Old August 10th, 2013, 18:29   #46
AndyBees
AndyBees's Avatar
I've prepared my notes and schematics from working notes, etc., to "as built" plans. I have some things in Excel and some in WordPerfect. Of course, I've never actually prepared a complete schematic as fas connecting the dots. The labeling is such (connectors identified, color, etc.) that it is fairly straight forward and easy to follow.
If everything goes well (time is the issue), I plan to print everything out and place in a ring binder for the trip to the Fest.
In reference to recent comments in various posts, I did notice several instances where color code did not match what was in the Bentley......... brown tape and pen to identify what I did until the end!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old August 16th, 2013, 23:53   #47
Waffles00
TDI(s): 02 1.9 alh
did you get teh map for the pinout finished?
Waffles00 is offline   Reply With Quote
Old September 11th, 2013, 13:42   #48
AndyBees
AndyBees's Avatar
I've read thru this Thread again (number of times), unless I missed it, no one answered the qustion(s) about the Load Reduction Relay.
As far as I know, all vehicles have that Relay or one that serves the purpose. In the start mode of the ignition switch, the Load Reduction Relay is deactivated cutting off current to practically everything but the Starter and components necessary to start the engine. (Like, head lights, marker lights, brake lights, power outlets, defroster circuit, AC, etc., are without power during engine cranking.)
Old September 11th, 2013, 14:20   #49
dremd
dremd's Avatar
I don't know the answer, but I didn't do anything with the load reduction relay in my car and it works fine. That said, I have a new 90ah battery, heavy cables, and it is hot here.
2013 Nissan LEAF what are these emissions you speak of?
03 Silver Premium Jetta Wagon lots of OEM goodness. 1.8T Triptronic eliminated, ALH + 6 speed manual installed in place. Emissions? Yes, a lot
2006 Sprinter long range hauler, 300+ cubic feet loaded 25 mpg.
2014 JSW (Went back to VW) Emissions? Well, about that . . .
dremd is offline   Reply With Quote
Old September 11th, 2013, 15:31   #50
JFettig
JFettig's Avatar
I think you are correct Andy. I'm not running that, just left it disconnected and everything operates the same as it did when I was running MSA15
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old September 11th, 2013, 16:00   #51
AndyBees
AndyBees's Avatar
Yeah, the Load Reduction Relay in the vehicle that you are setting the TDI engine performs that function (load reduction). The LRR from the donor vehicle is not necessary at all!
If you notice, the "hot wires" involved with the LRR are Black & Yellow ....... that's typical of those circuits!
Old September 12th, 2013, 07:11   #52
archemitis
archemitis's Avatar
I have found that a load reduction relay is not necessary in my situation. My vehicle has very limited electronics, and the engine still cranks fine with cooling fans and lighting. I could imagine a car loaded with amp drawing electronics making the starter hard to crank without one.
My swap has about 40 miles(and climbing) on it now thanks in part to this thread.
archemitis is offline   Reply With Quote
Old November 28th, 2013, 05:19   #53
dremd
dremd's Avatar
I just wanted to bump this thread, which I consider to be among the best here on tdiclub.
Old November 5th, 2014, 17:29   #54
dremd
dremd's Avatar
Just wanted to bump best thread in the subforum
Old November 14th, 2014, 13:22   #55
vdubspeed
Okay....The OP is in the house!!!
My TDI swap is running and I'm so damn glad I built this guide because it was incredibly helpful. There are a few changes and I will be posting them soon but for the most part...it's highly accurate and will get you up and running...
https://www.youtube.com/watch?v=qtvuDNxZDxk
vdubspeed is offline   Reply With Quote
Old December 30th, 2014, 10:29   #56
mcneil
Glow Plug Relay J52 pin 7, 0.35 gn,
On my bentley diagram it looks like it goes to T121/33 not T121/23. Typo?
2000 Jeep TJ TDI with a 4L65e Automatic
http://forums.tdiclub.com/showthread.php?t=349116
slowly coming together
mcneil is offline   Reply With Quote
Old January 9th, 2015, 22:02   #57
Autopaul
Excellent thread and diagrams! Thank you
How much of this stuff is going to be different from an alh To a PD motor, my wiring harness is from an 04 pd jetta, and motor from similar year passat> using jetta cluster
Autopaul is offline   Reply With Quote
Old March 3rd, 2015, 13:30   #58
A-man930
Subscribing for reference. Thanks for taking the time to put this together!
A-man930 is offline   Reply With Quote
Old February 11th, 2016, 09:32   #59
Autopaul
i realize that this is an older thread, I have read it a number of times and wondered if this was ever "Stickied" I always have a hard time finding it and thus it is now in my Favorites.
On a side note is there any noticeable differences between an alh wiring schematic and a PD bhw (from a Passat).
I cannot find the thread that talks about these differences.
Thanks again for all the info.
Old February 11th, 2016, 16:57   #60
oldpoopie
oldpoopie's Avatar
ALH and BHW will be very different. They are different engines, AND different chassis.
Pacific Northwest TRUSTED TDIClub mechanic
Email me, justgrow@gmail.com
MK4 ALH alternator pinout? A4-TDI TDI 101 9 April 27th, 2013 20:43
68 pin 98 jetta TDI pinout Goldguru VW MKIII-A3/B4 TDIs 13 April 25th, 2011 03:23
"THE" ALH pinout? onlyn8v TDI Conversions 3 March 6th, 2011 09:19
98 TDI pinout 98GTDI OBD Scanners 0 November 27th, 2005 08:04
TDI-ECU Pinout RonnyH VW MKIV-A4 TDIs (VE and PD) 0 January 27th, 2001 15:05
Page generated in 0.14418 seconds with 10 queries
[Output: 127.96 Kb. compressed to 106.66 Kb. by saving 21.30 Kb. (16.65%)]
