Old June 1st, 2013, 19:33   #1
speedpepino
Fuel Economy: 1.6 l - 58 mpg
Angry tdi swap transmission
can someone help me to find what manual transmission i need for my 2004 TDI the engine code is BEW my five speed automatic transmission went bye bye it went to heaven and now i want to put manual in i have 02M 6 speed for my for my 2005 GTI but if i can put in the TDI then i will, thanks for the help
speedpepino is offline   Reply With Quote
Old June 1st, 2013, 20:03   #2
Seatman
Seatman's Avatar
Fuel Economy: No idea
The gear ratios are different in the tdi so the gti one wont be much use. But any of the Mk4 tdi 2000 on gearbox set ups will fit, same mounting to the engine etc.
Seatman is offline   Reply With Quote
Old June 5th, 2013, 12:18   #3
cruiser guy
cruiser guy's Avatar
Location: No fixed address!! Yep, we're really of no fixed address.
Do all gasser trannies have different ratios than the TDi ones?
cruiser guy is offline   Reply With Quote
Old June 5th, 2013, 12:52   #4
QuickTD
Yes. All gas transmissions have lower gear ratios, particularly 4th and 5th. They often have lower ratio final drives as well.
QuickTD is offline   Reply With Quote
Old June 5th, 2013, 17:01   #5
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
The VR6 trans is close to the right ratio but the bell housing is wrong...
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old February 22nd, 2014, 19:28   #6
speedpepino
i completed the swap from automatic to stickshift on my golf tdi 1.9 t. everything works except the spedometer, i do not know how or were to connect the 3 wires from the speed sensor on the new manual transmission.. can someone help me please? thx
AHU/ALH Eurovan T4, about transmission (5th gear swap, 02A swap) X@V TDI Conversions 46 March 24th, 2014 16:15
ALH 5-Speed Transmission w Peloquin LSD, .681 5th Gear Swap, and Manual Swap Parts riddleyo Private TDI Items for Sale/Wanted 8 March 3rd, 2012 17:59
Best Manual Transmission For an 05 Golf TDI??? Looking to Swap Out. FolksWagen Upgrades (non TDI Engine related) 4 June 13th, 2011 17:54
09 TDI Manual Transmission swap isa540 VW MKV-A5 Golf/Jettas 6 May 19th, 2010 07:05
WTB ** Parts for transmission swap 2000 Jetta TDI CF6-50 Private TDI Items for Sale/Wanted 2 February 5th, 2010 20:01
Page generated in 0.13374 seconds with 10 queries
[Output: 74.22 Kb. compressed to 65.10 Kb. by saving 9.12 Kb. (12.29%)]
