Old May 17th, 2013, 19:46   #1
sasilverbullet
Default rear door won't unlock
03 Jetta - the drivers rear door doesn't unlock with the remote. You have to pull the handle on the inside twice to open it. Every once in a while it opens fine.
What could be the problem?
2003 Jetta GLS TDI
2004 Nissan Titan Crew Cab
1970 Lincoln Mark III
2002 Beetle TDI (son's car)
sasilverbullet is offline   Reply With Quote
Old May 19th, 2013, 17:30   #2
sasilverbullet
bump...
2003 Jetta GLS TDI
Old May 20th, 2013, 22:49   #3
TornadoRed
TornadoRed's Avatar
If you disconnect and then reconnect the battery, that may reinitialize the remote unlock function. Report back if that works, or not.
'03 Golf with 698k miles: Bosio DLC 764, GT1749VB, PP 2.5" downpipe, Malone tuning, VR6/G60 clutch/flywheel, Bilstein HDs, Recaros, Akebono pads/Brembo rotors, Cat filter with Nicktane head, DG Panzer w/FMJ, Pirelli Cinturato P7 AS+, TDT/Delvac1
TDI Trusted Mechanics by jwlionking TDI Search Engine https://cse.google.com/cse/publicurl...44:_idbzjdyxdm
Old June 2nd, 2013, 14:21   #4
sasilverbullet
Tried, nope, still intermittent. I sprayed WD-40 everywhere I could, it seemed to make it work a little better.
Any ideas?
2003 Jetta GLS TDI
Left rear passenger door WON'T unlock... HELP! crashtested VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 27 February 21st, 2016 05:43
Unlock switches/remote won't unlock rear driver's door MKIInut TDI 101 0 July 15th, 2010 14:33
Sometimes door won't lock or unlock RedTDIowner TDI 101 17 October 5th, 2009 12:50
turn key in door. door won't unlock! dairyman TDI 101 12 August 2nd, 2008 18:55
Rear LH Door won't unlock kulwap TDI 101 4 August 14th, 2007 10:57
Page generated in 0.10432 seconds with 10 queries
[Output: 63.75 Kb. compressed to 56.97 Kb. by saving 6.78 Kb. (10.63%)]
