Old July 16th, 2015, 13:40   #46
noxorc
Originally Posted by Santos_V View Post
Hi Jed,
HEX+CAN is the only compatible interface.
Micro-CAN does not support the T'reg since its not based on the golf V/VI chassis. Here is a listing of Micro-CAN compatible vehicles
Need help, the Ross-Tech webpages don't say anything about 2015.
Which VCDS is compatible with 2015 Golf Sportwagen (MK7) ?
Thanks.
noxorc is offline   Reply With Quote
Old July 17th, 2015, 11:43   #47
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Try going to this page-
http://store.ross-tech.com/mm5/merch...een=RTAC&Tab=3
Old September 3rd, 2015, 07:36   #48
foodking
So I'm a little confused on what I should be buying from Ross-Tech. So here's the list of VWs my family owns,
B5 Passat TDI
mk5 Jetta TDI
mk5 Jetta TDI sportswagon
B6 Passat VR6
To support the B5 my brother drives, I'll need the HEX-USB+CAN.
I could be wrong, but I thought I read somewhere on these forums that the HEX-USB+CAN can't do everything on the 2005.5 and newer so a Micro-CAN is needed.
According to http://www.ross-tech.com/vag-com/Micro-CAN.php, the Micro-CAN "does not support Turbo Mode, the Clear All DTCs function or Activating/De-Activating Transport Mode. A HEX-USB+CAN is needed for those functions."
Does this mean even if I say screw you to my brother, I'm still stuck purchasing both?
In addition, where does the HEX-NET fit into this? does the HEX-NET encompasses both? The video mentions a cable included to plug the HEX-NET directly into a laptop, but their page doesn't mention a cable. Can anyone who purchased a HEX-NET confirm if a cable is included?
Sorry there are a lot of questions here. I just want to make 1 purchase that'll cover all my bases instead of back-tracking. Any help is appreciated.
foodking is offline   Reply With Quote
Old September 4th, 2015, 01:28   #49
Ol'Rattler
Ol'Rattler's Avatar
The Micro will cover all the newer CanBus cars. Add $100 more, to get the the Hex+Can and you include the older non CanBus cars back to 1996.
I don't need it, the Micro would have been just fine for my A5 Jetta, but I got the Hex+Can just to add compatibility for the older non CanBus cars.
If you purchase the $249 Micro or the $349 Hex+Can, both come with the cable you need that plugs into your laptop. Most likely, the only difference in the two versions is the license that is embedded in the cable.
I know very little about Hex+Net. I think it is just the next generation of VCDS that is a more expensive version that includes wireless capability and the ability to use VCDS on your smart phone.
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old September 4th, 2015, 05:31   #50
foodking
Thanks! that clears it up. I'm hoping to get a response from someone who has purchased the HEX-NET
Edit: A quick search on youtube reveals that the HEX-NET does indeed come with a usb cable.
Old September 4th, 2015, 14:15   #51
BobnOH
not-a-mechanic
If your not sure, just contact Ross Tech, they're very helpful (especially with sales).
With 4 Vdubs, it just might be worth the $350-400 it'll cost
Old October 6th, 2015, 22:25   #52
MalinoR
Fuel Economy: 43 mpg
Default Aren't there other options besides Ross Tech?
I'm a total newbie to TDIs, had a couple old MBs running on WVO, but nothing as sophistocated as these newer VWs. I bought it with 150K mi and the CEL on. I've had the codes read from AZ and Oreilly's several times now trying to track down my exhaust pressure and glow plug fault issues. I can see that I will need a VAG or OBD scanner of some sort.
I'm disappointed that this thread has only discusses the Ross-Tech product. I'm sure its great, but I'm not paying $350! Are there no other OBD-II software programs or handheld scanners that will do the job?
Specifically I know that I'll be replacing my exhaust pressure sensor(s) this weekend and have read that I need to program the car's computer to recognize the new sensor and that is done with a VAG com... have to input a code that the VAG com gives...I dunno. Will the Bosch scanner at Oreilly's do this? or is this only something that can be done with a VW specific product like the Ross Tech?
Sorry for the ignorance but I'm reading each night till 2 am trying to figure this out before the weekend gets here.
MalinoR is offline   Reply With Quote
Old October 7th, 2015, 06:54   #53
Lightflyer1
Lightflyer1's Avatar
There are but they cost way more than this tool. If you are going to work on your car you need VCDS. There are things which can't be done without a tool like this. Or will cost you more in time and money trying to fix or replace more parts than needed. One other option is if you have someone near you that has one and will work with you. Check the list. I do this quite often for people near me.
2015 Beetle TDI.
Old December 8th, 2015, 17:44   #54
JSWTDI09
JSWTDI09's Avatar
Originally Posted by 2009jettatdimk5 View Post
is there someone in near chicago area that can do some simple customs for me, like turn off the DRL's and horn when locked? I don't want to buy the VCDS, im on a budget. What other recommendations you got , if not..
According to this Vag-Com locator, there are 38 people in the Chicago area who have VCDS and are willing to help others.
http://www.maptive.com/ver3/VCDS_Locator
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old February 13th, 2016, 02:37   #55
pkhoury
That guy with the goats
pkhoury's Avatar
Fuel Economy: CR - 36-41, PD - 39-48 (26-32 while towing)
Have Fun!
Don
How can we add ourselves to the list? I recently upgraded to the HEX+CAN (before I resold my ALH).
pkhoury is offline   Reply With Quote
Old March 4th, 2016, 14:02   #56
leadfoot69
with the hex-can and 15.7 vcds will i be able to program a new key to my 2013 jetta or do i need something else to get code out like in my 2000 jetta i had?
thanks
leadfoot69 is offline   Reply With Quote
Old July 10th, 2016, 20:04   #57
Dimitri16V
Dimitri16V's Avatar
Just tried my HEX CAN USB on my new 2016 Golf , no go
I suspect I need the HEX NET interface for another $449 and limited to 10 cars
And there's no mention about being able to trade in your old interface
2004 Golf TDi 412K, 87 Rocco
2016 Toyota Corolla S
2016 Golf TSI ( reinforced metal oil pan , VCDS tweaks)
Aleksander Prokhorenko , Charles Keating ,Russian and US special forces KIA against ISIS. RIP heroes
Dimitri16V is offline   Reply With Quote
Old July 11th, 2016, 13:16   #58
BobnOH
not-a-mechanic
Contact Uwe at Ross Tech, he will give a better price if you bought from him in the past.
Try begging.
He may want your old unit.
Old July 11th, 2016, 18:09   #59
tadawson
Nope, HexCan should talk to anything . . . it's MicroCan that is limited.
tadawson is offline   Reply With Quote
Old July 13th, 2016, 18:53   #60
Dimitri16V
Dimitri16V's Avatar
I send them a scan of the car , it is only the engine module that is not recognized
Suggested a beta software release
Which VCDS Trimmy OBD Scanners 4 February 27th, 2013 22:22
MK5/MK6 VCDS lite vs VCDS Full?? storx TDI Power Enhancements 3 July 30th, 2012 11:15
VCDS or Not to VCDS, THAT IS THE QUESTION BRADFORDKO TDI 101 6 July 15th, 2011 21:21
used VCDS? ajbowman OBD Scanners 3 September 15th, 2010 18:06
Did I do this with the VCDS? Turbine Suburban VW MKV-A5 Golf/Jettas 1 August 9th, 2009 10:52
Page generated in 0.18242 seconds with 10 queries
[Output: 129.98 Kb. compressed to 108.69 Kb. by saving 21.29 Kb. (16.38%)]
