Thirstyturtle328
So here's the scoop; I have a 2002 Golf with 195,000 miles, I bought it at 165,000 miles. The shifting has always been perfect and I've loved that aspect of the car. But after reading these forums 24/7 I decided I should change the manual transmission/differential fluid since, for all I know, it's the original fluid. So I bought some VW G070 fluid from IDparts and this past weekend I changed it out, everything went smoothly. The old fluid was quite dirty and sparkled in the sunlight (tiny metal shavings) so I felt good about changing it.
Well the first day or so of the change everything was okay although I definitely didn't think the shifting was any better. Well now it's been 5 or 6 days and the shifting is getting TERRIBLE. Moving the shifter left and right is genuinely difficult...so much so that if I push it all the way left or right it STAYS IN PLACE (see pictures). Also, pretty much every time I stop the vehicle, when I go to start again, it won't go into first (like it hits a wall), and I have to pull it back down into neutral and try again, usually takes 2 times, sometimes 3 or 4. Same deal when shifting into 3rd sometimes, it just stops and I have to pull it back into neutral and try again.
The only other thing I changed this weekend is my motor oil so I'm 100% sure that all of these symptoms are being caused by the transmission fluid change...but why?!?! Maybe the G070 is WAY thicker than whatever was in there before? I'm so upset about it because I've been honked at multiple times at lights because I'm unable to get it into gear :0(
Picture of shifter "stuck" to the left:
Picture of shifter "stuck" to the right:
Please help me guys! I'm assuming the answer is to change the fluid to something different but I really don't think G070 should be causing this much of an issue!
