Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old March 14th, 2013, 10:39   #1
mrrhtuner
mrrhtuner's Avatar
Default Jetta TDI, Exhaust pipe broken after cat
Hey everybody, I looked under my 00 jetta TDI and noticed that the exhaust is broken just past the catalytic converter.
I used to deal with Honda's a fair bit so I know the exhaust system is always a bolt up type system.
Looking at the image below that I found of a mk4 jetta tdi exhaust, it seems that the cat piece and the midpipe is welded up...is that how it comes from the factory?
So would my best option be is to take the car to a muffler shop and have them just weld back in another pipe connecting the cat and the rest of the original mid-pipe?
I was thinking of getting a used downpipe/cat and bolt it on but it seems like I would have to get the mid-pipe welded onto the cat anyways.
Image for reference
mrrhtuner is offline   Reply With Quote
Old March 14th, 2013, 10:53   #2
ic_ou812
Common occurrance. Same thing happened to me 4 years ago. Muffler shop welded a new piece in - $30 done.
2002 Jetta TDI GLS Reflex Silver - Sprint 520's, EVO Skidplate, Scangauge II, NewSouth Indigo Boost Gauge, Dawes Device
1979 Rabbit Diesel L - went to the boneyard long ago
1971 Super Beetle - a fun summer car, sold to some high school kid
ic_ou812 is offline   Reply With Quote
Old March 14th, 2013, 11:01   #3
mrrhtuner
mrrhtuner's Avatar
That's what I figured.
Old March 14th, 2013, 11:02   #4
imo000
imo000's Avatar
^^^^^ what he said ^^^^^
imo000 is offline   Reply With Quote
Old March 14th, 2013, 12:24   #5
LNXGUY
LNXGUY's Avatar
Happened to my old 99.5 $20 and 15 mins later a shop put in a new piece. Simple stuff.
Bill
LNXGUY is offline   Reply With Quote
Old March 14th, 2013, 17:53   #6
ludikris
ludikris's Avatar
TDI(s): Jetta mkiv
gut that cat with an air chisel while it's out.. better than getting a bigger diameter exhauset for EGT temps and performance
Toronto old ride: 2000 black tdi 330 km/customized vnt-15 turbo/RC-3+/sprint 520's NEW RIDE -2015 JETTA TDI HIGHLINE
ludikris is offline   Reply With Quote
Old March 15th, 2013, 05:39   #7
fierodough
TDI(s): Beetle
Fuel Economy: 5.7l/100km
I was thinking of gutting my cat-converter as well... Would the car smoke more? Where I'm at, we do e-tests through the OBDII... So no check engine light and sensors pass the rediness, you are good to go... but if it smokes bad.... they do a more detailed inspection...
fierodough is offline   Reply With Quote
Old March 15th, 2013, 07:00   #8
LNXGUY
LNXGUY's Avatar
Gutting the cat is almost worthless. Guys see maybe a 1hp increase. Not worth the hassle if you ask me..
Bill
Old March 15th, 2013, 08:00   #9
Zedbra
Zedbra's Avatar
Unless you need to pass visual inspections.
For my $30, the cat was left on the floor of the shop.
2005 Jetta TDI GLS: VNT17VB, 3 Bar, Malone Stage 4, BiXenon retros, OEM Fogs, ST Coilovers, OZs
Zedbra is offline   Reply With Quote
Old March 15th, 2013, 08:20   #10
LNXGUY
LNXGUY's Avatar
I don't run either (cat or muffler) but wasting your time gutting the cat is just that, a waste of time.
Bill
Old March 16th, 2013, 06:11   #11
imo000
imo000's Avatar
Catslytic converters are worth a lot of money, even if they aren't working. If you really hell bent on getting rid of it, take it to a scrap yard.
Old March 16th, 2013, 07:52   #12
ludikris
ludikris's Avatar
TDI(s): Jetta mkiv
gutting the cat is better than a bigger exhaust... I asked Jeff from Rocketchip the same and he agreed.. gut your cut is cheaper and more efficient than a bigger diameter down pipe with a cat on it.
Old March 16th, 2013, 08:54   #13
LNXGUY
LNXGUY's Avatar
You'd be better off chopping off the cat, selling it and installing a straight pipe in its place. Hell, you'd probably make $$$ doing that, lol.
Bill
Exhaust Broken pre-Cat; Downpipe Needed? Lex4TDI4Life VW MKIV-A4 TDIs (VE and PD) 2 July 11th, 2011 10:25
Broken exhaust pipe any suggestions? kc5833 TDI 101 16 March 28th, 2011 10:48
NB Exhaust pipe rusted at cat TDIfor TDI 101 4 August 10th, 2010 17:51
What are my options - broken flex pipe/exhaust pipe GregK VW MKIII-A3/B4 TDIs 14 August 10th, 2008 19:32
Exhaust pipe broken wolfsburg VW MKIV-A4 TDIs (VE and PD) 3 March 5th, 2007 17:34
Page generated in 0.16088 seconds with 10 queries
[Output: 115.48 Kb. compressed to 96.50 Kb. by saving 18.98 Kb. (16.44%)]
