Old May 11th, 2013, 09:23   #1
nvr-enuf
Default Where to pull car / front tow hook
Hello everyone
I have a 2005 Passat wagon and thought the car would have a screw in tow hook like my Jetta. Unfortunately it does not buy does have a hook on the front passenger front but the lower grill near the fog light would get wrecked.
Any suggestions how to simply tow the car from the front?
nvr-enuf is offline   Reply With Quote
Old May 11th, 2013, 10:07   #2
Volk14
You remove that bumper grille to access the tow hook point. Take a look at the owner's manual, it's pretty simple.
Volk14 is offline   Reply With Quote
Old May 11th, 2013, 18:23   #3
TheGrove
Yep, the grill just pops out and the hook is there. When done you can just snap the grill back into place.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old May 12th, 2013, 03:26   #4
thundershorts
thats not a towing hook and should not be used as such, its really a tiedown.
"You can't argue with a fool..."
thundershorts is online now   Reply With Quote
Old May 12th, 2013, 05:07   #5
Psymos
A tiedown? For what a Christmas tree on the roof?
I was always under the assumption it was a tow hook. That's what it is on my Subaru.
Psymos is offline   Reply With Quote
Old May 12th, 2013, 05:15   #6
nvr-enuf
Default Thanks
I have the factory binded book (5" by 8") and was not able to find hoe to pop out- I know it should be simple but I did not want to break it.
I ended up pulling on the sway bar, worked fine.
Old May 12th, 2013, 13:08   #7
TheGrove
Glad it worked out. You pop the piece of grill out by the right fog light. If I remember you can just grab it and give it a good tug and it will snap out.
Old May 12th, 2013, 15:32   #8
peiphil
Take a look up top at the stickys and look under bsm replacement and follow the links to get a very nice procedure with pictures on how each grill piece is removed.
They are very simple once you know where the push tabs are.
No tools just your fingers.
Good thing to practice in case you ever have to get a pull off of a snowbank some day.
I dont think you would like a redneck with a big 4x4 truck hooking on to your swaybar in that case!
peiphil is offline   Reply With Quote
Old May 13th, 2013, 10:59   #9
nvr-enuf
Thanks everyone
Old May 13th, 2013, 11:44   #10
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
It is a tow hook, the tiedown holes for transport go in the oval holes in the unibody rail under the car, and get plugged off during PDI.
oilhammer
www.cardocautomotive.com
Front Tow Hook? JungleMan Ontario 34 July 14th, 2014 10:15
Can I tow it home using front tow hook? sdeck TDI 101 9 October 2nd, 2012 16:58
Front Tow Hook Fun autoelf92 Upgrades (non TDI Engine related) 36 May 31st, 2012 16:50
I had the pleasure of using the front tow hook Skidog TDI 101 9 December 20th, 2008 20:01
No front tow hook? vw4life VW B5 Passat TDIs 4 May 26th, 2007 10:54
Page generated in 0.16264 seconds with 10 queries
[Output: 95.35 Kb. compressed to 80.95 Kb. by saving 14.40 Kb. (15.10%)]
