Old March 28th, 2013, 08:24   #1
JARED_LA
Default DIY Oil Change
This is my first car and in the past I have always changed my own oil in my trucks. What are you guys doing to change your oil? Top side or bottom? If bottom, how are you lifting the car, with ramps, etc and are you lifting all four tires. If top side, what do you recommend for an extractor?
JARED_LA is offline   Reply With Quote
Old March 28th, 2013, 08:29   #2
Lightflyer1
Lightflyer1's Avatar
Plenty of threads here already about this. Do top or bottom whichever you prefer. What ever you lift with the car needs to be level to drain properly. Pela seems to be the prefered device for extraction.
http://www.goodboatgear.com/detail/1...FUGrPAod028ARw
2015 Beetle TDI.
Old March 28th, 2013, 09:55   #3
Softrockrenegade
Softrockrenegade's Avatar
Top extraction with a pela 6000 pump is my preferred method.
Softrockrenegade is offline   Reply With Quote
Old March 28th, 2013, 13:51   #4
South Coast Guy
Fuel Economy: Good
Where are you dumping your used oil?
South Coast Guy is offline   Reply With Quote
Old March 28th, 2013, 13:53   #5
Softrockrenegade
The closest storm drain , naturally!
Old March 28th, 2013, 13:58   #6
Lightflyer1
I dump mine at WalMart or any of the Jiffy places. Seems like there was some legislation that required them to accept used oil from anyone. I don't know if it was only local/state/national though.
2015 Beetle TDI.
Old March 28th, 2013, 15:17   #7
upsbroke
upsbroke's Avatar
Fuel Economy: NB-52 hwy
Default waste oil
Around here, alot of the shops use waste oil for heating and they are more than glad to take my used oil!
upsbroke is offline   Reply With Quote
Old March 28th, 2013, 18:56   #8
BlownBusa
BlownBusa's Avatar
^ YUP! My buddy uses a waste oil heater at his shop. Neat!
P.S. I'm currently 6 years down in the brown truck
2012 Passat TDI SE+ roof/nav/fogs/DSG
2000 Jetta TDI with all the fixin's (sold to a JARHEAD)
2004 GTO goes "potato potato"
'99 Turbocharged BigBore Hayabusa 300+HP(for now)
BlownBusa is offline   Reply With Quote
Old March 28th, 2013, 19:49   #9
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
I've done my own 10K and 20K changes on the NMS. At 10K I pulled the plug first and went topside with my Pela to see what was left. I can tell you you're not going to get much more than a couple of ounces (if that) out of the filter housing and pan. I decided to go bottom side only on the 20K.
I experimented the other way around several years ago with my Golf. I did topside first, putting the Pela tube all the way to the pan, then getting everything I could out of the filter housing and cooler. After I got every bit I could, I then dropped the plug. I'd say 1/3 quart was left.
So, IMHO, if you have to pick one, go bottom side for maximum oil removal. Why fight gravity?
Regarding oil disposal, Delaware has free oil collection stations at the many recycling centers all over the state. Free service (well, after your tax money pays for it of course).
And a Mk7 GTI that's faster, but more thirsty.
Blue_Hen_TDI is offline   Reply With Quote
Old March 29th, 2013, 05:44   #10
Rico567
Here in IL, anyplace selling motor oil has facilities for collecting it (and this may be the law). All I do is take my used oil jug in and they have a tank in back at Auto Zone, Advance, or O'Reilly. Sometimes you have to take it back and empty it yourself (take paper towels or rags!) and sometimes they do it for you. Their attitude tends to be better if you buy your new oil there.
"I reject your reality and substitute my own."
- Adam Savage
Rico567 is offline   Reply With Quote
1st DIY oil change alcampbell TDI 101 14 October 8th, 2012 09:33
First Oil Change Experience (DIY) canux VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 16 August 26th, 2010 12:04
First DIY oil change... Cailean VW MKIII-A3/B4 TDIs 6 June 12th, 2006 13:42
what do i need for DIY oil change? oj1111 VW MKIV-A4 TDIs (VE and PD) 11 March 24th, 2006 22:06
DIY Oil Change -- What size Allen Wrench for the Oil Drain Plug? TEXAS_TDI VW MKIV-A4 TDIs (VE and PD) 40 August 8th, 2002 13:10
Page generated in 0.13764 seconds with 10 queries
[Output: 96.58 Kb. compressed to 81.92 Kb. by saving 14.66 Kb. (15.18%)]
