Old February 13th, 2013, 14:42   #1
fgiraffe
Default G13 versus G12 coolant?
Hello all-
I have a 2012 TDI JSW with 9700 miles, and my coolant warning light came on. I checked the level, and it is just below the lower line in the reservoir. It's going in for its 10k mile service next week, but I don't want the coolant to be low until then.
Checked the manual, which calls for G12 plus-plus or G12 plus coolant. I didn't find anything with that spec at my local generic parts store. Went to the dealer, and they sold me this:
(Hrm, do imgur links not work? Link just in case )
VW Part # is G 013A8J1G
Which reads as G13 to me. Did this supersede G12? I didn't really find much definitive on the intertubez, so I thought I'd ask here.
Did the dealer sell me the wrong coolant?
I did not open the bottle to check the color, I'd like to be able to return it if it is the wrong stuff.
And at $33 a gallon, I now have my welcome to the world of VW parts!
fgiraffe is offline   Reply With Quote
Old February 13th, 2013, 14:51   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
ETKA shows the 'G13' starting on build date 01.06.2012 so yeah there may have been a running change. Check your car's build date on the door jam sticker. It may just be that there has been a supercession.
This means that if your car was built on June 1st of 2012 or later, it uses the G13. Up through May 31st 2012, it was G12++.
oilhammer
www.cardocautomotive.com
Old February 13th, 2013, 15:21   #3
fgiraffe
OK, thanks. I take it then that G13 is not recommended to mix with the G12++?
My car was picked up in May, so definitely built before June 1 2012.
I'd go ask the Service Manager at the dealer, but they'd prolly give me a third answer.
Old February 13th, 2013, 15:24   #4
oilhammer
oilhammer's Avatar
Honestly, I do not know what G13 is *safe* to mix with. Since G12++ is indeed available, I'd probably just stick with that to be safe.
oilhammer
Old February 13th, 2013, 16:21   #5
DieselZappa
DieselZappa's Avatar
TDI(s): 2001 Golf
Fuel Economy: Avg. 52 mpg so far
G12 part# just superceded to G13 part#...looks to be the same stuff?
funkengruven
DieselZappa is offline   Reply With Quote
Old February 13th, 2013, 17:05   #6
jeff@mcm
Fuel Economy: dismal, but fun
FWIW our local dealer is sending us G13 in place of G12 for a few weeks now.
jeff@mcm is offline   Reply With Quote
Old February 14th, 2013, 04:50   #7
oilhammer
oilhammer's Avatar
I get my coolant in Pentosin brand from an aftermarket wholesaler, so I am not certain what Volkswagen is doing with coolant.
oilhammer
Old February 14th, 2013, 11:23   #8
Kenn JSW
I did quite a bit of research on G12++ vs G13. It appears that they are really the same thing, but G13 is produced in a slightly more "environmentally friendly" manner. It seemed to start out as Europe-only and Skoda brand only.
From this research-
Here’s some interesting info from a Skodaparts.com site:
G13 coolant additive provides the same exceptional cooling and antifreeze performance as G12++, but is manufactured in an environmentally sustainable way, using glycerin instead of glycol. Glycerin, a bi-product of biodiesel production, is much less harmful to the environment than glycol-based products, which are produced from mineral oil. In comparison with the manufacture of traditional coolant additive, it is estimated that G13 production will produce 11 per cent lower CO2 emissions.
So there is a difference in manufacture, but it may not matter in actual use, and the final product may be identical. What I suspect is that VW isn’t yet able to produce enough of the G13 to supply markets outside of Europe. It could also be that different markets use coolant sourced from different suppliers, and suppliers for the US aren’t yet capable of producing the G13.
Compatibility chart:
Kenn JSW is offline   Reply With Quote
Old February 15th, 2013, 20:40   #9
fgiraffe
Dealer said that this was all they had now, so I used it to top off.
FWIW, the new G13 was the same pinkish color as whatever I had from the factory when I took delivery in May 2012.
So far so good.
Thanks all for your info.
Old November 16th, 2014, 10:59   #10
CZguy
CZguy's Avatar
I'm sorry for digging this old thread up, but I just ran across several warnings that stated "do not mix G11 G12 or G13 as they are not compatible".
"When one engine fails on a twin-engine airplane you always have
enough power left to get you to the scene of the crash."
"Directions to heaven. Turn right, and go straight."
CZguy is offline   Reply With Quote
Old November 16th, 2014, 11:03   #11
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
G11 (blue) and G12 (nuclear pink) are definitely not compatible. G12, G12+, and G12++ are compatible with one another. I believe G12 (+, and ++) are not compatible with G13.
Trusted TDI Mechanics Map || TDIClub Chat
VeeDubTDI is online now   Reply With Quote
Old November 16th, 2014, 14:46   #12
Kenn JSW
I posted a compatibility chart just a few posts above! G13 is compatible with the G12++.
Old November 16th, 2014, 15:00   #13
Good Ol' Boy
VeeDubTDI's Avatar
I missed that! Thanks.
So it's basically saying that new coolants are reverse-compatible with old coolants, except for G12 and G11, which don't play nicely with one another.
Old October 17th, 2015, 08:57   #14
KCCats
Sorry for digging this up once again, but why can't I just flush with water and use standard anti?
KCCats is offline   Reply With Quote
Old October 17th, 2015, 10:37   #15
ATR
ATR's Avatar
One thing I've learned working with different car makes is to listen to the OEM's recommendation on use of antifreeze. In the case of the MKVI the best thing you can use is G13 OEM fluid.
If you can't find any locally try IDParts:
http://www.idparts.com/g13-coolant-gallon-p-1974.html
This must be mixed 50/50 with distilled water.
Drivers Wanted
-2011 Golf TDI 6MT = gone but not forgotten!
-2017 Golf GTI Sport 6MT
***Official maintenance schedule for your VW [PDFs inside]***
ATR is offline   Reply With Quote
G13 Coolant better for environment? But any good in our TDIs? s.pavel6 Fuels & Lubricants 9 January 26th, 2013 09:47
G13 Coolant Pink/ 507 synthetic maniago VW Passat Family (NMS and B7) TDIs (2012+) 26 July 18th, 2012 08:55
G12 coolant dunl Central Canada 6 October 29th, 2009 05:35
Where to get G12 coolant? Str9012 Fuels & Lubricants 7 June 19th, 2007 20:32
Need G12 Coolant -- Where can I get it? Tussey VW MKIV-A4 TDIs (VE and PD) 11 November 25th, 2003 23:46
Page generated in 0.13858 seconds with 10 queries
[Output: 128.21 Kb. compressed to 106.60 Kb. by saving 21.60 Kb. (16.85%)]
