Old December 22nd, 2002, 14:29   #1
VWflappie
Default Heated seats.......
This saturday i have installed soem heated seats in my car (mkIV Golf TDI 81 Kw). The only thing is that the seat on the passenger site workks great, and somehow i cant get the drivers seat to work. Does anybody know how i can check out the internal wiring of the seat??, and maybe find out what is broken (backrest or seat??)
VWflappie is offline   Reply With Quote
Old January 8th, 2003, 14:59   #2
BRBarian
Default Re: Heated seats.......
Do a search...
http://forums.tdiclub.com/cgi-bin/ul...9&t=000982&p=2
BRBarian is offline   Reply With Quote
Old October 4th, 2003, 08:31   #3
G60ING
G60ING's Avatar
Ok I've done a fair amount of searching for topics that went into specifics about retrofitting heated seats to cars that did not come with them. I've been down this road before but it was on my old Subaru Impreza I bought a Corrado so I could strip the heated seats harness and elements since I was framilar with the wiring. From the searching I've found a few links to old topics with broken links. I'll tell you what I have:
Seats:
The switches and plugs:
This information from the Vortex listed by Boraguy01:
[ QUOTE ]
its actually pretty easy....ill give u a simplified version
parts needed
1 X 1J0-963-563 (drivers side switch)
1 X 1J0-963-564 (pass side switch
2 X 8L0-971-972 (these are the "switch-connector" that have 6 terminals. They plug into both the pass and driver switches) 2 X $3.68 = $7.36
2 X 1J0-937-731 (green plugs that plug into the seats themselves)
1 x 000 979 407 6 mm Repair wire - $5.40
3 x 000 979 227 2.5 mm Repair wire - $2.35 x 3 = $7.05
4 X 000 979 135 1 mm Repair wire - $1.75 x 4 = $7.00
directions
1) on the "switch-connector" there are 6 connectors (ill name them as they are numbered on the "switch-connector")
terminal 1 powers switch backlight when lights are on
terminal 2 + connection (goes to seat plug). It plugs into seat green plug terminal 4
terminal 3 heat sensor connection (goes to seat plug) It plugs into green seat plug terminal 2
terminal 4 + connection (goes to fuse 44, use 7.5amp fuse if only 1 seat is being wired or use a 15amp fuse if you are doing both seats......on the other end of the fuse--->goes to unswitched power (connection 30 under the relay plate)
terminal 5 goes to (any fuse spot u can find empty and use) then to switched power (connection 75x under the relay plate
terminal 6 Ground (you can use the ground terminal for the intruments thats right below the steering wheel)
------green seat plugs------
on the green seat plugs there are 6 connections, only 4 are used....2 of which i already stated above, the 2 other are ground which are in terminal 1 & 3....again u can ground this to anything.
here is a picture of the relayplate power sources u will be getting power from
***i got this from john@abella.net, thanks***
[/ QUOTE ]
I can handle the running of wires and doing all of this. But my goal is to not use scotchLock wire taps and Boraguy01 has got me started on the path of not using these connectors so
My question/s:
1) For the illumination where are people tapping in and what should I use?
2) The instructions listed above tell me where to get constant power from but seems a little vague on the fuse area. Do I need any dealer repair wires to activate this?
3) For the switched power wire It tells me where to go but not what wire I'll need.
I plan to take pics of the specific wire connections as they go in the fuse panal so people can in the future have a little more straight forward how to.
Any help is appreciated. Thanks. Frank [img]/images/graemlins/smile.gif[/img]
G60ING is offline   Reply With Quote
Old October 4th, 2003, 09:42   #4
OilBurnerDE
Uh-oh....
Frank is here......... [img]/images/graemlins/eek.gif[/img]
Sup' Frank?
For my the haraness in my Passat, it only has 3 connections/wires. Power, ground, illumination.
I thought about doing it the factoy way. But I'm not sure if I want to drop the fuse panel to do it.
Pep Boys sells a ciruit add-on for about $7. It plugs into a fuse slot. I might try this out.
Ground is easy, plug it into the available ground block.
Illumination:
I wired up the boost gauge light by tapping into the illumination lead on the radio harness (not being used) I just might tap off of that.
The car also came with a harness for heated washer nozzels.
I might just install that as well, but it will involve more work. But at least I can install my blue LED lighted washer nozzels at the same time yo..... [img]/images/graemlins/rolleyes.gif[/img]....
With the 35 degree temps we had the last two mornings, I should get the seats working soon.
Heck I still need to install the interior that I ripped out chasing a water leak. [img]/images/graemlins/crazy.gif[/img]
OilBurnerDE is offline   Reply With Quote
Old October 4th, 2003, 12:24   #5
G60ING
G60ING's Avatar
yuppers I'm here. Hell I've been lurking for a good amount of time. But I'm thinking I can hold out for the proper pin connections to the fuse panel. But if it gets too cold I'll do it the quick and simple way. But you know I seldom choose the quick-N-simple route [img]/images/graemlins/tongue.gif[/img]
Old October 4th, 2003, 16:12   #6
will360655
TDI(s): 2007 Passat
Fuel Economy: 16/16/16
You can tape that from the dimmer switch, you just have to find the right wire, there are 3.
You use the 75X power (I think) then you use a repair wire to locate is into the fuse panel, then out.
You should use a fuse, I didn't locate my fuse in the fuse box, just an inline fuse...actualy i don't even think that I used a fuse. Should use a fuse though.
I will double check some part numbers, just to make sure, but I don't have my paper work handy.
Will
will360655 is offline   Reply With Quote
Old October 4th, 2003, 19:33   #7
tongsli
Get a copy of the Bentley's manual. Everything you need to know is in the wiring diagrams.
tongsli is offline   Reply With Quote
Old October 4th, 2003, 19:36   #8
tongsli
[ QUOTE ]
[/ QUOTE ]
Flappie,
I'd try another switch before I'd open up the seats. I bet it's the switch. Is it new? Do you have a spare?
Old October 5th, 2003, 17:10   #9
danix
danix's Avatar
Do NOT just take power from the radio or something like that, as the current draw on the seats is significant.
You can tap the dimmer wire on the adjacent dash switches, and look at the Bentley for the correct way to draw power, using factory repair wires and the proper fuses.
The wiring is simple but tedious given the amount of work in disassembly.
danix is offline   Reply With Quote
Old October 5th, 2003, 22:02   #10
tongsli
Wiring Diagrams 2003 Jetta Heated Leather Seats
Old October 6th, 2003, 05:41   #11
OilBurnerDE
[ QUOTE ]
[/ QUOTE ]
I guess this is directed to me. I agree do not use the radio harness for power to the heated seats.
I only tapped into my radio harness for the illumination of my boost gauge and for the dimmer lead on my new Head unit.
I will probably use the same lead for the heated seat switch illumination because it is convienient and the radio harness is not in use. I'd rather limit the amount of modifications to the stock wiring, if at all possible. Having one central source helps me stick to the KISS principle.
Old October 6th, 2003, 07:14   #12
oldpoopie
oldpoopie's Avatar
Lito, are you able to give me an ammended list of repair wire parts to hook up my seat heaters? I believe the above list is short a few wires.
-J
Old October 6th, 2003, 07:42   #13
G60ING
G60ING's Avatar
I should be hooking up the seats in the next week or two. With the help of the skematics I think I have it under control. While I'm doing the install I will keep track of the repair wires and even take pics. I plan to use all of factory wire connections.
Old October 6th, 2003, 09:43   #14
tongsli
All of the dash switches will look similar to this one. The blade is typically the same width.
The repair wire is the 000979135 listed above
Here are some more, from left to right: 000797135, 000979133,000979131,000979008
This copper wire connector is used in the relay plates:
000979114
Old October 9th, 2003, 11:22   #15
Boraguy01
Hey guys, ive been wanting to sign up here but never got around to it. MAybe this might help the guy whos trying to install his heated seats. To power the icon lights at night i just tapped a wire from the heated seat switch over to the hazard light switch. Just take one of the wires and stick it into the right terminal in the back of tha hazard light switch, if you take the switch out it will be obvious which one to tap into. ANything else let me know or email me and ill try my best to explain
Boraguy01 is offline   Reply With Quote
Page generated in 0.21596 seconds with 9 queries
[Output: 123.79 Kb. compressed to 103.71 Kb. by saving 20.08 Kb. (16.22%)]
