Old March 15th, 2013, 18:52   #1
sareljr
Fuel Economy: N/A
Default Emission Control
Does the mkiv or mkv Jetta TDI have any emissions controller like an EGR Valve, or DPF?
sareljr is offline   Reply With Quote
Old March 15th, 2013, 18:53   #2
jcrews
jcrews's Avatar
TDI(s): 2003 Golf
Both have EGR, 3 way catalyst, and closed CCV.
mkv additionally has an oxygen sensor.
mkv + CR (2009-2010) has DPF, CAT, EGR, NOx, additionally
Yard sale - misc. mk4 TDI parts.
jcrews is offline   Reply With Quote
Old March 16th, 2013, 19:17   #3
sareljr
Fuel Economy: N/A
What is a CCV? Is the EGR prone to clogging and failing or is it necessary?
Old March 16th, 2013, 20:18   #4
Cory F
TDI(s): 2002 Jetta
Crank Case Vent
Yes, EGR will cause clogging in many cases.
Cory F is offline   Reply With Quote
Old March 17th, 2013, 08:56   #5
sareljr
Fuel Economy: N/A
Is there an EGR delete then? I know on the diesel trucks you get DPF and EGR deletes.
Old March 17th, 2013, 09:12   #6
crankme69
crankme69's Avatar
TDI(s): 1996 Passat
Careful any subject pertaining to emissions or saving trees is not allowed here...friggin tree huggers!
crankme69 is offline   Reply With Quote
Old March 17th, 2013, 09:28   #7
GoFaster
Moderator at Large
Only if you attempt to remove or circumvent does the discussion potentially cross the line.
Back to the original question, it goes more by model year than by vehicle generation, and the following discussion applies to North American market only.
Through 2006, all TDI engines had crankcase ventilation and EGR systems, and an oxidizing catalyst. Around 1998, the EGR became "cooled EGR" with a heat exchanger transferring the exhaust heat into the coolant before blending with the intake air.
The "pumpe-duse" engines (which started in 2004 - installed in both Mk4 and Mk5) added a lambda sensor in the exhaust for fine-tuning the operation of the EGR system. The 2006 model adds a changeover valve for the EGR cooler so that it can operate either in cooled-EGR mode or uncooled-EGR to help with warm-up.
In the North American market, there was no 2007 or 2008 model year TDI.
The common-rail "clean diesel" engine 2009 and onward has the following main emission control systems, which have thoroughly been discussed elsewhere in these forums.
- High pressure EGR
- Low pressure EGR
- Oxidizing catalyst
- DPF (diesel particulate filter)
- Lean NOx catalyst without requiring AdBlue (Golf/Jetta/New Beetle) or SCR NOx catalyst requiring the use of AdBlue (Passat and all larger models)
- H2S catalyst
All of this is on top of the ECU calibration and the choice of injectors and fuel delivery methods. The 2009 models are very complex.
We already know that the upcoming EA288 TDI engine (due in Mk7 Golf) incorporates these systems into the design and simplifies them by eliminating some hardware, as opposed to the "added-on" arrangement that forces quite a number of compromises.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old March 17th, 2013, 10:01   #8
sareljr
Fuel Economy: N/A
Cool
No worries, I love the smoke from a diesel, and want to find out how to get smoke from the stock engine.
Old March 17th, 2013, 10:36   #9
Roshermoore
Default Smoke not needed!
FWW We need to be showing the public that diesels are no longer smoky, noisy, smelly engines. We should be trying to convince them that the new generation of engines no longer do any of these things.
09 Jetta Sportwagen, Blue Graphite Metallic, DSG, Sunroof, Rubber mats, Zeta Products body color side moldings, Body color door edge guards, VW front and rear Splash Guards, Clear rear bumper protector, 8" "Stubby" antenna. Build Date 11/08
Roshermoore is offline   Reply With Quote
Old March 17th, 2013, 12:02   #10
No More Buffalo
If you want smoke, you're barking up the wrong tree. It ain't a friggin' Cummins.
No More Buffalo is offline   Reply With Quote
Old March 17th, 2013, 12:18   #11
crankme69
crankme69's Avatar
TDI(s): 1996 Passat
Question
Mine smokes when the go pedal is too the floor not alot but some. Ya mean it ain't supposed to...?
Old March 17th, 2013, 12:35   #12
JSWTDI09
JSWTDI09's Avatar
Many older diesels smoke a bit. However, one of the main reasons we drive TDIs is for the economy. Smoke = wasted fuel. You get smoke when your fuel/air ratio is too heavy on fuel (not enough air for the amount of fuel injected). A well running diesel will produce very little smoke. If your car puts out much smoke; you either need less fuel or, even better, more boost (maybe a bigger turbo).
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old March 17th, 2013, 14:50   #13
PDJetta
PDJetta's Avatar
The A4 with the BEW has an O2 senser too (2004 on).
--Nate
Old March 17th, 2013, 17:28   #14
GoFaster
Moderator at Large
We do not want to promote this sort of environmental irresponsibility here.
Brian P.
Old March 17th, 2013, 17:36   #15
fnjimmy!
Chucklechump
fnjimmy!'s Avatar
TDI(s): TDIdiot
Set it on fire. The smoke you get is amazing.
Cheers,
Jim
fnjimmy! is offline   Reply With Quote
16824 - EVAP Emission Control Sys: Malfunction mtltdi OBD Scanners 5 May 24th, 2006 16:54
Emission control issues with chip upgrade? Alpha7 TDI Power Enhancements 6 September 20th, 2004 14:42
Question on BioD, and emission control devices godlike242 Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 April 14th, 2002 01:59
Emission Control Resources SkyPup TDI (Diesel) Emissions 0 May 7th, 2001 09:35
Maintaining Intake System Deposits to Improve Performance and Emission Control Turbo Steve VW MKIV-A4 TDIs (VE and PD) 5 February 14th, 2000 18:33
Page generated in 0.16270 seconds with 10 queries
[Output: 124.72 Kb. compressed to 103.65 Kb. by saving 21.07 Kb. (16.89%)]
