Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old June 15th, 2013, 07:30   #1
mhouck
mhouck's Avatar
Default New Filler Neck
Anyone had their car serviced at VW lately? I just had my compressor replaced and they swapped the filler neck and installed a device to prevent mis-fueling. Gasoline nozzles won't fit now, kind of interesting.
Mychael
'12 DSG Jetta TDI w\ Premium
'10 DSG Jetta TDI
mhouck is offline   Reply With Quote
Old June 15th, 2013, 08:43   #2
Roshermoore
Default Huh?
You must not have been reading much on the forum lately. There have been numerous threads about the misfueling TSB. This one has gone on for 6 pages.
http://forums.tdiclub.com/showthread.php?t=385623
09 Jetta Sportwagen, Blue Graphite Metallic, DSG, Sunroof, Rubber mats, Zeta Products body color side moldings, Body color door edge guards, VW front and rear Splash Guards, Clear rear bumper protector, 8" "Stubby" antenna. Build Date 11/08
Roshermoore is offline   Reply With Quote
Old June 15th, 2013, 16:26   #3
rms85702
rms85702's Avatar
All well and good until some jack wagon gas jockey replaces the one diesel pump nozzle with a gas one...
rms85702 is offline   Reply With Quote
Old June 16th, 2013, 13:32   #4
TommyTuTone
rms85702 is right!! Apparently a common issue; I once had to drive to 5 pumps at 3 different stations before I could find a diesel nozzle that would go into my tank!
TommyTuTone is offline   Reply With Quote
Old June 16th, 2013, 13:49   #5
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Which is yet another reason that YOU should not wait until the last minute to fuel up your TDI.
I capitalized YOU because nobody else decides when or where YOU stop for fuel.
Don't forget that the color of the pump handle has no bearing on what product comes out the spout.
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old June 16th, 2013, 16:27   #6
pdt165
Bill
But it was green so i thought it was diesel........
LED bulbs in almost all possible locations. Aftermarket OEM Fogs. ESP Off Button. Malone Stage 1.5 Tune.
Micro-Can, Jupiter FL, PM me.
pdt165 is offline   Reply With Quote
Old June 16th, 2013, 19:33   #7
mhouck
mhouck's Avatar
Yeah, sorry I've been in and out. Hasn't really caused me any heartache yet, and no full service fuel stations in Texas, so I think I'll be okay.
Mychael
'10 DSG Jetta TDI
Old June 16th, 2013, 23:01   #8
jetlagmech
TDI(s): 2010 jetta
Fuel Economy: best tank 50.6, worst 36
If I have to go to the dealer for something I think I will tell them not to install this safety devise unless they are going to give me the adapter to use other size nozzles. I think the dealer is finished for me now that I have 85,000 miles and the dry area I live in I don't expect any exhaust valve problems.
JETLAGMECH
2010 jetta, 6sp man, & tdiclub plate frame ..build date 08-09
1956 Buick Special (my dad bought it brand new)
1946 Luscombe 8E
jetlagmech is offline   Reply With Quote
Old June 16th, 2013, 23:03   #9
rms85702
rms85702's Avatar
Bill, I whole heartedly agree with you. I my self don't really wait until the last drop if fuel is pumped from the tank to fill up. I try to keep at least a half tanks worth of fuel in the car.
Your also right about how no one decides when I stop for fuel, its usually my bladder that decides.
Old June 18th, 2013, 13:57   #10
DieselMann99
Originally Posted by mhouck View Post
. . . and they swapped the filler neck and installed a device to prevent mis-fueling. Gasoline nozzles won't fit now
Since a gas nozzle is narrower, how exactly does the new device work?
DieselMann99 is offline   Reply With Quote
Old June 18th, 2013, 16:07   #11
TDIx2
TDIx2's Avatar
Location: Saginaw Mi ~ looking out for deer and dangerous people!
TDI(s): 2014 Jetta
Just filled up today with the misfuel device. What a treat that was only took 15 minutes to pump 11 gallons. I could hear the fuel rising up the tank then click like every 10 seconds. What a joke this thing is. They should have called the no fuel adaptor. Lol
2014~Jetta TDI premium/nav
2008~EOS Eshmier Blue LUX:
TDIx2 is offline   Reply With Quote
Old June 18th, 2013, 19:26   #12
elconquistador
elconquistador's Avatar
Sounds like ill be removing this little piece of vw tech if/when it gets installed
2011 VW Jetta 2.0 TDI
-Feb/2011 Build Date
2004 Isuzu Axiom
elconquistador is offline   Reply With Quote
Old June 20th, 2013, 15:56   #13
rms85702
rms85702's Avatar
Could also tell them not to install it into YOUR car.
Old June 20th, 2013, 18:21   #14
millerman61
My 2013 came with this already installed. I have never had this problem when filling up.
millerman61 is offline   Reply With Quote
Old June 20th, 2013, 20:53   #15
mhouck
mhouck's Avatar
Two fill ups for me now too, and no issues
Mychael
'10 DSG Jetta TDI
Filler neck sanjaun2 VW Passat Family (NMS and B7) TDIs (2012+) 34 April 21st, 2013 17:27
Filler Neck. A5JETTA VW MKV-A5 Golf/Jettas 84 March 10th, 2013 13:17
Rusty filler neck DezlDan VW B5 Passat TDIs 9 August 14th, 2007 17:38
Rust in the filler neck LoneLIPumpeDuse VW MKIV-A4 TDIs (VE and PD) 17 January 15th, 2007 11:53
pushed in filler neck? JFryauff Fuels & Lubricants 11 April 9th, 2005 08:00
Page generated in 0.17871 seconds with 10 queries
[Output: 131.83 Kb. compressed to 110.40 Kb. by saving 21.43 Kb. (16.26%)]
