Old April 6th, 2013, 07:26   #1
Jetta Knight
Default Wheel lug nut torque
The 2013 owners manual calls for 103 ft/lb of torque for the wheel bolts. This seems a bit high. I have always used, as per the manuals, 88 to 90 ft/lbs of torque on my other VW's. Far be it for me to question VW but I have enough history with the company to be skeptical. Any thoughts?
2001 Jetta TDI Automatc, Black (Sold)
2006 Jetta DSG TDI, Pkg1, Plat Gray (Sold)
2009 JSW DSG TDI, Black (Sold)
2013 Passat SE DSG TDI, Tungsten Silver
2016 Subaru Outback Limited
Jetta Knight is offline   Reply With Quote
Old April 6th, 2013, 08:15   #2
Salsaman06
Salsaman06's Avatar
FWIW the factory shop manual states the 103 value as well. (Actually it says 140 Nm which converts to 103.26 ft-lbs)
TDI Replacement:
2017 Chevrolet Impala Premier - all options
Fantastic car.
Salsaman06 is offline   Reply With Quote
Old April 7th, 2013, 06:25   #3
Jetta Knight
Thank you for the confirmation.
Old April 7th, 2013, 07:10   #4
PaulB
My Sprinter van calls for 175 ft-pounds on the lug nuts! Apparently they can make these strong enough to take the torque.
PaulB is offline   Reply With Quote
Old April 7th, 2013, 14:29   #5
vw_norm
Gone, but not forgotten.
When I rotated the wheels for the 10K service, I tightened and hand torqued each one to spec - 103 ft-lb, with my clicker-type torque wrench. Not applying enough torque is not worth having your wheel bolts loosen while driving. Nothing but bad things will happen.
vw_norm is offline   Reply With Quote
Old April 8th, 2013, 12:09   #6
VernK
And apparently there was a misprint in early manuals, and the torque was spec'd too low (I think the 80-90 lbft*number)
Yours
Vern
VernK is offline   Reply With Quote
Old April 8th, 2013, 20:02   #7
50pascals
I have always torqued that size stud / lug to 85 ft-lb without any problems. On literally dozens of cars. 103 is fine and all, I wouldn't lose any sleep over 85 or 90.
50pascals is offline   Reply With Quote
Old April 8th, 2013, 20:37   #8
brent_strong
I usually do 85 for passenger cars, unless I know offhand what the spec is...
brent_strong is offline   Reply With Quote
Old April 9th, 2013, 13:46   #9
JM Popaleetus
JM Popaleetus's Avatar
Shouldn't be an issue. 100lb-ft isn't an issue for really any car.
The Jetta with its 89lb-ft is almost low.
2013 VW Passat TDI SEL Premium (Candy White/Cornsilk, Lip Spoiler, 17" Salamancas)
2010 VW Jetta TDI Sedan (DSG, White Gold/Cornsilk, Sunroof) RIP
2007 GMC Sierra 2500HD Duramax (Classic, Extended Cab, Summit White/Ebony)
JM Popaleetus is offline   Reply With Quote
Old April 9th, 2013, 14:00   #10
JdC Machine
JdC Machine's Avatar
I wouldn't be worried about 100-103ft.-lbs. As JM said above, 100ft.-lbs. is about what most passenger cars require for lug nut torque.
You think 103ft.-lbs. is high? How does 300ft.-lbs. on the 5/8" studs on my 1990 1-ton Dodge make you feel?
Jim
2013 Passat TDi SEL
Opera Red
Titan Black
JdC Machine is offline   Reply With Quote
Old April 9th, 2013, 14:11   #11
JM Popaleetus
Porsche has you beat with the 400lb-ft that their center locking system uses:
Old April 9th, 2013, 14:23   #12
JdC Machine
Originally Posted by JM Popaleetus View Post
Porsche has you beat with the 400lb-ft that their center locking system uses.
Understandable, since there's only one nut/stud holding the wheel in place and fighting all those forces.
Jim
2013 Passat TDi SEL
Opera Red
Titan Black
Old April 9th, 2013, 18:37   #13
Jetta Knight
Thanks for all the input. I was wondering about the numbers since hearing of situations of cracked wheel hubs with over-torque. They must be grossly over-torqued to have that occur.
Old April 10th, 2013, 09:25   #14
740GLE
I just tossed the summer shoes on and had them at my typical 90-92. 600 miles since and they are still on with no signs of backing out.
Also remember who here has verified their torque wrench has been calibrated recently?
Old April 10th, 2013, 10:56   #15
VernK
Me! Just so happens I have a calibration tool so I can check my wrenches at 50 & 100 lb ft. I check when I remember. My 3/8 SnapOn is dead accurate, my 1/2 Craftsman is right at 50 and 2 lbs low at 100.
Yours
vern
Lug nut Torque, is 38lbs OEM rating the law of the land TDIGLI2002 Upgrades (non TDI Engine related) 27 May 30th, 2012 21:07
2009 Tire Lug Nut Torque Specifications securityguy VW MKV-A5 Golf/Jettas 11 November 5th, 2011 17:27
Lug nut torque on older cars supton General Automotive 2 February 26th, 2011 16:17
B5.5 wheel lug nut torque spec requested leicaman VW B5 Passat TDIs 1 January 5th, 2008 09:48
Lug Nut Torque Setting Paramingus TDI 101 10 February 20th, 2006 16:16
Page generated in 0.14912 seconds with 10 queries
[Output: 127.71 Kb. compressed to 106.07 Kb. by saving 21.64 Kb. (16.94%)]
