Old March 9th, 2013, 11:36   #1
PHOTOGUY1000
Default 1998 Jetta Driver side Cv Boot Repair?
So I think what I have here is an inner CV boot that is torn? Can I make the repair is the question... Struts, Alternator etc. type repairs I have no trouble with but I am no mechanic? I have air tools & am no afraid to get dirty. If I took it to a shop what would I expect to pay?
PHOTOGUY1000 is offline   Reply With Quote
Old March 9th, 2013, 11:57   #2
TronDD
TDI(s): 98 Jetta
It's not too hard to do. You need a special bit for the 6 bolts to get the axle out and snap ring pliers that expand the ring (if I remember correctly, double check).
For me, the inner CV slipped right off, new boot, regrease, put it back in and all done.
Tim.
'98 Jetta TDI
TronDD is offline   Reply With Quote
Old March 9th, 2013, 11:59   #3
PHOTOGUY1000
Anything else I should replace during the job?
Old March 9th, 2013, 14:18   #4
PHOTOGUY1000
Put the car up on ramps wanted to make sure the other side wasn't torn as well... boot looks great problem is I discovered the seal to the transmission on the passenger side seems to be leaking... is that an easy repair?
Torn CV Boot Repair Options To DIe for TDI 101 13 February 7th, 2012 17:10
WTB 1998 Jetta Driver's Door Boot & Connector thebigarniedog Private TDI Items for Sale/Wanted 1 August 18th, 2011 04:04
Replacing Driver Side CV Boot Jones6826 TDI 101 2 November 2nd, 2010 16:23
Inner CV Joint boot repair jokila TDI 101 11 November 23rd, 2007 21:33
1998 Jetta Driver's Outer CV Boot RR Rudolf Diesel VW MKIII-A3/B4 TDIs 2 September 8th, 2003 19:37
Page generated in 0.13042 seconds with 10 queries
[Output: 61.42 Kb. compressed to 55.00 Kb. by saving 6.42 Kb. (10.45%)]
