Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI News/Tech
TDI News/Tech This Forum is for the posting of TDI news related items.
Closed Thread
Old February 26th, 2009, 05:46   #1
BeetleGo
Pre-Forum Veteran Member
BeetleGo's Avatar
Fuel Economy: 39/46, usually 41
Default Seventh-generation VW Golf
I just read this in Auto Express:
http://www.autoexpress.co.uk/news/au...LC-Newsletters
There are pictures in the link. I like it ok, but wish the back weren't so fussy....
Bold new Golf gets into shape
It’s only just launched MkVI – but VW is already working on stylish replacement.
Text: Jack Rix / Photos: Poblete25th February 2009
it’s time to face the future at Volkswagen! The MkVI Golf has only just gone on sale, but the firm is already working on its replacement, due in 2012 – two years sooner than anticipated.
Our illustrations show how the MkVII is likely to look. And as usual with VW’s most important model, the styling is evolutionary.
But it’s under the skin where this model plans to break new ground – leading the way in how cars of the future will be made.
Reports suggest the MkVII will differ so radically from its predecessor that it bears comparison to the giant leap Ford made from the Escort to the Focus in 1998.
Bucking the trend for ever-increasing dimensions and kerbweights, the newcomer will rely on a smaller platform than the current car, with many components borrowed from the forthcoming Polo. Lightweight body panels will reduce weight, so similar performance can be achieved from smaller-capacity forced-induction engines. And diesels are expected to make up an even bigger percentage of sales than at present.
VW’s highly efficient twin-clutch DSG gearbox will be offered across the range as well, while advances in its resilience mean high-powered versions such as the GTI will benefit from seven ratios instead of six for the first time.
Hybrid
But it’s not just conventional engineering that’s going to make the Golf the greenest in its class – the hatch is set to join the hybrid party. We tried a prototype of VW’s Twin Drive technology last year (Issue 1,024), although it won’t go into full production until the MkVII emerges.
It combines a frugal 1.5-litre diesel unit with three compact electric motors, and the plug-in drivetrain can operate on battery power alone below 31mph for around 30 miles. Above that speed, it works in tandem with the oil-burner, and takes over entirely at motorway speeds. The result is a startling 113mpg – more than twice what a standard 2.0-litre TDI can muster.
Beyond that, VW is already working on an HCCI engine – a petrol unit that thinks it’s a diesel. By ditching the spark plugs, this blends the fuel efficiency of a diesel with the cleaner emissions and free-revving nature of a petrol.
And as HCCI engines run most efficiently at constant rpm, there’s even talk of using it to extend the range on a plug-in hybrid powertrain – giving a similar set-up to the Chevrolet Volt.
But one thing is for certain: for the first time, VW’s focus will be on fuel efficiency, recyclability and environmental credentials above all else.
~BeetleGo
~BeetleGo(ne)
Biodiesel: carbon-responsible fuel. User of ASTM certified biodiesel from commercial pumps since 2002.
'98 New BeetleGo R.I.P. (Parts now living in countless New England club cars)
'05 5sp Golf GLS TDI - Rocket Chipped to 1.5, NB hoop style headrests, Mud Flaps, Euro style sideview mirrors (They're blind spotless!), and Koni FSD's (Talk about smoothing the bumps AND tightening the curves!!!)
Don't know how to use the search function? Click Here!
BeetleGo is offline
Old February 26th, 2009, 12:06   #2
jettafock
jettafock's Avatar
Fuel Economy: 34.5 39 44
Default Say hello to the MKVII Golf
The MKVI isn't even out yet but VW is already working on the MKVII. It will come with the new VW Twin Drive Technology (hybrid diesel).
its time to face the future at Volkswagen! The MkVI Golf has only just gone on sale, but the firm is already working on its replacement, due in 2012 two years sooner than anticipated.
Our illustrations show how the MkVII is likely to look. And as usual with VWs most important model, the styling is evolutionary.
But its under the skin where this model plans to break new ground leading the way in how cars of the future will be made.
VWs highly efficient twin-clutch DSG gearbox will be offered across the range as well, while advances in its resilience mean high-powered versions such as the GTI will benefit from seven ratios instead of six for the first time.
Hybrid
But its not just conventional engineering thats going to make the Golf the greenest in its class the hatch is set to join the hybrid party. We tried a prototype of VWs Twin Drive technology last year (Issue 1,024), although it wont go into full production until the MkVII emerges.
It combines a frugal 1.5-litre diesel unit with three compact electric motors, and the plug-in drivetrain can operate on battery power alone below 31mph for around 30 miles. Above that speed, it works in tandem with the oil-burner, and takes over entirely at motorway speeds. The result is a startling 113mpg more than twice what a standard 2.0-litre TDI can muster.
Beyond that, VW is already working on an HCCI engine a petrol unit that thinks its a diesel. By ditching the spark plugs, this blends the fuel efficiency of a diesel with the cleaner emissions and free-revving nature of a petrol.
And as HCCI engines run most efficiently at constant rpm, theres even talk of using it to extend the range on a plug-in hybrid powertrain giving a similar set-up to the Chevrolet Volt.
But one thing is for certain: for the first time, VWs focus will be on fuel efficiency, recyclability and environmental credentials above all else.
Link to article:
2004 Jetta TDI 17/22, RC3, 3bar, 2.5 DP no cat with magnaflow muffler after DP to 2.5 straight pipe, 17" Monte Carlo wheels, Eibach Pro-Kit Springs, Koni Yellow's, 337 front/rear brakes, GLI brushed alum. interior trim.
http://www.cardomain.com/ride/788097 2009 TDIFest Peoples Choice Winner
jettafock is offline
Old February 28th, 2009, 10:13   #3
Blue_Hen_TDI
Blue_Hen_TDI's Avatar
Can't say I'm a huge fan of that styling.
And a Mk7 GTI that's faster, but more thirsty.
Blue_Hen_TDI is offline
Old February 28th, 2009, 12:56   #4
Varkias
Varkias's Avatar
TDI(s): '02 Golf TDI
Fuel Economy: 46 MPG
I wouldn't worry to much about the styling, once we have seen the MkVI in person, I'm willing to bet that this is much more evolution then revolution when it comes here, which probably won't be until 2014 or later, if the timeline follows the MkV's. Then again, if it really is going to be ready that soon, we might just never see the MkVI at all.
Golfs aren't huge sellers here, and I'm sure they can get a little more life out of the GTI. And with the next jetta/passat/whatever being built here, for NA only, I don't see a big push for the MkVI at all.
I really wanted a MkVI TDI Golf/GTI though...
BBS, OMI, RC3 ASV, PP520, Smoke.
W h y s p a r k w h e n y o u c a n G l o w.
Varkias is offline
Old February 28th, 2009, 14:44   #5
vwmk4
vwmk4's Avatar
Say that it's not true. I think that the MKVI looks very good and have read some good reviews from Europe and England. The MKV production has stopped and for sure NA will go Golf less until 2014.
FIGHT THE right, BE IT BY DAY AND BE IT BY NIGHT
vwmk4 is offline
Old February 28th, 2009, 14:53   #6
PlaneCrazy
TDI(s): Gone...
VW Canada has already put out a press release that we'll get the Mk VI for the 2010 model year, including a TDI!
Mike
Hers: '17 Golf TSI Sportwagen 5-MT
His: '18 Sportwagen 6-MT 4MOTION
'16 Marinoni Genius/Campy Record, '94 Marinoni Special/Campy Record
PlaneCrazy is offline
Old February 28th, 2009, 15:26   #7
vwmk4
vwmk4's Avatar
True and the Golf 2.0L TDI was at the Chicago Auto show.
vwmk4 is offline
Old February 28th, 2009, 18:25   #8
chewy
TDI(s): None
They just pshoped the front and the rear of the VW Bluesport concept. Very poor job, the MKVII will likely look a lot different than that. And VW will have a 1.6 TDI, not sure where they got ideas about a 1.5 liter TDI.
In other VW news, VW has put an advertising sign (at the Geneva autoshow I think) of the next gen Polo before it has officially unveiled it.
This gives a much better indication of how future VWs will look like as its teh first clean sheet design from Walter de Silva who will design all future VWs.
chewy is offline
Old February 28th, 2009, 19:35   #9
Mcgink
Mcgink's Avatar
To me, It looks like a Nissan Versa.
Mcgink is offline
Old March 4th, 2009, 04:35   #10
Tom Servo
Tom Servo's Avatar
Fuel Economy: ~39 mpg :(
I was thinking more along the lines of a more-angular Focus.
~Zach
alabama broadcast media page
Tom Servo is offline
Old March 8th, 2009, 17:36   #11
boutmuet
boutmuet's Avatar
Fuel Economy: 34-40 MPG
It screams Honda Fit, though I don't think the styling is too bad.
boutmuet is offline
Old March 9th, 2009, 02:22   #12
Erdrick
TDI(s): 1998 Jetta
Huh, I thought that it looked like a Matrix.
Erdrick is offline
Old March 9th, 2009, 08:15   #13
frugality
frugality's Avatar
Fuel Economy: 33mpg
Versa, Focus, Fit, Matrix. In other words, the MkVII Golf looks....generic? Nondescript?
Personally I like it, though the angle of the taillights looks a little odd, and doesn't seem to really match any other styling cues on the car. Either the MkVI or the MkVII is better than the lump-of-putty look of the MkV, though.
2016 GTI SE 6M with lighting package, runs on RUG, has spark plugs? AVERAGING 33mpg!
2010 Jetta Sportwagen TDI, 197,089 miles, Silver, manual, 17" Goals, original brakes -- GONE; REPURCHASED BY THE MANUFACTURER.
frugality is offline
Old March 9th, 2009, 08:36   #14
PlaneCrazy
TDI(s): Gone...
Sorta like the new Polo on steroids.
Mike
Old March 9th, 2009, 08:56   #15
Tom Servo
Tom Servo's Avatar
Nondescript. Kinda like what they did to the Jetta.
~Zach
Closed Thread
News about VW next generation of Tdi engines LRTDI TDI News/Tech 97 August 29th, 2013 12:39
next, next generation of vw tdis...more than meets the eye chittychittybangbang VW MKIII-A3/B4 TDIs 1 July 19th, 2007 00:56
Vw Calls For Preferential Status For Second-generation Biofuels VW Derf TDI News/Tech 72 September 22nd, 2006 08:05
VW unveils next-generation engine azbioguy General VW Discussion 2 May 29th, 2004 18:28
Anybody know when next Generation VW's land???? tdi90hp General VW Discussion 0 February 6th, 2002 08:04
Page generated in 0.18325 seconds with 10 queries
[Output: 130.73 Kb. compressed to 109.34 Kb. by saving 21.39 Kb. (16.36%)]
