Old July 1st, 2013, 06:52   #31
vdubspeed
AndyBees - I'd love to see your notes though!
I've updated the brown connector to reflect the updates.
I'm also about to tear into this Jetta harness and will make notes that show the difference. Three differences between the New Beetle ALH harness and the Golf/Jetta harness I have noticed are:
1. New Beetle MAP/IAT sensor runs in the car harness and has to be spliced back in.
2. G/J harness has small relay box attached. I plan to use this box to house my 109 relay, glow plug relay and coolant relay
3. T14 on the Beetle is right by the ECU. T14 on the G/J is down by the battery.
Thanks for all the input.
Jason
vdubspeed is offline   Reply With Quote
Old July 1st, 2013, 19:18   #32
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
The NB MAP wires run through the colored connectors straight to the ecu.
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old July 2nd, 2013, 04:35   #33
vdubspeed
Yes I know. That's what I'm saying. On a new beetle you have to unwrap the passenger side harness to get just the MAP wiring out.
On a G/J...no worries.
Old July 5th, 2013, 10:47   #34
JFettig
JFettig's Avatar
I just whipped this up,
2003 Golf/Jetta ALH harness diagram
http://i.imgur.com/2fHgCmG.jpg
Now I gotta figure out how to print it so I can draw on it
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old July 9th, 2013, 08:47   #35
JFettig
JFettig's Avatar
Been running my EDC swap for a day, pin 88 is not hooked up to anything and everything seems to run just fine, no extra codes or anything.
Old July 9th, 2013, 22:07   #36
dremd
dremd's Avatar
Hey guys awesome info here.
I'm swapping a 2000 ALH with a 03 auto harness and EDC15 ecu in to a 2003 Jetta wagon GLX.
I'm trying to use the first post in this thread, unfortunately, I don't appear to have a T14a "a few inches from small ecu connector".
I THINK I have 100% determined that the Golf/ jetta doesn't have that connector, however I am assuming that the same functions still exist on the G/J as the new Beatle, so how how do I find those lines on the Golf/ Jetta harness?
Tesla Model S P85
03 Silver Premium Jetta Wagon ALH + 6speed MT
2013 Nissan LEAF Totaled
2006 Sprinter
2014 JSW (Went back to VW)
dremd is offline   Reply With Quote
Old July 9th, 2013, 22:18   #37
JFettig
JFettig's Avatar
its by the battery
Once I finalize my ALH harness stuff, I'll post it up.
Old July 9th, 2013, 22:35   #38
dremd
dremd's Avatar
Originally Posted by JFettig View Post
its by the battery
Is it this one?
Edited to Fix pics totally my bad.
I'd like to send out a GIANT thank you to JFettig for a) taking the time to un-jumble my link and b) so quickly clearing that up.
Tesla Model S P85
2006 Sprinter
Old July 9th, 2013, 22:40   #39
JFettig
JFettig's Avatar
pics don't work, but I found them, looks like the one.
Old July 10th, 2013, 01:08   #40
zukikat
Fuel Economy: 45mpg hwy
While reviewing JFettig's '03 G/J bentley diagram link in an effort to assist dremd's '03 G/J 1.8T to ALH swap with an '03 ALH ECU/Harness I noticed several things...
JFettig's link shows T14a/7 and T14a/8 in use, which (the O.P.) vdubspeed's '01NB charts/pics/notes does not. I presume this is an '03 change???
JFettig's link also shows T14a/10 color as "sw/gn" versus vdubspeed's '01NB T14a/10 "gn/sw(Small)", and I noticed both the '03G/J and '01NB show T14a/2 is "sw/gn", same color as the '03G/J diagram also shows on T14a/10. Do pins /10 and /2 of T14a share that same wire in '03?
Any thoughts/suggestions on these things would definitely be helpful and appreciated.
zukikat is offline   Reply With Quote
Old July 10th, 2013, 06:44   #41
vdubspeed
I could have just reversed the colors zukkiat. I'm not near the harness but I'll check tonight.
My NB/ALH/Auto harness is definitely a little difference then other harnesses.
Nice to hear another pin 88 confirmation.
Thanks again for the continued input.
Old July 11th, 2013, 08:21   #42
zukikat
Yeah, NB and G/J, although both may have gotten the ALH, have their differences...
Old July 11th, 2013, 22:28   #43
zukikat
Some '03 G/J vs '01 NB wiring info updates...
Based on Jfettig's Bentley pic link, dremd and I have determined that for the '03 G/J the T14a/7 is for G22/3 "VSS Ground" which is a part of the Vehicle Speed Sensor circuit and works in conjunction with T14a/2 G22/1 "VSS Power" and T14a/3 G22/2 "VSS Signal" and is therefore necessary for Vehicle Speed Sensor operation in an '03 G/J. How this may or may not apply to earlier Mk4 G/J we do not know...
We've also seen in Jfettig's Bentley pic link that on a '03 G/J T14a/8 is wired on one side of the T14a connection but doesn't seem to go anywhere on the mating T14a plug/socket, although based on that same Bentley pic link this pin IS POWERED on Fuse S229 10A which also connects to ECU T121/37 via T6/1 for purposes presently unknown by the two of us...
Old August 10th, 2013, 17:44   #44
archemitis
archemitis's Avatar
Bump for an OP update? Dont want this gem of a thread to get lost!
archemitis is offline   Reply With Quote
Old August 10th, 2013, 17:57   #45
dremd
dremd's Avatar
Gem for sure!
This thread makes me want to put an ALH in something else.
Tesla Model S P85
2006 Sprinter
MK4 ALH alternator pinout? A4-TDI TDI 101 9 April 27th, 2013 21:43
68 pin 98 jetta TDI pinout Goldguru VW MKIII-A3/B4 TDIs 13 April 25th, 2011 04:23
"THE" ALH pinout? onlyn8v TDI Conversions 3 March 6th, 2011 10:19
98 TDI pinout 98GTDI OBD Scanners 0 November 27th, 2005 09:04
TDI-ECU Pinout RonnyH VW MKIV-A4 TDIs (VE and PD) 0 January 27th, 2001 16:05
Page generated in 0.18780 seconds with 10 queries
[Output: 130.19 Kb. compressed to 108.75 Kb. by saving 21.44 Kb. (16.47%)]
