MkV MK V MKVI MK VI fans test AC troubleshooting with VCDS
The changes are sweeping in nature.
The fans on the old mk IV manual AC system should start in slow as soon as the AC was asked to turn on, it did not matter if the clutch engaged or not.
The fans on the MkV systems must see AC pressure rise before they come on in the AC mode.
Luckily there are very good troubleshooting aides for the Mk V system built into its controllers - a VCDS is invaluable.
Fans - Go into the Engine Controller, OUTPUT TESTS, and choose the one for fan testing circuit one. This should cycle BOTH fans from off or very low speed to full speed in a periodic cycle.
The fan controller is built into the large fan on these cars. It develops the pulsed power signal that drives both the large fan and the small fan.
There is another test in this module for the AC system, but it is of minimal value. It calls itself AC clutch relay control circuit test, but don't be fooled - your compressor has no clutch. It does test that the ECU can tell your compressor to unload. If you run this test, do so on a warmed car, and watch for the changes in fuel as the compressor is allowed to load and unload. Have the AC on, engine on and warmed, AC demanded full cool.
Then go to the AUTO HVAC controller ADV Measuring values:
Choose
refrigerant pressure
Air-Conditioning Operation information
Compressor Shut-off Requirement
compressor current, specified value
Temperature after evaporator
Look at these closely.
If you have .825 amps or so requested current that is max. The refrigerant pressure should be high, and the temperature after the evaporator should be low - 2 to 4 C or so.
A bar of pressure is roughly 15 psig, so you can do the math ( or go to a units conversion site on line and let it do the math for you) to see if your high pressure sender agrees with your mechanical gauge set.
The compressor shut-off requirement is the status of the interlocks, and can tell you what may be preventing operation. As long as it says "no shut-off signal is present" and your current is high, then the pressure should be high and the temperature after the evaporator is low. If the pressure is low (and you have a good charge in the system) then the RCV is probably bad. Do verify that the compressor is turning, which it must be unless the break-away protective system has broken free.
The most common failure on these cars AC system is the RCV, Refrigerant Control Valve built into the compressor.
Next is probably the fans.
Then the high pressure sensor.
Mk V and VI AC troubleshooting.
AC Compressor Refrigerant Control Valve Make sure you get the proper valve for your compressor.
