Old April 21st, 2013, 21:53   #1
tombodd
TDI(s): 2001 jetta
Default serpentine tensioner shock
hi guys...going to change a leaky tensioner shock ONLY. before I get to it has anyone done just the shock bfore? Any tricks or tips?
Thanks, Tom
tombodd is offline   Reply With Quote
Old April 22nd, 2013, 11:36   #2
Redneck Truck
Gone, but not forgotten
Redneck Truck's Avatar
It's easy. Pull the belt, remove the tensioner, remove the shock, reassemble.
From what I'm told, if the tensioner's internal spring or the alternator pulley are malfunctioning, the shock won't last long.
- Still parting a 2002 4-door reflex silver Golf TDI 5-speed.
- Still parting most of 2001 Audi TT 225 6-speed engine bay.
Please help me clear out my garage. PM me.
Redneck Truck is offline   Reply With Quote
Old April 22nd, 2013, 12:01   #3
davebugs
And often a bouncy tensioner is a symptom of clutch pulley failure. Certainly was on my Golf.
So you may wanna check the alternator clutch pulley while you have the serp belt off.
davebugs is offline   Reply With Quote
Old April 22nd, 2013, 17:24   #4
ibyte
Care to elaborate on how to check for an alternator pulley malfunctioning
thanks
ibyte is offline   Reply With Quote
Old April 22nd, 2013, 19:09   #5
davebugs
thanks
Your alternator very likely has a clutch pulley on it - and that's what often fails.
There is a how-to describing how to check this. Often you'll see small metal shavings too.
Old April 25th, 2013, 21:31   #6
tombodd
TDI(s): 2001 jetta
Hey guys ...did the shock replacement yesterday. Dropped the panzer, washed the engine and undercarriage the night before , let it dry overnight. I like working on clean stuff. Easy job. Thanks for all the help and suggestions. Tom
Serpentine Tensioner Tdi_Jetta_94 TDI 101 6 January 3rd, 2013 14:02
Serpentine Tensioner Deezleer TDI 101 0 September 24th, 2009 15:51
V Belt Tensioner shock absorber dave23703 TDI 101 11 April 12th, 2008 17:48
serpentine tensioner jjstark VW MKIV-A4 TDIs (VE and PD) 5 April 6th, 2006 18:42
Broken Mount for Serpentine Tensioner Shock Absorber bigjim VW MKIV-A4 TDIs (VE and PD) 1 September 17th, 2002 17:57
Page generated in 0.15992 seconds with 10 queries
[Output: 72.24 Kb. compressed to 63.28 Kb. by saving 8.96 Kb. (12.40%)]
