Old May 20th, 2013, 17:12   #1
eddieleephd
Fuel Economy: 45-51.9
Default Weird oil leak on the back of alh engine
Hey I am trying to diagnose an oil leak on the back of the engine, it is not the turbo, valve cover, and doesn't appear to be head gasket.
I cleaned it all up and wiped down to as clean as possible, no significant oil present, then started it up and let it present again.
The only place I can see it coming from is the engine mount on the pulley side of the engine.
it runs down the back side then down the block.
I cannot think of something that should leak here. There is no oil in the timing cover or on the belt as I can see.
I have recently used a engine mount bracket repair kit on it purchased from idparts.
Any ideas of what might leak??????
eddieleephd is offline   Reply With Quote
Old May 20th, 2013, 17:19   #2
davebugs
EGR valve is weeping?
That's what mine was - twice.
davebugs is offline   Reply With Quote
Old May 20th, 2013, 17:19   #3
EGR valve?
2002 Jetta wagon, 358K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 255K; 2011 335d, 55K; 2015 Golf Sportwagen, 5K. Principal, http://www.idparts.com
Old May 20th, 2013, 17:21   #4
Ski in NC
Fuel Economy: 48-52 typical
Camshaft seal??
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old May 20th, 2013, 17:24   #5
eddieleephd
Yeah the EGR is good and there is no oil in the timing belt cover so not the cam shaft.
I am looking a bit lower near the engine mount bracket...
Old May 20th, 2013, 17:30   #6
eddieleephd
maybe it could be the camshaft seal...
any other thoughts??
Old May 20th, 2013, 17:45   #7
turbotec
turbotec's Avatar
How about the oil galley plug? There is 2 on the timing belt side. And one on the transmission side.
turbotec is offline   Reply With Quote
Old May 20th, 2013, 17:50   #8
paramedick
paramedick's Avatar
The camshaft seal typically leaks BEHIND the plastic plate underneath the timing belt components. Frequently seen where you report a leak.....
An all TDI Family!!
Old May 20th, 2013, 17:55   #9
whitedog
Hmmm.
Drinks raw water
Old May 23rd, 2013, 06:54   #10
eddieleephd
Is this like a freeze plug?
I will be taking timing belt cover off to replace the cam seals so will be able to see everything.
Old May 23rd, 2013, 08:36   #11
turbotec
turbotec's Avatar
Yes. Just like a freeze plug, but only about a 1/2 inch in diameter. This spot leaking is mostly unlikely, but the other guys listed all the other locations I would have suggested.....This is just one place I would also check!
Old May 24th, 2013, 20:15   #12
eddieleephd
Originally Posted by whitedog View Post
Hmmm.
sorry that was dieselgeek block repair kit...
I had my panzer plate on and hit a riser on the side of the road...
Saved the oil pan and broke the little ear the bracket holds on to...
so I am gonna change the cam shaft seals and likely clean turbo at the same time, with the engine down and forward I will have more room to work...
Old May 25th, 2013, 04:39   #13
DanG144
I believe I remember some one else having leak from a broken ear mount. I am pretty sure they had to seal it with epoxy.
You might take a closer look and call DieselGeek to discuss this possibility.
Old May 25th, 2013, 16:44   #14
eddieleephd
Thanks I have looked it over a few times and have seen nothing...
One more thing to have a good look at when it is apart in the next couple weeks weather permitting.
For now I am planning on a intake and turbo cleaning along with cam shaft seal replacement.
really sucks I have had the timing belt off more than I ever expected!!
ALH Oil Leak - Front of engine nashbok TDI 101 17 January 21st, 2015 16:09
...OIL LEAK AT OIL-FILLER CAP of ALH engine... MrSafety VW MKIV-A4 TDIs (VE and PD) 26 December 1st, 2012 20:30
Coolant leak back of engine richmondvatdi VW MKIII-A3/B4 TDIs 15 June 23rd, 2012 21:28
Oil Leak From Back of Engine - 06 Jetta SlowMotionReplay VW MKV-A5 Golf/Jettas 3 June 3rd, 2011 08:53
Air leak from back of engine when cold? Shaggy VW MKIV-A4 TDIs (VE and PD) 2 February 27th, 2008 09:03
Page generated in 0.16723 seconds with 10 queries
[Output: 115.24 Kb. compressed to 96.07 Kb. by saving 19.17 Kb. (16.63%)]
