alex wetmore
BRM: 2006/65k miles, Won't start, tons of smoke, codes inside, harness looks okay
2006 Jetta, 100hp PD engine, about 64k miles.
My wife's car started smoking heavily (black smoke, so too much fuel) and lost a lot of power on a hill today. This was a sudden event, the car has been working pretty well up until then (though the timing is a bit off so it idles roughly).
Now when the car is first turned on it has very little power, shudders heavily, and barely works. After going a couple of blocks (maybe half a mile) it goes into limp mode and is severely underpowered, but it goes. (update: now it doesn't go at all, it stalls seconds after starting).
VCDS (I liked the name VAG-COM better) reports the following faults:
000387 - Fuel Temp. Sensor A (G81)
P0183 - 000 - Open or Short to Plus - Intermittent
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal - Intermittent
001027 - EGR Valve (N18)
P0403 - 000 - Malfunction - Intermittent
I searched the forums and the most similar thread to mine is this one:
http://forums.tdiclub.com/showthread.php?t=271894
This thread just ends with no resolution.
This led me down the path of checking the EGR. The first suspect thing is that the intake pipe wasn't properly seated, the top was cocked out by about 1/4". This means that it likely wasn't making a good seal. I checked inside and there is more oil than I'd expect to see, but it doesn't look heavily clogged. The oil + smoke from this recent failure can't be helping that.
I hooked up VAG-COM again and tried to drive the car. I got this graph:
http://i.imgur.com/n6P1oa2.png
red: engine speed
green: EGR (spec)
yellow: EGR (actual)
blue: EGR duty cycle
Since the EGR (actual) barely moves even when EGR (spec) is shooting up I'm guessing that this also points to EGR issues.
Is there a way for me to test the EGR with VAG-COM without running the car? I don't want to run the car without the intake pipe. I'd like to see if the EGR valve is moving.
red: engine speed
green: EGR (spec)
