Old March 2nd, 2013, 04:37   #1
Cerberus
TDI(s): 1999 Jetta
Question Radio anti-theft code won't work
I have a 1999 (early model) Jetta TDI. After having to disconnect the battery for some work I find the radio code will not work. I am entering the right code as I have done many times before but it only returns to SAFE and after 2 tries you have to wait an hour to try again. I'm stumped.
Any suggestions will be greatly appreciated.
Cerberus is offline   Reply With Quote
Old March 2nd, 2013, 05:51   #2
jellendc
This worked on my MK4, not sure about yours but it may be worth a try. Got the tip from a fellow forum member...
Pull out fuse 42 and 37 from the drivers side door fuse panel, with the key in the on position. This will reset the radio
jellendc is offline   Reply With Quote
Old March 2nd, 2013, 14:42   #3
Cerberus
TDI(s): 1999 Jetta
Thanks for the info. However my fusebox is different having only 22 fuses, no. 22 is for the radio. Tried pulling it out but still no change.
I appreciate your attempt to help. Thank you.
Old March 2nd, 2013, 23:24   #4
Fixmy59bug
Fixmy59bug's Avatar
Fuel Economy: Check my Fuelly Tag for most up-to-date numbers
Are you sure the code you have is correct?
It seems as though you are using the correct procedure but the radio is not accepting the code since it is locking down after entering the code twice.
Double check the 14 digit serial number on the radio card to the serial number on the radio.
If they do not match, the code is wrong.
Fixmy59bug is offline   Reply With Quote
Old March 3rd, 2013, 03:51   #5
vwa1
When all else fails, i find that beating the @%$%$ of something with a 12lb sledge hammer is at the very least satisfying, if not always the most productive. You may want to save this method as a last resort.
vwa1 is offline   Reply With Quote
Old March 3rd, 2013, 05:52   #6
joetdi
I've had radios that would not take the correct code and never got them working.
You may want to try a full discharge and try again though.
joetdi is offline   Reply With Quote
Old March 4th, 2013, 04:52   #7
Cerberus
TDI(s): 1999 Jetta
Fixmy59bug: I'm sure it is the right code as I have it written on the visor and have used it many times before.
joetdi: Full discharge? Do you mean disconnect the battery and try again? I've already done that and no luck.
vwa1: Your hammer method is looking better all the time, I only have an 8 pound sledge hammer but I think that should do the trick.
Thanks to all.
inputting radio anti theft code studebaker VW MKV-A5 Golf/Jettas 13 October 14th, 2012 04:56
Anti-Theft Radio Code smorris62 TDI 101 0 January 28th, 2006 09:40
Anti-theft radio code GladesTDI General VW Discussion 6 July 5th, 2002 00:25
Anti theft radio code ckimball tdi VW MKIV-A4 TDIs (VE and PD) 5 August 11th, 2000 09:45
Radio Anti-Theft Code, where to find it? Weasle543 VW MKIV-A4 TDIs (VE and PD) 8 May 4th, 2000 10:50
Page generated in 0.14904 seconds with 10 queries
[Output: 77.54 Kb. compressed to 67.36 Kb. by saving 10.18 Kb. (13.13%)]
