DanG144
Also a lot of talk about the TORQUE app for phones.
http://forums.tdiclub.com/showthread.php?t=378154
May be worth looking into.
Are you saying that the ScanGauge does not read coolant temp? or is it a requirement to buy additional software/parts to make it work?None of the 12 gauges on my SG would show coolant temperature. This FWT gauge is actually the ATF temperature. I had to add an X-gauge per the instructions on the Linear Logic web site. I named it XII, number 12, short for our G12 although that has been superceded G13, but I digress.
I agree, mine also read coolant temperature just fine, right out of the box, for my manual transmission.No, nothing new to buy. It reads water temp fine right out of the box for me. My manual ALH didn't require any fooling with. Adding X-Gauges are just a matter of entering the info into the Scangauge. Read about it on their website.
Something is not right, the dash gauge should be at 190*F starting at 165*F. Yes, Intake Air Temp is post-IC. The sensor is integrated into the MAP sensor, so it shows the air temp going into the intake. This is one of the parameters the computer uses to determine fuel and timing. You could wire a post-turbo/pre-IC sensor in to see how efficient the IC is in terms of temp and pressure drop.Further update on the ScanGauge II.
Coolant gauge in the car shows 190F sometimes as soon as when the ScanGauge has only reached 130F! I stays rocksteady on 190F even as the coolant temperature exceeded 240F as noted above. What kind of a joke of a gauge shows a rock steady 190F with a possible variation of nearly 100F?!?
The ScanGauge II is a "must have" for the TDi as far as I am concerned. The dash gauge is just a waste of space!
I'm monitoring coolant temperature of course as well as volts, boost and intake air temperature.
It looks like intake air temperature is after the intercooler. Anyone know if oil pressure is a possibility with the ScanGauge II on the TDi?
I can't say if the factory gauge is working or not. It shows cold at cold and pinned hot when it blew out. It's the "in between" that I doubt! ScanGauge works for me. It is now the gauge that I watch.Something is not right, the dash gauge should be at 190*F starting at 165*F.
I see you have an auto. Sometimes the SGII will read the auto tranny fluid temp on the water temp setting. There's some other setting or xgauge to get coolant temp?I can't say if the factory gauge is working or not. It shows cold at cold and pinned hot when it blew out. It's the "in between" that I doubt! ScanGauge works for me. It is now the gauge that I watch.
Where would the sensor go?Instead of spending $169 for Scanguage, you could have bought a temperature gauge from PepBoys for few dollars and hooked inside you car.
In the upper radiator hose near the engine using an adaptor mounted inline.Where would the sensor go?
