Orders TDI Club Cards TDI Fest 2009 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
User Name
Password
Upgrades (non TDI Engine related) The place of handling, lighting and other upgrades that do not relate to the performance or economy of the TDI engine. In other words upgrades to your TDI that don't fit into fit into TDI Fuel Economy & TDI Engine Enhancements.Please note the Performance Disclaimer
Thread Tools Search this Thread
Old November 22nd, 2002, 08:35   #406
hugemikeyd
Default Re: MFA Cluster Conversion! Pictures!!!!
OK so here is another question to add onto a post a few pages back...
The letters at the end of the cluster part number represent different engines and such and the only one explained are that C is for Diesel, what about B? I already know that A is for gas so what could B be for?
hugemikeyd is offline   Reply With Quote
Old November 22nd, 2002, 09:01   #407
weedeater
top speed on the speedometer. B is 140MPH. C is 160 MPH. Both have the tach redline for the diesel (4500-5000).
weedeater is offline   Reply With Quote
Old November 23rd, 2002, 09:52   #408
hugemikeyd
So about that B thing, my cluster has a redline of 6500 and it goes to 160 MPH...
Old November 23rd, 2002, 10:28   #409
Michael Moore
That tach redline of 6,500 should be considered as a pretty strong hint that you don't have the correct part number of cluster for your car... assuming your car has a diesel engine in it.
Michael Moore is offline   Reply With Quote
Old November 23rd, 2002, 16:18   #410
hugemikeyd
well i have a 1.8T, which is gas, but the cluster is supposed to go with a Diesel you tell me. Is there any chance i can get this thing to work in my car?
Old November 23rd, 2002, 20:57   #411
tongsli
Where did you buy it?
Lito
tongsli is offline   Reply With Quote
Old November 23rd, 2002, 21:26   #412
weedeater
sure, what's the part number?
Old November 24th, 2002, 18:24   #413
hugemikeyd
i bought it off of a member of the VWVortex forums. He said that he bought this one (MPH) and another in (KMH). He liked the KMH Euro look better and stuck with that one.
As for the part number, i have 2. The one on the sticker on the outside is: 3B0-920-927B
But VAG-COM reads: 3B0-920-926BX
I think my car needs an A, but i don't have an A...
Old November 25th, 2002, 20:58   #414
tongsli
According to the catalog, that cluster is for a Passat.
I doubt the cluster harnesses are identical. The harnesses could be the same, but the pin assignments need to be checked out.
Do you have a Bentley's manual?
Anyone here have the pin assignments for a Passat???
PTC, you out there?
Lito
Old November 26th, 2002, 10:51   #415
hugemikeyd
I know its for a Passat, this is an attempt at making my car different from everybody elses. [img]images/icons/wink.gif[/img]
Somebody told me that the pin outs are the same. All i know is that the harnesses are correct and when i plug it in and turn my key, the Immo light blinks (expected) but the Brake light also blinks and there is nothing in the manual about that. When i use VAG-COM to check out what might be wrong it gives me an error:
00779 Vertical Motion Sensor (G90)
Open or Short to B+
Then i found out that that might not be the error that i have, it should say:
Ambient temperature sensor -G17-
Open/short circuit to positive
Short to earth
That is supposed to guve me dashes for a temperature, which is what i have b/c i still need to install the OAT sensor. What the hell is going on? LOL
Old November 27th, 2002, 00:49   #416
tongsli
Well,
You're definately forging new territory here.
<font size="2" face="Verdana, Helvetica, sans-serif">Maybe the person who told you this can help you out.
Good luck,
L
Old November 27th, 2002, 00:57   #417
Birdman
Until you Put the proper sofeware coding into it all kinds of warning will come up.
Birdman is offline   Reply With Quote
Old November 27th, 2002, 06:17   #418
KOMET155
to verify the pin outs compatibility, you might want to look in the passat and golf bentley manuals at the diagrams for these connectors, and compare the 2, pin by pin....
KOMET155 is offline   Reply With Quote
Old November 28th, 2002, 10:47   #419
hugemikeyd
I have the entire pin out from the Golf/Jetta, i think they were posted in this forum actually, but does anybody have the pinout for a Passat Cluster? This would be greatly appreciated. This Passat cluster offers more options than the Golf/Jetta cluster like miles until empty. It also looks just like the the Euro Sport cluster just without the silver fill ins. I think it looks great. Well thanks to all that have helped me and those who might help me in the future and have a great Thanksgiving!
Old November 28th, 2002, 16:27   #420
MOGolf
MOGolf's Avatar
Not knowing which Passat cluster (there are 3 AHU engine versions that I have info about) the possible pin-outs are...
Blue connector:
1-Terminal 15, positive
2-Turn signal right
3-Speedometer signal out
4-Warning Lamp Trailer towing
5-Fuel gauge
6-Airbag/ground w/o airbag/vacant
7-ground (sender circuit)
8-Coolant temperature
9-ground
10-Oil Pressure
11-Speedometer signal/MAF #3/vacant
12-Alternator warning
13-backrest lock/glow plug period warning/vacant
14-rear fog
15-vacant
16-open tailgate or boot/vacant
17-Warning lamp main beam (high beams)
18-Turn signal left
19-ABS
20-Illumination
21-Driver door open/vacant
22-vacant/coolant low
23-Terminal 30, positive
24-ground
25-K-wire
26-Parking light right
27-Parking light left
28-Speedometer signal in
29-Brake fluid level
30-S-contact
31-Seat belt warning
32-Emissions warning/vacant
Green Connector
1-vacant
2-Immobilizer read coil 1
3-vacant/warning lamp for side lights/vacant
4-CAN bus signal screening
5-W-wire
6-Washer fluid
7-brake pad wear
8-External buzzer/vacant/CAN-High for Conv. system and central locking
9-External gong/vacant/CAN-Low for Conv. system and central locking
10-Fuel reserve warning/vacant
11-Vehicle stationary signal
12-AC cutoff signal
13-Hand brake
14-Traction control
15-vacant
16-vacant
17-Immobilizer read coil 2
18-vacant/Oil temp and level
19-vacant/CAN high in
20-vacant/CAN low in
21-vacant
22-vacant/bonnet switch
23-MFA switch down
24-MFA switch up
25-MFA reset
26-Ambient air temperature
27-vacant/CAN high out
28-vacant/CAN low out
29-vacant/CAN shielding
30-speedometer out/vacant/Radio-Navigation clock
31-Selector lever display/vacant/Radio-Navigation data
32-Fuel consumption/vacant/Radio-Navigaion enable
If there is a 20 pin Red connector
1-4 vacant
5 Telematic Shield ground
6-11 vacant
12 Radio-Navigation clock
13 Radio-Navigation data
14 vacant
15 Radio-Navigaion enable
16-20 vacant
The 1Z is a different beast.
MOGolf is offline   Reply With Quote
Search this Thread:
Advanced Search
vB code is On
Powered by vBulletin Version 3.5.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
© 1996 - 2007, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.08984 seconds with 10 queries
[Output: 90.72 Kb. compressed to 84.02 Kb. by saving 6.70 Kb. (7.38%)]
