Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW MKVI-A6 Jetta Sedan (~ 2011+)
VW MKVI-A6 Jetta Sedan (~ 2011+) Discussions area for the MkVI (2011+) Jetta sedan. This model was originally codenamed NCS (New Compact Sedan).
Old February 21st, 2013, 06:54   #1
ProPAL
ProPAL's Avatar
Fuel Economy: Bora Lifetime Average = 6L/100km, Golf Lifetime Average = 6.5L/100km
Default Coolant Smell?
Hey everyone
I've noticed twice now when I get home and park the car in the garage a very noticeable coolant smell coming from the car. I check quickly but could not see any leaks.
My Sig needs updating so my new ride is a 2012 Jetta Highline w. DSG.
I read somewhere but can't find it now this seems like a known issue in regards to the water pump?
Is anyone seeing this issue and has anyone had their car back to the dealer for the fix?
Cheers,
Peter
ProPAL is offline   Reply With Quote
Old February 22nd, 2013, 13:45   #2
ProPAL
ProPAL's Avatar
Car is scheduled in tomorrow at the dealership. I will post the result.
Old March 5th, 2013, 05:35   #3
ProPAL
ProPAL's Avatar
Leak was not located but they will monitor the rate going forward.
Old March 13th, 2013, 14:22   #4
ajohnsonlmt
Let me know if you have any luck with this. Mine is doing the same thing, it's a 2011 with 31k miles on it.
ajohnsonlmt is offline   Reply With Quote
Old March 16th, 2013, 14:47   #5
pinkertonfloyd
Hmmm every VAG car I've owned has had a small of Coolant when shutdown hot... I always figured it was from the heat building up and the (top mounted) overflow tank outgassing.
Also G12 is very low water, and stronger smelling.
If your level doesn't go down, I wouldn't worry much. G12 is fairly easy to spot leaks... it "foams" up usually.
pinkertonfloyd is offline   Reply With Quote
Old March 17th, 2013, 00:44   #6
Hogndos
Just throwing this out there as I have noted it during the rainy season here in Oregon (oh yeah, EVERY season is the rainy season here)...the windshield washer/antifreeze that came from the factory/dealer has a very strong "coolant" smell....more so I think than any store bought fluid I have used...the first time I used the washer ...thought I had spouted a coolant leak as the smell seemed to find it's way into the cabin directly....probably not related to what your getting... only just a thought...
Hogndos is offline   Reply With Quote
Old March 17th, 2013, 08:51   #7
Dozenspeed
Dozenspeed's Avatar
Fuel Economy: $10,457 per TB change
This ^^^^^^^^^^
Do you have a MK6 Jetta SEDAN? (2011-2015) Contribute to our mileage thread here! Over 70 cars and 3.5 million miles of data!
Dozenspeed is offline   Reply With Quote
Old March 18th, 2013, 13:27   #8
ProPAL
ProPAL's Avatar
Sorry for the absence, The smell prevails but me nor the dealer know the root cause yet. If the reservoir looses fluid to the point it trips the low limit sensor they told me to take it back again for another review.
Pressure testing the tested yielded no results.
Thanks for the tips on the matter,
Cheers,
Peter
coolant smell keith102 TDI 101 0 April 7th, 2012 20:24
coolant smell msrtdi TDI 101 1 May 12th, 2009 16:59
Slight coolant loss, coolant smell in cab rampage TDI 101 6 July 15th, 2008 13:35
still have coolant smell msrtdi TDI 101 3 February 11th, 2008 16:09
Coolant Smell TDINJ VW MKIV-A4 TDIs (VE and PD) 2 June 3rd, 2007 07:35
Page generated in 0.13753 seconds with 10 queries
[Output: 87.02 Kb. compressed to 75.05 Kb. by saving 11.97 Kb. (13.76%)]
