Old April 27th, 2013, 07:34   #1
TurnerBFC
Default Immobilizer light flashing...starts for 1 second then dies
My light on the dash that shows the car and the key (not sure what its called) is flashing. The car was running fine yesterday and now this morning for me it will start for 1 second and then die.
Does anyone know what the cause and fix of this is?
Greatly appreciated.
TurnerBFC is offline   Reply With Quote
Old April 27th, 2013, 08:03   #2
Ski in NC
Fuel Economy: 48-52 typical
Immobilizer (anti theft) system is not recognizing your key and thinks the car is being stolen. Two things to try:
1. Do you have another key to try?
2. Put key in ign, turn to run but do not start. Leave it that way for 15min.
Maybe also disconnect battery and leave off for 15min, hook back up and try.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old April 29th, 2013, 08:40   #3
TurnerBFC
Thanks ill try
Old April 29th, 2013, 09:18   #4
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy:
Crazy idea that's also worked a time or two: flip the key over and try the 'other side'. It may position the RFID chip in the key in better range of the immobilizer antenna to be successfully read.
If you post a question, post your solution!
mk4 front wheel bearing | scurvy winter front | VCDS in Chicago, IL USA
You are entitled to your opinions but not your own facts.
scurvy is offline   Reply With Quote
Old April 30th, 2013, 08:55   #5
PDJetta
PDJetta's Avatar
There is a pick-up coil that encircles the ignition switch to be the antena loop to communicate with the chip in the key housing. If the loop is shorted or open, the imobilizer will activate. You may want to check the wiring. Its pretty fragile and the first place I'd look.
--Nate
2000 jetta starts then dies. No immobilizer light. No response from engine controller Turboed VW MKIV-A4 TDIs (VE and PD) 5 December 19th, 2016 13:07
vw touran- starts after few seconds dies. glow plug light flashing abua Other VW Group TD(I)s 0 February 12th, 2013 11:52
2000 tdi No response from engine controller, starts then dies, no immobilizer light Turboed OBD Scanners 10 October 17th, 2012 14:39
No response from engine controller tdi starts then dies no immobilizer light Turboed OBD Scanners 3 October 11th, 2012 16:04
Car dies, then starts, glow plug light flashing? James Carroll TDI 101 0 September 9th, 2006 08:52
Page generated in 0.12243 seconds with 10 queries
[Output: 68.85 Kb. compressed to 60.91 Kb. by saving 7.94 Kb. (11.53%)]
