| Upgrades (non TDI Engine related) The place of handling, lighting and other upgrades that do not relate to the performance or economy of the TDI engine. In other words upgrades to your TDI that don't fit into fit into TDI Fuel Economy & TDI Engine Enhancements.Please note the Performance Disclaimer |
July 11th, 2002, 21:59
#1
Lift pads for Audi TT fit the JETTAS, GOLFS, New Beetles and Passat B4\'s!!
I was looking around in ETKA. Found this with the Audi TT.
Does anyone think this would fit our cars??
Lito
[ July 27, 2002, 16:04: Message edited by: tongsli ]
July 12th, 2002, 07:22
#2
Re: Lift pads for Audi TT fit the JETTAS, GOLFS, New Beetles and Passat B4\'s!!
That looks identical to the ones I bought from SchnellTDI. You need both the #30 rubber part (bracket) and the #31 plastic insert (carrier). There were no part numbers on the ones I bought.
July 12th, 2002, 20:20
#3
Thanks 63Ragtop. I will post some pics once I get them. I ordered them today. They're NOT expensive.
But let me first get them, post some pics and maybe you can tell me if they are identical to yours??
I'm hoping that since the Audi TT is based upon the Golf platform, that the hole in our Jettas and Golfs are identical. If they are, these should work. Let's hope so.
Thanks,
Lito
[ July 12, 2002, 20:23: Message edited by: tongsli ]
July 16th, 2002, 11:23
#4
I assume these lift the suspension? Above or below the coil spring? I would be VERY interested in a set. How much lift do they provide?
July 16th, 2002, 15:41
#5
Fuel Economy: 53.7/45.4/40.3
<font size="2" face="Verdana, Helvetica, sans-serif">No, the idea is to provide a cushioned point to place a jack as to not damage the frame or bodywork while doing maintenance.
MCA
July 16th, 2002, 16:25
#6
Fuel Economy: 53/46/34 with bad injector and MAF
Lito,
How inexpensive are these?
Others might be interrested if they can order it from their local for cheap.
July 17th, 2002, 09:46
#7
Oops? [img]images/icons/blush.gif[/img]
Thanks for the correction.
July 17th, 2002, 15:08
#8
E-volved,
From Impex, they're just $20.00 for all four. I am getting mine in a day so I will FIRST verify that they fit our cars too.
Check back for pics here.
Lito
July 18th, 2002, 13:44
#9
July 18th, 2002, 20:07
#10
Yes.
You just don't have the nice informative card telling the mechanic that they're there and can be used for lifting purposes.
July 18th, 2002, 20:18
#11
Hey Glen.
Of course it'd be you responding first to my post [img]images/icons/grin.gif[/img] I can always count on you [img]images/icons/smile.gif[/img]
Well, can someone explain how to remove the OEM plastic covers underneath where these go?
I've listed the part numbers, and they'll only cost you $20 plus shipping from Impex.
thanks,
Lito
July 19th, 2002, 06:03
#12
Fuel Economy: you keep track?
To remove the plastic covers - peel em off [img]images/icons/grin.gif[/img] or pok a hole through them and peel em off.
The best way to get em in is to use a floor jack and a 27mm 1/2" socket stuck in a 2 ton hydraulic floor jack.
Pop right in.
although they don't work so smooth with the 2 ton jack the recess on the jack isn't good - need to fill the hole in the jack (i used a nice peice of 2x2 with corners trimmed grain verticle).
I use them quite a bit - seem to be good - although I noticed on my set the VW stuff was ground off (IE the logo)!
July 19th, 2002, 07:09
#13
top post dawg
Lito, nice pix as always!
Do I need to order 4 of Part #30 and 4 of Part #31 as shown in ETKA?
thx
July 19th, 2002, 07:55
#14
Just peel out the plugs with your bare hands and fingernails. The rubber part must be completely seated before you put in the plastic one. You will be able to easily twist the rubber part in the hole if its seated all the way.
Yeah, yours look a lot nicer without the part numbers ground off. [img]images/icons/grin.gif[/img]
July 19th, 2002, 08:03
#15
Yep... dems da ones! Nice work, as usual, Lito. What would we do without you, your digital camera, and your ETKA? [img]images/icons/cool.gif[/img]
-Mel
