Old May 31st, 2013, 20:29   #1
bubba
TDI(s): 2005 Passat
Default Fault Codes
Hello Mates,
2005 TDI Passat Sedan. No chipping or mods, still chained, 73K
I am currently in limp mode due to throwing several codes. I borrowed a scan tool and this is what came up.
P0322
P2801
P0001
P0722
I have been doing general maintenance on the car. The only possibility i can think of is that when I changed the air filter I forgot to put the small vacuum hose on the air box before I took it for a drive. The battery was out for a couple of days until I got the new one installed.
Any feedback would be greatly appreciated.
bubba is offline   Reply With Quote
Old June 2nd, 2013, 09:46   #2
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
P0322 = VAG 16706 - Engine Speed Sensor No Signal.
P0722 = VAG 17106 - Transmission Output RPM Sender No Signal.
P0001 and P2801 do not appear to be BHW related as they are not on the fault code list in Bentley.
Did you disturb anything under the cowl when you changed the battery?
-George Bernard Shaw
Old June 2nd, 2013, 16:29   #3
thundershorts
Why not first check system voltage for approx 14+-, then clear all codes and see what comes back. If your alt can't maintain 14 at idle with new battery(hopefully of proper size and quality), then charging system needs attention. When you buy a battery, it isn't fully charged and you may need to do that first.
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old June 2nd, 2013, 21:55   #4
bubba
TDI(s): 2005 Passat
Thanks for the input.
I will put the new battery on the battery tender. The new battery is the larger Interstate 80 ah. I also installed the new hold down strap/bracket for that battery.
I didn't disturb anything that i know of when changing the battery. I did leave the small vacuum hose off the air box after changing the air filter (back on now).
I want to avoid taking it to the dealer if possible.
With the codes cleared it was still in limp mode and the service engine light came back on after a few miles of driving.
I will need to borrow a scan tool again.
Thank You Guys!
Old June 3rd, 2013, 08:38   #5
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Yes, avoid the dealers. Where in CF are you?
Check here for a TDI guru in your area:
https://docs.google.com/document/d/1...hl=en_US&pli=1
Originally Posted by bubba View Post
...I want to avoid taking it to the dealer if possible...
Old June 3rd, 2013, 15:58   #6
bubba
TDI(s): 2005 Passat
I am in the Monterey Bay CA area.
Old June 3rd, 2013, 17:08   #7
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Did you check the link?
Old June 4th, 2013, 00:03   #8
bubba
TDI(s): 2005 Passat
Yes, thank you, I did check the link. Looks like San Jose is the closest. About a 1.5 hour drive.
Old June 4th, 2013, 05:48   #9
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Not on the list, but this shows up on the map:
Van-Café
1823 Soquel Ave.
Santa Cruz, Ca 95062
(831) 426-1244
Old June 6th, 2013, 00:59   #10
bubba
TDI(s): 2005 Passat
Problem solved. I took the air intake off again and found a very small vacuum line disconnected below the turbo intake hose. I found a person locally with a vagcom, cleared the codes and now it runs perfectly.
Old June 6th, 2013, 04:50   #11
thundershorts
Wouldn't be a bad idea for you to purchase your own vag-com.
Old June 6th, 2013, 06:03   #12
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Glad you figured it out. ++ to thundershorts' recommendation re VCDS (Vag-Com)
Fault Codes colezy9 VW MKV-A5 Golf/Jettas 1 September 16th, 2011 05:22
Fault codes Help tverhoeven VW MKIV-A4 TDIs (VE and PD) 1 September 8th, 2011 18:54
help...fault codes casta_baga OBD Scanners 2 August 30th, 2005 18:55
help...fault codes casta_baga TDI 101 0 August 10th, 2005 17:41
Fault Codes ransmith TDI 101 7 December 12th, 2002 14:07
Page generated in 0.15325 seconds with 10 queries
[Output: 105.00 Kb. compressed to 87.95 Kb. by saving 17.04 Kb. (16.23%)]
