Go Back   TDIClub Forums > Classifieds/For Sale/Wanted > Private TDI Items for Sale/Wanted
Private TDI Items for Sale/Wanted VW TDI/Diesel related items for wanted and for sale by private individuals. Group Buys and commercial posts should be in the "Vendor & GroupBuy" section.
Old February 24th, 2013, 17:38   #1
TDINIT
Fuel Economy: Heavy Footed
Default FS: BRM Engine Mount Bracket (EARLY STYLE)
SOLD >>>SOLD >>> SOLD
BEW/BRM Engine Mount Bracket
This is the "EARLY BRACKET" (VW # 03G 199 207 F)
Explanation from MyTurboDiesel >> http://www.myturbodiesel.com/1000q/a...ount-jetta.htm
$50 shipped in lower 48 states
TDINIT is offline   Reply With Quote
Old February 27th, 2013, 05:17   #2
TDINIT
This Bracket lets you change the Timing Belt WITHOUT removing the mounts...
Check the "myturbodiesel" link above for specifics!!
Old February 27th, 2013, 05:27   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
I think you have it backwards. The early BRM mount has the front upper ear mounted to the block in the middle of the belt path, same as the BEW, ALH, etc.
The later BRM bracket has that ear moved out and attached to the accessory bracket, right next to the alternator mount, outside of the timing belt path. Change happened in June of 2005 (this is even stated in the shop procedure for toothed belt replacement).
However, it makes no difference as the bracket needs to be moved in either case to slide the tensioner off the stud, unless you remove the stud with the tensioner, and that to me can be a bit of a pain.
The F suffix is the early one, replaced by the newer G suffix (and also requires replacement of 3 other parts, as noted in ETKA).
Your picture seems strange, though, as it clearly has the F on it, but is clearly the late mount (with the long reach to the accessory bracket on the one ear, same as this 2006 BRM Jetta I have in front of me).
So yeah, you could put your bracket on a VERY early BRM car I guess, but you'd have to change the other stuff, too in order to make it work. The early BRMs' accessory bracket has no threaded boss to attach that far point.
oilhammer
www.cardocautomotive.com
Old February 27th, 2013, 07:38   #4
oilhammer
oilhammer's Avatar
Upon further investigation, it would appear ETKA is wrong. Since this 3/2006 car here also has the F bracket. What doesn't make any sense, though, is that unless the German alphabet is different, F comes before G.
But that F bracket is clearly still the later wide stance version. Very few BRM cars have the short G bracket, because the A5 cars didn't come here until several months into the 2005 MY, and if they switched to the F bracket in June of 2005, that would mean that only about 3 months worth of cars would have had them... and only the BRM engine.
Personally, I've only ever seen TWO of these early mount BRM cars, and I regularly service a boatload of these cars. Hardly a day goes by without a BRM car on the docket here.
oilhammer
Old March 2nd, 2013, 05:33   #5
TDINIT
I Dont have it backwards
As you mentioned above ETKA Vs. Actual doesnt all ways match up...
I would usually agree with whats in print however I know better then to just take it as absolute truth....
(Im a vag "master" tech / Shop owner my self, I know the drill...)
It says change the BELT
Nothing mentioned about changing the tensioner or stud...
Again
This is an ETKA fail...
This was removed from a BRM jetta basic, build date 02/05
Nothing needed to change to swap to the later "G"
I tried this before posting the FS add as there is LOTS of conflicting info....
My etka has conflicting info with in it for these 05/06 cars
YES
And it has the WIDE foot print with the early part #....
IDK........
This is again using ETKA for date changes and we have established that doesnt work......
Thats cause there JUNK.......
ALH is where its @!!!
Old March 2nd, 2013, 05:33   #6
TDINIT
yes this is still for sale
Old March 2nd, 2013, 17:47   #7
Dankcorey22
Dankcorey22's Avatar
Fuel Economy: enough
Ill take it
MY CARs-BLACK 99.5 Jetta TDI 5 speed 17/22 11 MM, and more
1983 VW jetta turbo diesel
Dankcorey22 is offline   Reply With Quote
Old March 3rd, 2013, 06:01   #8
TDINIT
Originally Posted by Dankcorey22 View Post
Ill take it
Your PM has reply!!!
Sale Pending
Old March 4th, 2013, 05:10   #9
oilhammer
oilhammer's Avatar
BRMs in here for routine PM means they are junk? Hrmmm... strange way of looking at it.
At any rate, the bracket you are selling is for the later BRMs, not the early ones. And if you had an early one, you'd want the later bracket I guess to make the belt easier, but it won't do you any good because the accessory bracket would need to be changed out anyways.
oilhammer
Old March 4th, 2013, 06:10   #10
TDINIT
Im sorry,
But ANY engine that requires cam replacements as maintenance is junk
I had a bew PD in MK4 golf and Ill save the highres pics as we all know what happens inside them...
Furthermore ANY engine that has had SO many changes in such a short period ONLY to be replaced shortly there after with the newest "CR" family of engines shows me that there junk......
AND that the manufacture knows it...
AND >> For those that are VW-Audi people and not just diesel folks
Sounds very,very/same, same as the FSI-TSI story with pump followers.........
Old March 4th, 2013, 06:10   #11
TDINIT
sold
o
l
d
Old March 4th, 2013, 06:19   #12
oilhammer
oilhammer's Avatar
They don't ALL need "cam replacements", except the ones that the dumbass dealers feed the incorrect 5w30 oil to.
The PD engine has been in use since 2000.
We have BRM cars in excess of 300k miles here with valve covers that have never been off. I'd say that is a pretty good engine.
The DI gassers engines also often are a result of incorrect oil. They even have a TSB about it (dealers are once again clueless about that, too... )
oilhammer
FS: BRM Engine Accessory Bracket TDINIT Private TDI Items for Sale/Wanted 8 November 18th, 2013 08:12
?? Engine mount bracket to engine block bolt torque setting?? IXLR8 TDI 101 3 September 27th, 2011 22:27
2006 BRM Alt/AC Bracket - broken engine mount joshljoshl VW MKV-A5 Golf/Jettas 2 February 12th, 2011 17:59
FS: Engine mount bracket TDICADDGUY Private TDI Items for Sale/Wanted 3 October 20th, 2009 10:32
Engine Mount Bracket vbenw VW MKIV-A4 TDIs (VE and PD) 2 August 11th, 2004 13:57
Page generated in 0.16985 seconds with 10 queries
[Output: 117.98 Kb. compressed to 99.86 Kb. by saving 18.11 Kb. (15.35%)]
