Old February 16th, 2013, 18:00   #1
SkyRyder55
Fuel Economy: 5 L/100kms
Default G12 compatible coolant
Is there a common coolant available that is compatible with VW G12 for a top off?
SkyRyder55 is offline   Reply With Quote
Old February 16th, 2013, 18:43   #2
GoFaster
Moderator at Large
VW G12.
Use the right stuff.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
GoFaster is online now   Reply With Quote
Old February 16th, 2013, 19:30   #3
SkyRyder55
thanks. unfortunatly, dealerships are closed sunday and monday is a holiday. i need to drive the car.
Old February 16th, 2013, 19:46   #4
GoFaster
Moderator at Large
How much coolant is actually needed??
Fill the bottle using distilled water to the lower line on the bottle now (measure how much you put in) then add that same amount of straight G12 when you can get your hands on some. The very slight temporary dilution won't be an issue.
Brian P.
Old February 16th, 2013, 19:47   #5
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
G12 or distilled water.
Trusted TDI Mechanics Map || TDIClub Chat
Old February 16th, 2013, 20:11   #6
Ski in NC
Fuel Economy: 48-52 typical
Just top off with distilled water. Buck a gallon at the supermarket.
2001 Jetta TDI 5sp Stock 201k mi
1981 Rabbit IDI 4sp Sold at 339k mi
1990 S-10 4.3 4wd 5sp 154k mi
1986 VW Pathfinder 1.6 45hp Marine 4700 Hrs
2001 Cummins 8.3 420hp Marine 1660Hrs..REFIT DONE!!
Ski in NC is offline   Reply With Quote
Old February 16th, 2013, 20:12   #7
SkyRyder55
ok. After more research G12 is the only way to go if I dont want to incurr a huge disaster. So I guess im adding distilled water and hoping the weather stays not that cold.
Old February 16th, 2013, 20:31   #8
AndyBees
AndyBees's Avatar
Mixing conventional off the shelf antifreeze with G12...
Nuff said?
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
Old February 16th, 2013, 20:44   #9
BKmetz
Administrator
BKmetz's Avatar
Fuel Economy: 50 MPG
Zerex G05
Brian, 2015 Passat SE TDI 6MT, 2014 Passat SE TDI 6MT sold back to VW on 1-3-18
Wifey, 2014 Passat SE 2.5
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is offline   Reply With Quote
Old February 16th, 2013, 21:10   #10
compu_85
Gadget Guy
compu_85's Avatar
I thought G05 was similar to G11, which shouldn't be mixed with some versions of G12?
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old February 16th, 2013, 22:17   #11
BKmetz
Administrator
BKmetz's Avatar
Valvoline/Zerex is licensed to use the BASF formulation for Glysantin G-05. Glysantin G-05 is a HOAT coolant with no 2-EHA (2-ethylhexanoic acid). 2-EHA is the additive in Dex-Cool and caused the Dex-Cool sludge problem.
Glysantin G-30 is the green/blue coolant to mix with the older generation coolants.
Here's a great article with a color table.
http://donsnotes.com/home_garden/auto/antifreeze.html
Old February 17th, 2013, 11:19   #12
Ol'Rattler
Ol'Rattler's Avatar
Pentosin does make both a G11 and a G12 compatible anti-freeze which some NAPA parts stores carry.
http://pentosin.net/f_antifreeze.asp
  • PENTOFROST NF (with silicates) (For G11).
  • PENTOFROST SF (without silicates) (For G12).
2006 Jetta TDI
5 speed, Manufactured 06/06
DC stage 1 SMF Clutch
Draw-Tite hitch
Dash Tray
Blue tint aspherical mirrors
Euro Cupholder
Euro Light Switch
2nd grocery hook
Adjusted Cam to Crank Timing
Old February 17th, 2013, 18:22   #13
SkyRyder55
Great. Thanks. I picked some up. But since my water pump is leaking like a sive right now im not pouring more in. $25 for 1.5 liters. ouch. Gotta change the pump.
Old February 18th, 2013, 00:13   #14
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
timing belt due?
DPM is offline   Reply With Quote
Old February 18th, 2013, 06:04   #15
SkyRyder55
no. Was just done by previous owner 40 000 kms ago. have paper work to prove it.
Long story short, I had a training school working on my car, they left a clamp off a coolant hose. While doing an Italian tune up, hose blew off. Did not notice all the smoke behind me till doing the second wot run. I have to assume running the pump without coolant smoked it.
G12 Plus Plus Coolant Mass. Wine Guy VW MKIV-A4 TDIs (VE and PD) 4 July 31st, 2012 10:49
coolant thats not g12. what!! pure_octane Fuels & Lubricants 14 December 14th, 2010 04:07
G12 coolant dunl Central Canada 6 October 29th, 2009 04:35
G12 coolant Schmoky TDI 101 5 November 19th, 2008 20:39
G12 Plus Coolant DbLog General VW Discussion 5 September 11th, 2006 10:02
Page generated in 0.15702 seconds with 10 queries
[Output: 127.25 Kb. compressed to 106.21 Kb. by saving 21.04 Kb. (16.54%)]
