Old May 2nd, 2013, 06:58   #1
TurnerBFC
Default PD - P0299 - Goes into limp mode
My 2004 jetta tdi (BEW) goes into limp mode and occasionally hands me a gift of an engine light, P0299, which is an under-boost code. I replaced the clip on the intercooler pipe which seems to help, but I think I still have a boost leak somewhere. Can anyone shed some light on where I should look for leaks or to replace? I've heard the N75?
TurnerBFC is offline   Reply With Quote
Old May 2nd, 2013, 07:15   #2
d2305
Replace the vacuum line to the actuator.
d2305 is offline   Reply With Quote
Old May 2nd, 2013, 07:34   #3
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Fuel Economy: Great!
P0299 "Control Range Not Reached" can be caused by a dirty EGR Valve not fully seating. That was the problem with my BHW as diagnosed by Jeff @ RocketChip. Works great now.
-George Bernard Shaw
Old May 2nd, 2013, 07:55   #4
TurnerBFC
Where can I buy the vacuum line?
Old May 2nd, 2013, 07:56   #5
TurnerBFC
Is the best thing for me to do is start by cleaning the egr? Any chemicals you can recommend that will help?
Old May 2nd, 2013, 08:51   #6
1854sailor
Resident Curmudgeon
1854sailor's Avatar
I had part of a can of brake cleaner that I used. Other folks here have soaked the GER in kerosene and even water and reported good results.
See posts #100 through #103 in this thread:
http://forums.tdiclub.com/showthread.php?t=383808
Old May 2nd, 2013, 09:09   #7
TurnerBFC
Ok great! My friend works at an auto shop, he told me to take off the EGR and he will clean it up in the Varsol tank for me. I'll start with that. Thanks 1854sailor
Old May 2nd, 2013, 09:12   #8
1854sailor
Resident Curmudgeon
1854sailor's Avatar
Sounds like a plan. Good luck!
Old May 3rd, 2013, 21:22   #9
TurnerBFC
Ok, so...I REPLACED the EGR with one that my buddy had from his PD that he cleaned up and I still seem to have a loss of power. Can anyone recommend something else to try? I'm going to look into vacuum lines this weekend. It's becomes a real pain.
Although, I have not seen the P0299 code in two days, so it appears I've fixed something.
2005 PD has no power, is this limp mode?? Zampano77 TDI 101 9 September 24th, 2012 22:29
Digi PD limp mode narongc73 TDI Power Enhancements 17 July 18th, 2011 07:45
Limp Mode Help on '04 PD greyebar VW MKIV-A4 TDIs (VE and PD) 5 July 13th, 2008 11:17
2004 PD Limp Mode Neurosis99 VW MKIV-A4 TDIs (VE and PD) 14 March 11th, 2008 14:58
Digi PD and Limp Mode Almagne TDI Power Enhancements 5 January 24th, 2008 16:50
Page generated in 0.14903 seconds with 10 queries
[Output: 89.24 Kb. compressed to 76.27 Kb. by saving 12.98 Kb. (14.54%)]
