Old February 20th, 2017, 09:56   #151
UhOh
UhOh's Avatar
Originally Posted by benchlands_tdi View Post
Completed most of the wiring, and just waiting for some harness parts to come in.
One question, on the wiring diagrams, does the "30 unswitched power" refer to the "30" or the "30A" power source?
What wiring are you referring to? I didn't see what approach you're taking.
As an update to my quest, I just picked up a complete 2000 Jetta that has only 118k miles (gasser w/bad engine): paid $400. The car is immaculate. Seats, just what I wanted- beige, cloth heated (exact same pattern), are in excellent shape. Seller (it was his daughter's car) says that the driver's seat heater wasn't working- I figure I can resolve this.
I plan on using this wire harness:
https://www.kufatec.de/shop/en/retrofits/seat-accessories/seat-heating-harness-vw-audi-seat-skoda
Old February 20th, 2017, 12:10   #152
benchlands_tdi
Sorry for the confusion, I'm using this diagram and referring to the power sources noted near the bottom of the diagram ("30 unswitched power").
Originally Posted by oldpoopie View Post
Ok, I think the bently diagram is confusing. Too much info for what I need. I've put together this diagram to simplify things. Let me know if I've made any errors.
benchlands_tdi is offline   Reply With Quote
Old February 20th, 2017, 17:19   #153
ToddA1
Fuel Economy: Dismal
No clue what 30A means, other than 30 amps.
30 is a constant 12v power source. As the diagram mentions, it's unswitched.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old February 20th, 2017, 19:22   #154
benchlands_tdi
Right. So on the power studs under the dash, there is a "30" and a "30A".
Which one should I use to draw power for the heated seats? I'm using the wiring diagram shown on post 152. Thanks.
Old February 21st, 2017, 03:13   #155
ToddA1
In this case, it appears it's just a separate feed from the battery. I'd confirm with the Bentley, and if so, choose whichever.
-Todd
'97 B4: Stock
Rabbit build
Old May 2nd, 2017, 14:38   #156
UhOh
UhOh's Avatar
Managed to tear into the driver's seat after finding that the thermistor circuit tests "open." Most seem to state that it's the thermistor wires that break, but having the seat apart I'm not seeing any signs of breakage:
I cut just to start tracing the wires. Hard to see, but the wires seem perfectly fine, though who is to say whether they couldn't be broken inside the insulation (I've read that they tend to break out-right). I'm hesitant to cut up any further unless I'm certain that the thermistor is shot: I'll be cutting right over the elements themselves. Not certain how the wires connect down below; seem to disappear into some clumps of black glob-y material, which I'm also a bit hesitant to mess with.
Old May 2nd, 2017, 16:10   #157
SilverGhost
SilverGhost's Avatar
-Todd
I know this is old post, but that does NOT mean 30 amps. DIN standard wiring in German cars 15 is switched ignition, 30 is battery +, 31 is ground, 75/x is load reduction (aka accessory).
In this case 30a is a secondary battery feed.
Jason
SilverGhost is offline   Reply With Quote
Old May 2nd, 2017, 20:49   #158
ToddA1
I'm familiar with German wiring, but based on the diagram provided, there was no "30A", which was confusing. My response included:
Jason
Once the pic was posted, it added clarity, which I replied:
-Todd
'97 B4: Stock
Rabbit build
Old May 3rd, 2017, 10:58   #159
SilverGhost
Sorry, ToddA1. I meant to quote the post after yours. I'm not sure how I managed to screw that up.
Jason
Old February 22nd, 2018, 21:09   #160
UhOh
UhOh's Avatar
Following up to my previous post above (#156), I sliced further down and found one of the wires to the thermistor broken. All has been back together and working in my car for some time now (awesome this winter!). It's looking like I now need to do the same repair to the driver's seat in the wife's car (which is what brought me back here). I had thought that I'd seen someone do such a repair in-car, popping the back of the lower seat cushion loose, but have been unable to find (just to verify that it does work, that it's the same style of seat); if anyone is familiar with that info (not sure if it was on this site or not- thought it was) I'd appreciate any tips to where I can see/find it.
Page generated in 0.25525 seconds with 9 queries
[Output: 99.58 Kb. compressed to 84.86 Kb. by saving 14.72 Kb. (14.78%)]
