Old February 18th, 2013, 12:41   #1
Fulf
Default 2012 Jetta TDI oil changes
I just took a trip from SC to IL over 1300 miles. on the way there i average 62 mph for 45.5 mpg. on the way back i wanted to get home faster. i averaged 72mph and 42.9 mpg. now it is time for my first oil change.
For TDI's after 2003, be careful about the oils recommended in the oil FAQ section. I bought Shell Rotella T6 (found locally, Mobil Devlac is also found locally) thinking that would do the trick. I decided to call Shell to confirm that their product meets the vw 507.00 spec. They said they would not recommend their Rotella for models after 2003.
My oil cap says "Castrol recommended" and doing a little research I have found that Castrol SLX/edge LL03 5w-30 is recommended. The guy at Shell recommended Pennzoil Ultra Euro L 5w-30.
Does anyone have any experience with this? Also do you recommend sucking the oil out with a pump or removing the drain plug?
Fulf is offline   Reply With Quote
Old February 18th, 2013, 13:06   #2
Lightflyer1
Lightflyer1's Avatar
Well you picked wrong from the FAQ. T6 is being used in 2006 and earlier with good results. It is not suited to any common rail engines due to the exhaust system requirements for a low ash oil. The Castrol is what the dealer should sell you. This one is also commonly used as well:
http://www.mobiloil.com/USA-English/...ula_5W-30.aspx
2015 Beetle TDI.
Old February 18th, 2013, 13:15   #3
WutGas?
WutGas?'s Avatar
The Pennzoil has been holding up well it seems based on UOAs from one member.
When researching your car going forward, you need to look at the 2009+ CR FAQs.
WutGas? is offline   Reply With Quote
Old February 18th, 2013, 14:19   #4
kydsid
TDI(s): 2012 Passat
op see signature link
504/507 Oil retail source list - http://forums.tdiclub.com/showthread.php?t=360912
kydsid is offline   Reply With Quote
Old February 18th, 2013, 16:43   #5
T_D_I_POWER
T_D_I_POWER's Avatar
Originally Posted by Fulf View Post
.... Also do you recommend sucking the oil out with a pump or removing the drain plug?
Bottom drain. It is better because you can drain while the oil is still hot. It's easier working with the gravity than against it.
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old February 19th, 2013, 09:02   #6
Roshermoore
Default Right Oil & Top or Bottom?
I've been using it since my 09 was new. Gee, its been four years now.
I used a Pella 6000 for my 40K change and sucked out 4.2 liters. It took a while, but you can get as much out from the top as from the bottom if you are willing to take the time. When you get my age, it's much easier from the top.
09 Jetta Sportwagen, Blue Graphite Metallic, DSG, Sunroof, Rubber mats, Zeta Products body color side moldings, Body color door edge guards, VW front and rear Splash Guards, Clear rear bumper protector, 8" "Stubby" antenna. Build Date 11/08
Roshermoore is offline   Reply With Quote
?Type/Brand Oil for 2012 Jetta TDI sportwagon monkfarm Fuels & Lubricants 30 March 24th, 2015 11:04
2012 Jetta TDI Oil Change childog69 Fuels & Lubricants 16 July 26th, 2012 18:32
First Oil Change 2012 Jetta TDI childog69 TDI 101 4 July 18th, 2012 19:06
doing research TDI JETTA 2012 found this Consumers report looking to Buy a 2012 TDI hobokenkid General VW Discussion 38 June 12th, 2012 14:09
2012 Jetta Sportwagon oil changes familyman831 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 6 May 1st, 2012 13:42
Page generated in 0.14713 seconds with 10 queries
[Output: 77.47 Kb. compressed to 67.84 Kb. by saving 9.62 Kb. (12.42%)]
