Old October 7th, 2017, 17:10   #76
Motohead1
Originally Posted by fjdiesel View Post
Andybees I see it has been over a year ago since you referenced the VSS wiring for the cruise control function. Did you or anyone make that work? Or can you just put the VSS signal directly into the ecu if your conversion is not in a vw?
zspace I sent you a pm also. Thanks
Originally Posted by oilcan_boyd View Post
I am also interested in getting cruise control to work. I took the Jeep on a 1000 mile round trip and my right leg got a little cramped up.
The VSS is covered in several builds but to recap. You need a valid brake switch/ signal. and a VSS pulse. The VW is 8000ppm signal. Dosent have to be exactly that ppm but its nice to have speed match up for logging. HTH
Motohead1 is offline   Reply With Quote
Old October 14th, 2017, 04:10   #77
k_pt
TDI(s): golf 4
has anyone found out how to wire t88?
k_pt is offline   Reply With Quote
Old October 19th, 2017, 00:39   #78
superhl
Default pictures
vduspeed,
Could you email me these pictures? I am in the process of converting 1992 isuzu pickup to 2002 vw TDI diesel? I can't open these images. Thanks
superhl is offline   Reply With Quote
Old November 21st, 2017, 19:01   #79
jhax
For the cruise control, in my research, I have found that ECU (T121/20) SEEMS like it is for cruise control, the AHU/1Z equivalent is T60/43 on the ECU. If you are using a MK3 gauge cluster, ECU PIN 43 goes to W/1 on the CE2 fuse box and out of the fusebox at U2/2 "Speed Sensor" on the a2resource website. So if I am correct, and if you are using a MK3 cluster/fuse box ALH ECU (T121/20) goes to W/1 and then to the speed sensor in the cluster.
jhax is offline   Reply With Quote
Old December 20th, 2017, 19:01   #80
OregonBricky
Does anyone have these photos from the original post saved? None of them show up for me. Looks like their no longer being hosted.
OregonBricky is offline   Reply With Quote
Old December 20th, 2017, 19:02   #81
dremd
dremd's Avatar
I have them printed in my glovebox, I’ll get them to you when I get back to my TDI probably Friday
2013 Nissan LEAF what are these emissions you speak of?
03 Silver Premium Jetta Wagon lots of OEM goodness. 1.8T Triptronic eliminated, ALH + 6 speed manual installed in place. Emissions? Yes, a lot
2006 Sprinter long range hauler, 300+ cubic feet loaded 25 mpg.
2014 JSW (Went back to VW) Emissions? Well, about that . . .
dremd is offline   Reply With Quote
Old December 20th, 2017, 19:06   #82
OregonBricky
Originally Posted by dremd View Post
I have them printed in my glovebox, Ill get them to you when I get back to my TDI probably Friday
Awesome thank you!
Old January 1st, 2018, 08:14   #83
dremd
dremd's Avatar
Old March 16th, 2018, 05:40   #84
Bolts-n-Hose
TDI(s): TDI
Can someone confirm what I think may be an error on the diagram above? It appears to me that (at least for my 01 Jetta) the red/purple shares the 30 amp constant 12v fuse with the main power to the ECU. This diagram shows this 30 amps being switched off of relay 109.
Bolts-n-Hose is offline   Reply With Quote
Old June 19th, 2018, 12:55   #85
DominicTheMadman
DominicTheMadman's Avatar
TDI(s): 1.9 ALH
Default Without this thread...
Without this thread, I would not have been able to do my ALH swap! Thanks a million!
DominicTheMadman is offline   Reply With Quote
Old September 7th, 2018, 09:21   #86
AndyBees
AndyBees's Avatar
I realize this is a late response ....
Bolts-N-Hose, yes, the circuit that goes through 14a/5 is switched via the 109 Relay as shown in the diagram in this Thread. The fuse in question is #32 in the original application.
My notes, Bentley, etc., confirm it and that's how I installed it in my conversion.
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old September 9th, 2018, 14:43   #87
blkhatsilhouette
Hey everyone, I'm in the middle of swapping an '00 ALH/5 speed into an '03 1.8t/automatic (both were jetta's).
I'm having trouble with the T14a connector that the pin out is shown on this thread. In the 1.8t jetta, I'm missing pin 3 (green) and pin 10 (black with green stripe).
On the harness that was in the 2000, it has these wires, and I traced them around on the hacked up harness for comparison.
I know that pin 3 of this connector should go to pin 28 on the blue connector of the instrument cluster. I don't have the green wire on the T14a connector, but there is a green wire in the blue connector of the instrument cluster... where does that green wire go to on a 1.8t?
I also see on the diagram that pin 10 should go to the load reduction relay. I traced this black/green stripe wire to fuse 10 (small fuses) on the 2000 wiring, but it doesn't seem to exist on the 1.8t. The bottom blade of the load reduction relay traces continuity to fuses 20, 21, and 36 on the 1.8t, but those also exist on the TDI, so I need that extra wire...
Any input would be greatly appreciated!
Thanks!
blkhatsilhouette is offline   Reply With Quote
Old September 9th, 2018, 19:12   #88
Runninwild
Runninwild is offline   Reply With Quote
MK4 ALH alternator pinout? A4-TDI TDI 101 9 April 27th, 2013 20:43
68 pin 98 jetta TDI pinout Goldguru VW MKIII-A3/B4 TDIs 13 April 25th, 2011 03:23
"THE" ALH pinout? onlyn8v TDI Conversions 3 March 6th, 2011 09:19
98 TDI pinout 98GTDI OBD Scanners 0 November 27th, 2005 08:04
TDI-ECU Pinout RonnyH VW MKIV-A4 TDIs (VE and PD) 0 January 27th, 2001 15:05
Page generated in 0.15000 seconds with 10 queries
[Output: 113.94 Kb. compressed to 95.96 Kb. by saving 17.98 Kb. (15.78%)]
