Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old June 13th, 2013, 11:53   #1
Lonecrow
Lonecrow's Avatar
Smile Towing Revisted Jetta TDI 2011 Automatic
I've found "some" posts about towing with a 2011 Jetta with the DSG but nothing really definitive.
The specs are no more than 200 lbs tongue and 2000lbs towing. Now that does include the weight of the actual trailer too?
Also I keep reading that towing with an automatic is taboo. I only plan on getting a 4x8ft trailer to get the occasional lumber, half yard of dirt or stone, and possibly bringing a snowmobile or ATV up north. At the most the ATV would be about 800lbs.
Would adding a transmission cooler to this help the fact its an automatic? Or should I just drive with it in manual mode to try and keep the rpm's low?
Any advice?
Lonecrow is offline   Reply With Quote
Old June 13th, 2013, 12:30   #2
bennybmn
I saw a guy towing 2 dirt bikes on a small trailer in a sportwagen recently, seemed to have no problem. However, I would think that weight DOES include the trailer, so choose wisely
____________________________________________
Euro Switch, Dual horns and powder coated Portos so far... TC off switch soon!
bennybmn is offline   Reply With Quote
Old June 13th, 2013, 12:48   #3
pdt165
It does include trailer, other wise you could tow a lawn more trailer at 100 lbs or a empty uhaul at 500 lb, and that would make a huge difference in overall weight.
not sure if it was MK6 specific or somewhere else, but there is a cool thread called "show what you tow" might be of some help.
EDIT: here you are. http://forums.tdiclub.com/showthread.php?t=255330 Itll give you somethign to read through for a while
LED bulbs in almost all possible locations. Aftermarket OEM Fogs. ESP Off Button. Malone Stage 1.5 Tune.
Micro-Can, Jupiter FL, PM me.
pdt165 is offline   Reply With Quote
Old June 13th, 2013, 13:52   #4
Lonecrow
Lonecrow's Avatar
Thanks for the link. I'm just wondering about the transmission, that's really the only thing I worry about and how it would handle a long 8hr trip. I want to take an ATV or snowmobile on a trip eventually.
Old June 19th, 2013, 07:03   #5
redbarron55
I wouldn't worry excessively about the transmission cooler with the DSG. Eventhough it is an automatic gear selection and clutch engagement it has no torque converter that is the greatest contributor to heat in an "automatic" transmission.
The pump and fluid only provide gear selection and clutch engagement through the Magatronic valve.
The heat build up towing should be little if any greater than a manual transmission. That lack of heat build up is why the thing is almost as efficeint as a manual transmission.
The computer clutch engagement is probably better than 99 % of the manual drivers can do. Of course the manual drivers would dissagree!
I have seen ratings on european sites that rate the DSG higher than the manual transmission.
I think the British VW site gives 75KG tow bar weight and 1500KG towing limits (With trailer brekes). The limiting factor seems to be the trailer breaking rather than the load rating.
Towing capacity from UKTOWING = 1889 lbs. for the 2009 Sportwagen TDI.
http://www.uktow.com/towing%20capacity.asp
VW specs for the JSW:
Manual and DSG with brakes 1500 KG
Manual unbraked 740 KG.
DSG unbraked 750 KG.
Tongue (both) weight 75 KG
http://www.volkswagen.co.uk/new/golf...gines/overview
All in all I think that it is no worry for towing 750 KG (1650 lbs.) witout brakes and
the limit of 1500 KG. (3300 lbs) with brakes would give some comfort about the towing ability of the setup.
This is for the Golf variant (JSW).
The NEw Golf is rated 630 manual (unbraked) 1500 (braked)
640 DSG (unbraked) 1500 ( braked)
As you can see the limiting factor is more braking than towing capability as far as load rating on the drivetrain is concerned.
I guess it depends more on your comfort with the braking capabilities of the combination.
Obviously the JSW will tow more than the golf by 100 KG (220 lbs),but the drivetrain is the same.
redbarron55 is offline   Reply With Quote
Old June 21st, 2013, 11:11   #6
gtab55
TDI(s): TDI
I was in Germany and saw a Golf Variant (JSW) pulling a horse trailer. I could not tell whether or not it was with horses, but was still impressive.
gtab55 is offline   Reply With Quote
Old June 25th, 2013, 06:50   #7
Lonecrow
Lonecrow's Avatar
So I put the hitch on and a 4x8 trailer and it seems fine. Although the trailer is pretty light it wobbles and such around 80kms but if I have a load it seems more stable. I can only really take half a yard of gravel or dirt etc. But it tows it without any issue at all even under braking it is fine.
Just worry about the transmission on long trips if it'll be ok.
Also anyone recommend a good place to buy some bags? The back end does droop very easily I noticed. Need something to stiffen the rear shocks a bit.
Old June 25th, 2013, 19:42   #8
redbarron55
Rear springs for towing IDParts $329 in stock.
Old June 28th, 2013, 19:58   #9
caper7
I wouldn't worry about towing anything I towed a snowmobile and seadoo for years with no troubles.
caper7 is offline   Reply With Quote
Official towing capacity for 2011 Jetta TDI DSG? mtdoragary VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 29 December 7th, 2013 19:11
2011 Jetta Sports Wagon TDI Reliability: Manual vs Automatic Transmission moeen49 TDI 101 0 July 6th, 2011 19:49
Debating between an Automatic or Manual 2011 Jetta TDI Pyke VW MKVI-A6 Jetta Sedan (~ 2011+) 75 May 6th, 2011 11:52
Towing with a 2010 or 2011 Jetta TDI Wagon llscholes TDI 101 9 August 9th, 2010 11:25
towing my TDI/Automatic *DELETED* kensterling VW MKIV-A4 TDIs (VE and PD) 3 January 12th, 2004 07:09
Page generated in 0.13035 seconds with 10 queries
[Output: 90.39 Kb. compressed to 77.37 Kb. by saving 13.02 Kb. (14.41%)]
