Old March 1st, 2013, 08:51   #1
PaulB
Default Misfueling guard
I had some diesel in cans and decided to use it and to get fresh diesel in those cans. Then I ran into the misfueling guard.
I managed to get 5 gallons in with only a little spilling. My old B4 didn't have this problem. Is that guard really a useful advance that prevents misfueling, or is it just BS? How does the thing work anyway? How do you guys fill with cans, or have you given up on that?
PaulB is offline   Reply With Quote
Old March 1st, 2013, 08:59   #2
spartanmanor
Never filled up with cans. I would be worried about water contamination but that is just me.
spartanmanor is offline   Reply With Quote
Old March 1st, 2013, 09:40   #3
paulk124
paulk124's Avatar
Just remove the fueling guard. I did and it's a fairly easy process. Here's the thread with details:
http://forums.tdiclub.com/showthread...=364065&page=4
2013 Passat SE TDI 6M
2004 Honda Accord EX 2.4L I4 5M, 33.4 MPG over 97341 miles (total loss)
2004 Dodge Ram SLT 5.9L I6 6M, 17.4 MPG over 31005 miles
1992 Honda Civic VX 1.5L I4 5M, 46.6 MPG over 131202 miles (sold)
paulk124 is offline   Reply With Quote
Old March 1st, 2013, 10:03   #4
Lightflyer1
Lightflyer1's Avatar
But keep it handy as it goes back in easily and you may want to put it back before heading to the dealer. A funnel will also work.
2015 Beetle TDI.
Old March 1st, 2013, 11:35   #5
skinnyb
TDI(s): 2013 JSW TDI
Fuel Economy: Slightly north of 40 MPG
X2. My Passat did not have one but my new JSW did. First thing I removed (well second, I removed the stupid dealer advertisement badges first)... You can actually see the fuel now when filling up and the nozzle goes in without having to hold your mouth a certain way...
2015 Passat 1.8T Limited Edition
2013 JSW TDI DSG Malone 2.0 Eco, Tint, Wheels, Etc...
skinnyb is offline   Reply With Quote
Old March 1st, 2013, 12:55   #6
unixb0y
The dealer wanted $22CDN for their bypass adapter.
I went to bmw and bought it for $12CDN (BMW P/N: 16.11.0.440.157).
IT looks like this(not my picture):
I wish vw had designed their misfuel adapter to screw on/off.
I drive in the city and generally fill up when the light goes on. I only plan on using the adapter if I have no other choice if I'm in the middle of nowhere.
unixb0y is offline   Reply With Quote
Old March 1st, 2013, 17:23   #7
psd1
Fuel Economy: See Fuelly link
No need to remove anything, just manipulate the mechanism with your fingers (10 & 2 i think) and push the flap in. It will stay open until you fill with a regulation size commercial nozzle.
psd1 is offline   Reply With Quote
Old March 2nd, 2013, 07:11   #8
50pascals
I have a long black funnel - I think I bought from Wal Mart. It had a narrow tip that I had already cut off. Works perfect - slides right in.
50pascals is offline   Reply With Quote
Old March 2nd, 2013, 12:48   #9
PaulB
Well I tried, but it defeated me. I assume you mean to push those black things (at 10 and 2) down (toward the tank) and then push the flap open? I could barely get two index fingers in to do that, and the flap was never released. I thought maybe they were supposed to move out rather than down, but they didn't want to go that way.
Old March 3rd, 2013, 08:52   #10
psd1
It sounds like you're almost there, it is a little tricky but it does work. I think I pushed the tabs in with two fingers on the same hand and then pushed the flap back with my other hand. It is good to know how to do just in case you need fuel and only have access to a smaller nozzle that won't open the flap.
Old March 5th, 2013, 15:58   #11
50pascals
This one:
http://www.walmart.com/ip/RhinoGear-...unnel/20440553
Cut it off @ the step. Perfect size.
Misfueling - A first... RT1 TDI 101 22 June 24th, 2013 17:54
misfueling guard failure? [solved - pump had a gas nozzle on it] afarfalla VW Passat Family (NMS and B7) TDIs (2012+) 38 September 23rd, 2012 21:01
MKVI (Skid Plate/Splash guard/Door Guard) - Local Source? hvcl Ontario 15 March 4th, 2012 07:17
Misfueling Prevention Joyrex VW Passat Family (NMS and B7) TDIs (2012+) 31 November 21st, 2011 10:07
Misfueling jamesgl Fuels & Lubricants 4 February 20th, 2005 18:03
Page generated in 0.13120 seconds with 10 queries
[Output: 101.54 Kb. compressed to 85.88 Kb. by saving 15.66 Kb. (15.43%)]
