Mk1 & 16v, Audi 5000TD, Porsche 924/M471 and a bunch of diesel trucks.
Pat Dolan is offline   Reply With Quote
Old December 4th, 2017, 19:00   #110
jef@rosstech
Thank you for pointing that out, the info has been updated to reflect our current policy/standards/whims/wines/beers/sodas ect ect ect.
The page now states:
Earlier versions of Windows such as 2000, XP, and Vista might still work, but we no longer consider them supported.
Jef blah blah blah
www.Ross-Tech.com
Old May 4th, 2018, 22:13   #111
MrAsano
Fuel Economy: 40mph
Sorry to bring this post back from the dead
I own a 99.5 Golf TDI and I recently had the fuel injection pump gaskets replaced by a mechanic. I now know I need to adjust the IQ because the engine is shaking all over the place.
So here is my question. In order to use the VCDS to adjust my IQ, the only thing I need to do is purchase the connector (~$10) the and VCDS-Lite Software ($100)? https://store.ross-tech.com/shop/vcdslitereg/
I just want to make sure before I spend money.
MrAsano is offline   Reply With Quote
Old May 4th, 2018, 23:25   #112
gassprint1
TDI(s): 2006 jetta
chances are, that $10 cable isn't going to do anything but allow a generic scan. spend the 200 and get the proper setup to do everything. those generic cables are very much hit and miss ones....
Old May 6th, 2018, 14:43   #113
MrAsano
Fuel Economy: 40mph
Ok thanks I appreciate it!
Old May 7th, 2018, 08:23   #114
Mako
Check your MFD for the LPH display. When hot and idling set it to read .6/.7 LPH using the hammer mod. Of course this is a quick fix for anyone without VCDS. It's surprisingly accurate.
Mako is offline   Reply With Quote
Which VCDS Trimmy OBD Scanners 4 February 27th, 2013 22:22
MK5/MK6 VCDS lite vs VCDS Full?? storx TDI Power Enhancements 3 July 30th, 2012 11:15
VCDS or Not to VCDS, THAT IS THE QUESTION BRADFORDKO TDI 101 6 July 15th, 2011 21:21
used VCDS? ajbowman OBD Scanners 3 September 15th, 2010 18:06
Did I do this with the VCDS? Turbine Suburban VW MKV-A5 Golf/Jettas 1 August 9th, 2009 10:52
Page generated in 0.15896 seconds with 10 queries
[Output: 95.78 Kb. compressed to 82.35 Kb. by saving 13.43 Kb. (14.02%)]
