Old February 10th, 2013, 07:53   #1
rbartson00
Default Kerma Tunes
i recently purchased a 2006 jetta tdi with dsg automatic trans with 77k miles i dont rely know much about these cars i just got a good deal on it and wanted the mpg
but my real question is i want to put a tune on it but i dont want to send out my ecu. so i was considering the q loader from kermatdi. i was just wondering if its worth the price? and how are there tunes?
http://www.kermatdi.com/servlet/the-...04-pls-/Detail
rbartson00 is offline   Reply With Quote
Old February 10th, 2013, 08:35   #2
joseluis.17g
Most tunes are the same, there are several tuners specialized in Diesel engines like Kerma, Malone, rocket chip etc etc.
If you want to pay less, instead of purchasing the tune loader, you could rent a flashzilla for $50 dlls. With Malone tuning
Or find a dealer that's close to you
07 Mexican MKIV PD AXR engine 40,000 miles, Malone Tune, vr6 clutch, eibach pro kit, Upgraded SMIC, VNT 17/22 trunk mounted battery, mufflerectomy..
joseluis.17g is offline   Reply With Quote
Old February 10th, 2013, 08:42   #3
rbartson00
i like the loader because i can also make it back to stock but what stage should i do with everything else stock? and i dont want to kill the tranny
Old February 10th, 2013, 08:43   #4
LNXGUY
LNXGUY's Avatar
TDTuning might be another tuner you should look into.
Bill
LNXGUY is offline   Reply With Quote
Old February 10th, 2013, 09:54   #5
eddie_1
eddie_1's Avatar
You can now get an original flasher for the Hobbyist only $250, now being sold out of CT on ebay but maybe shipping from Europe. Alientech Powergate. I think the Q loader is actually based on this one. Then you still have quite a bit of money left over for a tune. This is really a brilliant flasher, has recovery options and original tune is on the loader at all times. Alientech is top notch.
2008 A6 BPP 283kmh - 100-200 kmh 14 secs - 2003 Jetta Wagon ALH 150mph, 170WHP Smoke free German Map, VNT 17/22, 11mm IP, 02M DRW 6speed, OMI, Lower IC pipes,FMIC, PD Lift Pump, 3bar map, ARL Sachs Upgraded/DMF, PP764s, CCV Filter, EGR delete, PD150 Intake, PD150 SRP, 2.5" DP with Magnaflow Cat & 2.5" Catback, R32 DSG Snorkel, PD150 Airbox/MAF, Custom Accordian, Ventectomy, Rear Fog, Euroswitch, 5 brake light mod, McNally EGT/Boost Gague, Scanguage II, Hidden Hitch, LED tails, Koni Reds, Depo
eddie_1 is offline   Reply With Quote
Old February 10th, 2013, 10:50   #6
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Drive to Red Lion, PA and see Rocketchip. Having a Tuner actually lay his hands on your car beats the heck out of mail order....
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old February 10th, 2013, 20:41   #7
diesel4ever
diesel4ever's Avatar
Fuel Economy: 4.2/4.8/5.5
I've had Kerma tune on my ALH and BEW cars. All positive experience and the beauty is the lifetime support. On my ALH I have few tunes I can choose from (low smoke, all out power or original).
2004 Jetta TDI Sport, KERMA Tune, VNT17 Turbo, 505,000km
2004 Jetta (hers), KERMA tune (otherwise stock), auto, 365,000km.
diesel4ever is offline   Reply With Quote
Old February 11th, 2013, 00:40   #8
Biodezl
Biodezl's Avatar
RocketChip has been my tune of choice for two vehicles. What worked well for my Passat was to pick up a used ECU from car-part.com for $150 and have it reflashed to work for my vehicle. I asked the salvage yard to give me the VIN of the vehicle the used ECU came from and I got the 4 digit CAN security code from my vehicle with an appropriate ODBD reader. I probably shouldn't go into too much more detail here (there are a few other threads on this), but I gave Jason both VINs, the used ECU, and the 4 digit security code, he made me a plug-and-play ECU. I keep the original ECU untouched in case I want to go back to stock configuration such as when I sell the vehicle. However, no ECU swapping was needed when I took the car in for a smog check because of how he does the reflash.
-BIODEZL
2005 Passat Wagon TDI Silver
1999.5 Golf GLS TDI Automatic Green
Biodezl is offline   Reply With Quote
Old February 12th, 2013, 16:20   #9
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
Q-loaders are Alientech
Most of the ones out there are simply plated with the tuner's logo. Never had a problem with any of the loaders I used
As for tuners, any of the previously mentioned work great. All are reputable
02 Jetta, 17:1 CR 81mm ASV, Colt cam, Peloquin LSD, Raxles, FueLab pump, 12mm/DE143, Gibonta 5 x 0.018, NX nitrous, 6+6 turbo, Bilstein coilovers
MKVII GTI 6MT, full build, 525hp
MKVII GLI DQ381, 93 tune only, daily driver
loudspl is offline   Reply With Quote
Old February 16th, 2013, 14:11   #10
eddie_1
eddie_1's Avatar
Since somebody asked me I want to clarify. With the Alientech Poweregate S (self programmer) series there is a slave version and a master version. I believe the slave version allows tuners to resell the loader and lock it but the master version allows you to upload tunes from any tuner. They are both the same price usually. The Master is then for the Hobbyist and allows you to upload any tunes and store altogether 3 (incl. orig) on the tool at any time. The Master is locked to one car and is released for another car when the car is returned to original. However there are folks able to unlock the 1 car restriction for about 200 in Germany. The good thing about the tool is that it also carries out checksum and checks the validity of everything automatically before upload to ECU.
Here is a website in England selling both for example. Make sure you order 'Alientech Powergate S Master':
http://alientechsales.co.uk/products...te&pcategory=s
The upload/download tune to tool software is nice to use and is at following called 'PWGpro':
http://www.alientech.to/xnote/sw/con...wg/pwgdwl.aspx
Old February 25th, 2013, 20:20   #11
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
If the goal is DIY maps, it might be better to just dump the EDC15/16/17 and Powergate box then upgrade to Nira i7r ECU..
Maybe not so easy install...but looks much more capable
Old February 27th, 2013, 12:40   #12
darkhorse
darkhorse's Avatar
Fuel Economy: mid 40's
Back to the original poster: Yes, the Kerma tune is worth the price. To be fair, so are the others. A good tune is your best buy in performance enhancement.
'06 Golf GLS 5 speed, Evo skid plate, Koni FSD's with Shine RSS, SBC stage 3, SMF, KERMA custom tune, R 32 snorkel,PD 150 airbox,MAF,TIP & manifold, K3B,R 783's, Colt stage 2, EJ SMIC, piping by ID Parts, Whitbread 2.5" DP, Aero muffler, 3"KERMA SS pipes, Sigma 5 short shifter, .681 5th gear & Peloquin, Nicktane 1 um fuel filter & DG/Amsoil bypass filter.
darkhorse is offline   Reply With Quote
Old February 28th, 2013, 05:38   #13
TDIJetta99
TDIJetta99's Avatar
Fuel Economy: low 38, high 61, avg 48
That looks pretty sweet.. Only issue I see over here is if you're going to use this on a street car, state inspections in emissions states will be a deal breaker unless they build it to support OBD2 readiness.. I doubt it since they are a Swedish company..
Taking on some work here and there.. Contact me for your needs.. Can do emissions testing friendly ALH tunes on most setups, even swaps. best way to contact is text or email tdijetta99@gmail.com
TDIJetta99 is offline   Reply With Quote
Old February 28th, 2013, 05:59   #14
eddie_1
eddie_1's Avatar
Also one of the goals of DIY maps may be to learn the winols software or one of the more widespread packages, so ideas can be exchanged more readily or Damos files could be shared. Also, EDC17 is really not a bad ECU.
Old February 28th, 2013, 19:47   #15
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
The future of tuning might be DIY maps on some kind of HUD w/ real-time analysis
Limits defined so users can't exceed known/discovered operating parameters of selected hardware. Tuner liability minimized?
There's this little gadget too:
Skynam
Tunes? aaronacj TDI Fuel Economy 7 July 23rd, 2012 17:03
Warranty and Tunes OILPowered VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 26 December 20th, 2011 17:08
A3/B4 WGT Super 17 hybrid turbo on Kerma, question for Kerma, etc. akampion TDI Power Enhancements 14 January 9th, 2009 10:17
KERMA/Alligator Tunes in Wisconsin CAdave Vendor & GroupBuy items for sale 0 November 6th, 2008 22:36
No Tunes stinkmitten VW MKIV-A4 TDIs (VE and PD) 0 March 16th, 2004 23:17
Page generated in 0.18749 seconds with 10 queries
[Output: 133.75 Kb. compressed to 112.08 Kb. by saving 21.67 Kb. (16.20%)]
