Old February 21st, 2013, 12:44   #16
James & Son
TDI(s): 2006 Jetta
Originally Posted by TooSlick View Post
Mobil Delvac 1/ESP actually has 67% higher ash than a typical VW 507.00 formulation:
(.4%/.6%)(100%) = 67%
TS
Sorry to be picky but actually .6/.4 is 50% more so 5-40 FM is not 507.00!!! How soon we forget or are fooled. Toolslick and Bob you better clarify this.
James & Son is offline   Reply With Quote
Old February 22nd, 2013, 00:12   #17
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
Devlac 1 ESP 5w40 is CJ-4, 1% ash
Mobil 1 ESP FM 5w40 is 229.5, 0.6% ash
Mobil 1 ESP 5w30 is 507.00, 0.6% ash
(1/0.6) = 1.67
2003 Jetta TDI (sold) / 2015 GTI 2.0T
Photos | Mods | CJ-4 Oils | Oil Analysis | Stage II Cam
Bob_Fout is offline   Reply With Quote
Old February 22nd, 2013, 04:09   #18
TooSlick
TDI(s): Audi 100S
As shown above 1.67 = 167%, or 67% higher ash for the Mobil Delvac 1/ESP, or any other API/CJ-4 Spec diesel oil. If you were looking at it the other way (.4%/1.0%), you could also say that a VW 507.00 oil has 40% less ash - compared to an API/CJ-4 oil. The two statements convey the same exact data.
(This is why we need more math teachers and fewer lawyers). :-(
TS
TooSlick is offline   Reply With Quote
Old February 22nd, 2013, 04:13   #19
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
TS
+1 on the math and LOL at the parenthetical statement
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old February 22nd, 2013, 15:51   #20
James & Son
TDI(s): 2006 Jetta
Yes, you caught me out. I jumped in to quick thinking you meant 507.00 was .4% ash and 5w-40 FM was .6% and the comparison was between those two oils. But in fact they both are .6%. Never mind you got me on that one. Rub it in.
Old February 25th, 2013, 09:07   #21
T_D_I_POWER
T_D_I_POWER's Avatar
(1/0.6) = 1.67
Castrol Edge 5W30 VW 507.00, 0.64% ash
YEAH. MB229.51
//TDI POWER
2004 B5.5S
1st TO USE Mobil 1 ESP Formula M 5W-40 IN THE CLUB http://forums.tdiclub.com/showpost.p...56&postcount=9
1st TO PREFILL OFH/OFI INSTL W/ OIL IN THE CLUB http://forums.tdiclub.com/showpost.p...02&postcount=5
1st TO PREFIL FF W/ DIESEL FUEL IN THE CLUB http://forums.tdiclub.com/showpost.p...4&postcount=14
T_D_I_POWER is offline   Reply With Quote
Old February 25th, 2013, 09:49   #22
TooSlick
TDI(s): Audi 100S
An older, VW 502.00/505.00 oil can have up to 1.5% ash, although most come in a bit lower.
TS
Old February 25th, 2013, 09:53   #23
Bob_Fout
Oil Wanker
Bob_Fout's Avatar
TS
The widely/worldly popular Mobil 1 0w40 is 1.3%
Old February 25th, 2013, 13:18   #24
T_D_I_POWER
That's why use M1 ESP 5W40 FM for both VAG Diesel and gas powered cars.
//TDI POWER
2004 B5.5S
Old February 27th, 2013, 23:52   #25
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
Default Just want to thank you guys!
I just moved into a 2009 Jetta TDI from a 2006 and the Devlac 1 ESP 5w40 was the oil of choice in my 2006 and I had EXCELLENT results with it and extended OCI's. Looks like I'll change it up to the Mobil 1 ESP FM 5w40 and see how that oil holds up.
Bob/TooSlick, can you give a quick "general" mileage folks are running on the CRD Jetta's? I'll search it out if you'd rather not but I think you have a captive audience in this thread that love the feedback and knowledge you possess and share with the club.
Thanks again!
Mrrogers1 is offline   Reply With Quote
Old February 28th, 2013, 08:12   #26
WutGas?
WutGas?'s Avatar
Mileage on the oil? 10K.
WutGas? is offline   Reply With Quote
Old February 28th, 2013, 08:18   #27
Mrrogers1
Yes, OCI and thanks! I'll miss my 15-18k OCI's but I'll continue having UOA done to make sure everything is in order.
Sent from my EVO using Tapatalk 2
Old February 28th, 2013, 10:01   #28
WutGas?
WutGas?'s Avatar
Well most people are doing the 10k, but some UOAs show that it could go longer. You gotta remember that many CRs are still in warranty so sticking to the factory recommended OCIs is the safe thing to do.
Old February 28th, 2013, 10:12   #29
tditom
Originally Posted by Mrrogers1 View Post
I just moved into a 2009 Jetta TDI from a 2006 and the Devlac 1 ESP 5w40 was the oil of choice in my 2006 and I had EXCELLENT results with it and extended OCI's. Looks like I'll change it up to the Mobil 1 ESP FM 5w40 and see how that oil holds up. ...
Does anyone actually have any UOA data that would indicate a VW507 oil would not protect a tdi CR engine as well as a 5W40?
-tom
Old February 28th, 2013, 10:45   #30
TooSlick
TDI(s): Audi 100S
The 5w-30, VW 507.00 oils are working just fine. I've seen a few oil analyses, representing maybe 1%-2% of the vehicles, where the oil did not hold up for 10,000 miles. However this can only be helped by using a formulation with a higher starting TBN, ie more detergency. Using a thicker oil isn't going to address this issue.
TS
Mobil 1 Turbo Diesel Truck 5w-40 Synthetic oil Old Navy Fuels & Lubricants 84 August 1st, 2012 13:35
Mobil Turbo Diesel Truck BDison Fuels & Lubricants 11 March 5th, 2008 14:52
Its April..anyone find "new" Mobil 1 - Turbo Diesel Truck oil... BurpleTDI Fuels & Lubricants 260 June 3rd, 2007 06:12
Mobil 1 Turbo Diesel Truck finally available! compu_85 Fuels & Lubricants 60 February 3rd, 2007 06:31
Looking for Mobil Truck and SUV Oil RichC Fuels & Lubricants 7 August 28th, 2004 07:09
Page generated in 0.16656 seconds with 10 queries
[Output: 133.83 Kb. compressed to 112.36 Kb. by saving 21.47 Kb. (16.04%)]
