Dimon80
Just wanted to give a warning to people who live in Chicagoland area and recently changed oil at Jennings VW in Glenview. Go back and have them re-change your oil or change it yourself/elsewhere!
Apperantly, until recently, the dealership service department and their technicians did not know that 507 spec oil must be used on TDIs. Their certified trained techs used (and probably still use) 504 spec oil out of drums in TDIs. After an oil change I inquired which oil was used and the reply was given that they used the correct one. I then demanded to show the bottles and they were not able to produce them. They called up the technicial, who pointed out the drums, with 504 spec oil in them. I had to open up a manual to show that TDI engine requires 507 spec. The service manager had an 'oh $hit' look on his face.
Unfortunately, for me this was a second oil change I've done at that dealership and it never downed on me that they used the wrong oil (@10K). Silly me assumed that after more than 4 years in production, certified service techs would know what oil must be used. So at the second change (@20K) for some reason I decided to challenge them and what I got is the description above. Obviously, they change to the correct oil right away. However, the damage was already done.
After a conversation with service manager and his reply that nothing will happen to the car, I had to contact the VWoA. All they could do is be a middle man between myself and the dealership, claiming that this is not a company's (VW) fault, rathen then dealership's. So after a few weeks of phone calls I got a $100 discount on my 40K service. Wow! I was impressed (sarcastic smiley)!
So, I came back to the dealership and after more arguements with all the managers there, I was not able to get anywhere. They are claiming (verbally, obviously) that the car will be fine, that there's no long term effect, etc. The standard bs. One of the GMs even mentioned that I was lucky to even get $100 off, he wouldn't give me anything.
Well, lesson learned for me. This is the dealership I will never go back for service and I would not recommend it to anybody. Please stay away from Jennings VW in Glenview IL. Even if they change your oil correctly, you will not get a good service from them.
I understand that the car might be fine even after driving on the wrong oil for 10K. However, the key word is 'might'. Except VW engineers (if they ever done any testing of that kind), no one can claim that there will be no adverse effects after this.
Once again, I want to relay the message to everyone here, not to use this dealership for service. And be careful using other ones!
