Old March 21st, 2013, 07:16   #1
Othermark
TDI(s): MK4 Jetta 03
Default 98 Audi A6 Quattro Wagon TDI Conversion.
Through family I have been passed the Audi wagon which is not in running anymore for various reasons. I really enjoy a TDI just for the basic three reasons, performance, longevity, and economy and I really like the Audi A6 with its space and rear viewing 3rd row. Since I got this thing for nothing I was wondering would it even be worth converting? I would really like to swap this thing over to a manual Quattro with a TDI power plant but I don't know where to start. First things first. Getting all other systems to function properly.
Right now the car has the following issues.
- Leaks coolant
- Power steering is going out
- Sun roof does not operate.
- Front windshield is smashed in
- Half the dash does not light up
- Stereo system is locked
- Front end bumper is coming off
Second, what parts do I need to locate in order to convert this A6 Quattro in a manual TDI?
Any thoughts would be appreciated.
Regards,
Mark
Othermark is offline   Reply With Quote
Old March 21st, 2013, 08:40   #2
Scott_DeWitt
Scott_DeWitt's Avatar
- Leaks coolant
Regards,
Mark
A TDI swap isn't going to fix any of the thing you mentioned.. Might want to consider another host.
Is yours a C4 or C5?
As far as the swap goes you will need:
Engine
Transmission
Clutch
Mounts
Driveaxles
Wiring harnesses
Computers
Lots of time
Fuel tank and lines
engine accessories etc.
www.advancedautomotion.com
Scott_DeWitt is offline   Reply With Quote
Old March 22nd, 2013, 08:14   #3
Othermark
The car is a C4 wagon. I kinda figured the majority of the problems are unrelated to a swap. I was more interested in knowing what engine and transmission should I be looking for in order to do the swap. That is assuming the swap is even feasible.
Old September 8th, 2013, 02:36   #4
ecodiesel1
TDI(s): 97 Jetta
Hey,
So did you ever do the swap? I don't have anything yet, but this is the exact swap I have been pondering for a little while. I have been hoping that someone would plow into the back of my mk3 TDI so I can use it as a donor... but no luck. Anyway, if you did it or are still looking to, we should talk.
-Nando
Drivers: 97 Jetta 1.9 TDI; 84 Rabbit L 1.6 IDI NA; 85 Audi 4kq
Projects: 83 Vanagon Westfalia 1.6 NA to TD
; 81 Audi 5k 2.0 NA to TD
ecodiesel1 is offline   Reply With Quote
Old September 8th, 2013, 07:26   #5
bbob203
Fuel Economy: 38-42
Im thinking of doing an a6q swap as well in the future would love to get some good discussion going.
bbob203 is offline   Reply With Quote
Old September 18th, 2013, 06:43   #6
chrisroser
chrisroser's Avatar
I recently picked up an 04 Audi allroad. 2.7t BEL with a bad ZF hp19 trans.
Motor runs great for now and overall the car is in great shape. Other than a timing belt svc and a upper reseal along with all the usual repairs needed on a car with 94k miles she's good to go.
Plans are for an 01E TDI 6 spd trans swap using a wavetrac front diff. and retaining the cooler. Been pricing parts from Frans and Scotty@Advanced Automotion.
After the trans conversion I plan to run it until I can locate a decent TDI motor and all the needed pieces for the diesel conversion.
The 2.5L euro TDI seems like the motor of choice but maybe the euro 2.7TDI from a late model A6 might make sense. I'll need a lot of stuff from the donar car so maybe buying a whole wreck and having someone dismantle it might make sense. With the restrictive import rules here in the US the motor will have to be broken down into parts but thats ok because I'd probably do it anyway.
Anyone have first hand experience with the euro 2.7TDI?
05 B5.5 BHW, 05 B5.5V BHW, 05 NB BEW, 98 HD Streetstalker, 99 HD XL1200C, 99 JD 270 Skid Steer, 2001 allroad APB, 04 allroad K04 Stage 3 BEL- The UBERWGN. 2001 B5 S4, 2003 F-350 7.3L Super Duty.
chrisroser is offline   Reply With Quote
Old September 18th, 2013, 10:01   #7
Zeitgeist
Zeitgeist's Avatar
I have a '94 100CSQ Avant (C4) with a pre-OBDII AAH V6 and 4HP18FLA electronic auto. Any chance that I can swap in an ALH and get the ECU to properly communicate with this trans ECU? These are a really nice chassis and unfortunately they weren't offered with the AEL engines over here in the states.
'87 300TD OM606t
'90 300D OM602t
'89 Vanagon Bluestar ALH mTDI
'01 Eurovan Weekender AXK --> (ALH Syncro?)
Past: '96 Passat 1Z
Zeitgeist is offline   Reply With Quote
Old September 19th, 2013, 22:37   #8
DangerBoy
The swap is possible, but I would like to also say what Scott said: You will need lots of time. I had a complete running C4 TDI sedan as a donor for my C4 Wagon and you would think that swap would be a breeze right? I mean, both cars are C4, not much work...
Prepare to remove the entire drivetrain, fuel system, interior, HVAC system (The V6 uses totally different AC system lines and routing than the 5 Cylinder).
Then there is the wiring, if you want to do a nice job you better feel comfortable with pulling both the engine and intrument main harnesses out and completely going through them. Not a big deal but time consuming to do properly. There might be a quick and dirty way to do such a swap, but I didn't go that way and I imagine you would have no end of future problems if you did. There is a reason most people don't finish their swaps... if the idea is to save money, which is why most people drive diesels, swapping is not the best way to achieve this goal IMHO. Just get a Jetta or Golf and put good tires on it, or import a quattro TDI.
Only go for the swap if you truly love the car and love the project so much that money doesn't matter all that much. Just my opinion of course. I'll be singing a happier tune once I'm finished mine I'm sure.
Dave
DangerBoy is offline   Reply With Quote
Old September 19th, 2013, 22:52   #9
Zeitgeist
Zeitgeist's Avatar
I've completely stripped a C4 twin to my car, so I'm pretty familiar with how they're constructed. I briefly considered swapping the AAH into my van, so I dissected the engine management wiring harness and peripherals before abandoning that plan in favor of an ALH swap. You're right it is a big job, and I still need to finish my van project, but...it's fun to dream
'87 300TD OM606t
'90 300D OM602t
Past: '96 Passat 1Z
Old September 20th, 2013, 01:23   #10
Frans
TDI(s): Golf MK2 TDI
I would recommend the 5 cyl inline TDI quattro setup for the C4.
Frans is offline   Reply With Quote
Audi A6 C5 1.9TDI Quattro conversion whoo-kid TDI Power Enhancements 10 January 31st, 2015 15:13
Audi A6 Tdi quattro in PA conejo_a_cuatro Sightings 0 September 18th, 2012 12:33
Off Topic: Audi A6 Quattro Wagon... SyNtAxx TDI 101 13 October 14th, 2008 18:35
will it connect? TDI in Audi A6 wagon with 2.8 v6 quattro ta79pr TDI Conversions 5 November 8th, 2007 09:00
(NON-TDI) 1996 Audi A6 Quattro Wagon jjvincent TDI Cars for Sale/Wanted 4 March 15th, 2004 13:25
Page generated in 0.15502 seconds with 10 queries
[Output: 98.25 Kb. compressed to 83.71 Kb. by saving 14.54 Kb. (14.80%)]
