Old June 15th, 2013, 19:10   #1
vdubspeed
Default ALH TDI pinout.
These pictures are subject to change but I wanted to get the information I have gathered out there. I know there are plenty of people that do TDI swaps beyond just VW people. My goal here is to help ALL TDI swappers get there swaps running as the factory intended.
Please remember though...my donor is from a 2001 Beetle Auto donor and going in a 1984 Rabbit GTI so I'm a little geared toward that thinking.
This is also an evolving set of picture. I haven't even finished the swap yet but I'm close to having the wiring figured out.
And now I present...
ALH TDI wiring Version 1.2
1.1 - change - correct title
1.2 - change - T6/1 Brown - power to ECU when key is on. To pin 121/37 on ECU.
vdubspeed is offline   Reply With Quote
Old June 15th, 2013, 23:07   #2
markd89
Looks like a VERY cool resource
Why is it labeled "AHU TDI-121 TDI Pinout" (not ALH)?
1978 VW Bus 1Z TDI Build thread: http://forums.tdiclub.com/showthread.php?t=308793
markd89 is offline   Reply With Quote
Old June 15th, 2013, 23:59   #3
Red_Liner740
TDI(s): none
Dude, you're amazing!!
Thats exactly what i need!!
Red_Liner740 is offline   Reply With Quote
Old June 16th, 2013, 05:50   #4
vdubspeed
Because racecar.
Version 1.1 belongs to you good Sir.
Old June 16th, 2013, 09:31   #5
AndyBees
AndyBees's Avatar
Awesome info! Wow! I spent tons of hours deciphering the Bentley manual electrical schematics and applying it to the real world.
Now, I have all that info in Excel Spreadsheet as well as my hand-drawn schematics. I also did mine maybe a little deeper because I am using the Jetta Cluster with most all the bells and whistles as well as the cruise, fuel level, coolant level, brake fluid level, clutch-in to start, etc.
Surely, many will be appreciative of the work you have done. It shows dedication and talent!
Thanks!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old June 16th, 2013, 23:03   #6
hybridfreak
T10Black/8 gn/ws connects to the clutch pedal switch IIRC.
Very helpful writeup! Thank you!
hybridfreak is offline   Reply With Quote
Old June 16th, 2013, 23:16   #7
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
Ahem....ECU ground?
Nice work!
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old June 17th, 2013, 02:58   #8
vdubspeed
AH! That makes sense because my donor was an auto
Originally Posted by greengeeker View Post
Ahem....ECU ground?
Nice work!
Where we're goin...we don't need ECU grounds
Old June 18th, 2013, 19:42   #9
Red_Liner740
TDI(s): none
I see a few of the pictures and descriptions have references to "Figure 1"
Would you happen to have a picture or a link to this figure 1?
** NEVER MIND....if i just opened my eyes and LOOKED i would see it in the first picture...duuh.
Old June 19th, 2013, 09:18   #10
JFettig
JFettig's Avatar
Nice. I just went through all this myself. You should note that the pin-out on some cruise control stalks and gas pedals are different. I'm putting a 121 pin ALH ecu and harness into my Passat and found that the pin numbers are different.
Minnesota Malone Tuning dealer
1998 B5 Passat TDI Compound Turbos
2009 JSW Stage 3 196whp so far
DIY injector calibration http://forums.tdiclub.com/showthread.php?t=383324
JFettig is offline   Reply With Quote
Old June 21st, 2013, 17:25   #11
archemitis
archemitis's Avatar
This post came up just in time for me! Thank you so much! I'm trying to understand what makes the ECU send the ground to terminal 85 on the 109 relay. what tells the computer its time to wake up?
I'm thinking its got to be t121/88 or t121/37. Is there an accessory position for one and an on position for the other?
archemitis is offline   Reply With Quote
Old June 22nd, 2013, 05:27   #12
vdubspeed
88 wakes up the ECU(key on), ECU then fires back to power supply relay and that in turn wakes everybody else up.
Old June 23rd, 2013, 15:05   #13
JFettig
JFettig's Avatar
I'm finishing up what I need to do with mine and I'm also stumped on pin 88. I'm not putting this into a MK4, its actually going into a B5 and I have a general idea what its for but don't know any specifics.
This is T14a/10 - load reduction relay.
What does it do? How does it work? What do I hook it up to?
Old June 23rd, 2013, 15:23   #14
ta79pr
ta79pr's Avatar
TDI(s): 02 TTQ (BEW)
Fuel Economy: avg. 43
If a PD, T10w/7 [li/ws] would be the fuel pump relay trigger from the ecu (fuel pump relay (J17 (4/85)). Also, T10w/9 [ge] is the "crash signal" from the airbag module if your target vehicle is so equipped.
ta79pr is offline   Reply With Quote
Old June 23rd, 2013, 16:52   #15
archemitis
archemitis's Avatar
I was wondering about that myself. Pretty sure it has something to do with the ecu getting full power while the starter is cranking. Not needed in my situation... I hope.
Any clue what T121/37 does? Looks like it goes to the ignition accessory position.
Im working on a "stand alone" harness that only needs the ignition switch signal from the vehicle along with clutch, brake and all that... so I can only speak in T121, as I only have two large ecu plugs to play with.
Does the ecu care if the starter is cranking? I havent found any ecu pins that go to the starter, so Im guessing no?
Sure wish there was a bar where guys that knew wiring could go and talk about this stuff and run ides by other like minded individuals... guess this is the next best thing!
Thanks again, this thread got me back into the wiring mode.
MK4 ALH alternator pinout? A4-TDI TDI 101 9 April 27th, 2013 20:43
68 pin 98 jetta TDI pinout Goldguru VW MKIII-A3/B4 TDIs 13 April 25th, 2011 03:23
"THE" ALH pinout? onlyn8v TDI Conversions 3 March 6th, 2011 09:19
98 TDI pinout 98GTDI OBD Scanners 0 November 27th, 2005 08:04
TDI-ECU Pinout RonnyH VW MKIV-A4 TDIs (VE and PD) 0 January 27th, 2001 15:05
Page generated in 0.17788 seconds with 10 queries
[Output: 128.13 Kb. compressed to 107.10 Kb. by saving 21.02 Kb. (16.41%)]
